This feels like such a daft question, so sorry. I have Blockwork walls to be wet plastered (HardWall + MultiFinish). As I imagine it, the lining depth should be the sum of
 - 2no. (i.e. 1no. on each side) MultiFinish skims 2mm each
 - 2no. HardWall base 11mm each
 - 1no. "100mm" block 96mm
TOTAL: 122mm
But linings are 108mm or 132mm finished depths?
Howdens Door Lining Kit
Am I missing something or should I be ripping them down to 122mm? @nod I hear plasterers hate linings being wrong so what do you suggest? Am I too thin on the MultiFinish layer?
Not a daft question at all
We have lots of issues with skimming and more often taping to the wrong linings 5 mil for skim flush for tape
132 is fine for hardwall
16 mil either side plained back 4 mil around casings and beads
Remember you will need at least 10 mil to cover an electrical capping
I always allow for 10-25 mil of thickness when quoting
Doubt you’ll get perfect 11mm base and most spreads will hit the door linings if that’s what they can see. Also check your 132mm casings as I’ve had them as thin as 128mm and as thick as 138mm depending on supplier.
I don’t like planted linings either but that’s just preference
Thanks, is that 16mm of just HardWall base to then have the finish skim as extra?
When you say plained back around casings and beads does that mean the finish layer is thicker there then?
Howdens seem OK on the one I have so far opened :-)
Yes
They will float the hardwall out flush to the lining Then once it’s set run an angle plane around the angles and lining Cutting it back 2-4 mil
18 minutes ago, nod said:
Yes
That’s doing it properly, I have come across so many not cut back, just the skim feathered to the lining giving a rounded surface fir the architrave to fit too 🤯.
Edited by joe90
Wonder how all this works with shadow gaps? Layer of plaster then the gap forming strip on that then the rest built up to the strip? Then there is the ones with the LEDs in - respect to plasterers🙂.
The shadow gaps are easier to run with wet plaster than boards
Much more versatile for curves etc
We wet plaster very few homes now
Mostly schools and high traffic areas
Such a pity. I'm seriously considering going through the house one room at a time, chiselling off the dry lining, taping for airtightness and wet plastering - which is what I wanted when the house was built but the building contractor managed to talk me out of it. 😪
I did actually win for one room which I plastered myself, the ground floor loo under the staircase which was so small, the dot & dab would have taken up a significant amount of space. Just told 'em to clear off and leave it to me. 🙄
The same level of airtightness can be achieved with dry lining and skim as wet plaster If it is done correctly
As a business I use hundreds of bags of Parge coat Always for soundproofing I never refer to it as an airtight coat As it does little or nothing  for airtightness and encourages the dry liners not to seal everything off probably
I dot and dabbed our first build which is extremely airtight and will do the same with our next
Its roughly the same cost for both
Probably cheaper for me to wet plaster as I’ll do all the laboure myself
Not having a service void then?  I would never build a house without a service void.
No
Weve been in five years and haven’t needed to get behind the plaster so far
20 minutes ago, nod said:
No
Which means you got it right first time.  But a service void would mean you have a fighting chance of making some alterations without needing to patch it up and re decorate afterwords.
1 hour ago, Mr Punter said:
I have not seen this before.  What is it called / used for?
Angle plane
Gives nice sharp angles and takes any high spots off
By not page coating the blocks but having a really good, airtight, dot and dabbed, boarded wall do you not end up with it "cold" behind the plasterboard?
Not at all
Parge would make absolutely no difference to the void behind the boards
In all my years as a plastering company I’ve never been given a bill of quantities stating that Parge coat is for anything other than soundproofing
Years ago the block work would be full of snots and gaps A Parge coat would have definitely helped there
But nowadays blocks should all be jointed
Very little air will pass through a 100 mil block
But if the D&D is sealed properly Along with ceiling lines Very little will get through
But if anyone does decide to add Parge About 4 hour on a a five bed house
Tell the dry liners it’s a soundcoat Like a says on the bag
Or nothing will get sealed
Weave one Multi National contractor that does actually carry out 1-7 air tests Brick and block They are scoring a two without any special measures
Contractor standard windows and doors ( Velfag )
Ta. This is more the case with my house where it would have helped. There's one room, block built with a 2" cavity. Outside is rendered so most are sealed. Inside it's just 1" batten onto the blocks then 1/4" hardboard and woodchip paper. Behind the hardboard there's a gale blowing. Comes up through the suspended floor into the walls too.
One small wall in my recent room-in-roof garage extension got the D & D treatment - as I'd missed giving any other instruction for it and the builders automatically reached for the easiest solution:
The wall has two concrete block leafs with EPS insulation in the cavity. The plasterboard was fitted up to the slope of the roof (visible at top right) and . While there was an attempt to put a continuous bead around the perimeter (as the contractor assured me had been done) clearly there are gaps so any infiltration from the cavity works its way around the edge and blows around behind the boards.
I just don't see enough care and attention ever being likely to be applied in the construction industry. One small gap in a supposedly continuous bead of adhesive can open up an entire wall to external air currents totally short-circuiting the insulation.
I am convinced the only way the average building monkey will ever get a room in roof right, is to make the entire roof a warm roof. Fairly easy to detail, then all the roof space even the bit not used for the rooms, is inside the warm envelope of the house.
Amen to that. But as we are right on the border of a conservation area, adding 200+mm to the ridge height was going to put a major crimp in our planning approval.
The tolerance that the brickie is allowed in the verticality of the block work.
I have an old Elu table saw, good 300mm dia blade and expect to have to rip down the door standards on occasion, facings and stops from time to time.. use old scool skills to hang a door.
You can buy door sets.. like you go to Kwik fit, but if you want quality expect that a door will take an extra 6 hours to fit right and remain right for many years. I have used hard woods that are oiled hence part of the extra time.
Take your time on hanging doors and forming the door sets.. in my own house I spent ages fitting them.. they just shut great, tight and will remain so.. but it takes time to get this quality job. You also need good quality ironmongery.
What has made the job easier when I look back is modern adhesives and the invention of the chop (mitre saw)... but if you have a finishing joiner turning up and they don't have a sharp hand plane.. then they probably don't know what they are really doing.
If you are having really traditional finishes you may not want to use posidrive screws on the hinges, to keep things authentic you want to maybe use slotted wood screws.. the slot in the screws in a traditional hinge should be vertical when tightened.. this is to stop the oils / paints from dripping and the slots should all be in aligment.. yes it's those details that matter.
  • 4 months later...
Door linings are progressing nicely and I am staying a week ahead of the plasterer there. I only have three more to do in blockwork now. One of them is a bit odd though. It's an interior section of a cavity wall. The Utility is a single storey bit on the side of a two storey wall so the lower part of the cavity wall is warm on both sides and has no cavity closer, just a full blockwork reveal. What's the normal ay of doing a door lining in this situation? fit it to one side and plaster up to the back face of the door lining? Not sure how the plasterer would get a good edge on the back face of the door lining.
