5 minutes ago, pocster said:
We should celebrate the big 100 - somehow .....
Donations to my PayPal account would work for me... ?
  • Haha 1
I think 100 people should piss in your new toilet . Baggsy first wee !
1 hour ago, pocster said:
Baggsy first wee !
Lots of experience in having a leak I suppose...
Cess pool wouldn't take it at the moment anyway!
Edited by Onoff
2 minutes ago, CC45 said:
is she good at sorting out plumbing?
My plumbing works fine as I'd happily demonstrate to her...
19 minutes ago, Onoff said:
Says Mr Microbore!
People use to see me coming round the corner a good 5 seconds before I did
5 minutes ago, Nickfromwales said:
Spray foam around the groups of pipe that you now cannot lag ;)  Saw it all square after and rejoice in not having to move the b’stards ?
??? What groups of pipes?
  • 3 weeks later...
Nasty Wickes wood battens on and plumb/level. Quick coat of white in the bit you'll see if ever accessing the pipe/valve to the wc:
20190505_200017
Ran out of gun foam :( Will get a can in the morning and try and get it all insulated and boarded.
16 minutes ago, Nickfromwales said:
Coming along nicely :)
Don't you mean slowly @nick?
Scored some 30mm Kingspan leftover on a site. Original wall in the cupboard so out of plumb I did two layers of 30mm on the top half with blobs of low expansion foam. Lower down 1 layer of 30mm and a full bed of nom 20mm expanding foam behind. I'll let dry, cut level then wash the bird sh!t off before foil taping a bit of vcl for good measure and boarding. "Fire up the Lidl drywall gun!" :)
20190507_204805
https://www.flickr.com/photos/122042403@N05/46882470425/in/dateposted-public/
Some foil tape here and there. Probably overkill insulating these internal walls but SWMBO has commented more than once how quiet the new bathroom is!
I need to make a removable / hinged panel feature to access the valve and get my hand in to the right to access the Geberit connections. Sod's Law the panel edges won't fall on grout lines!
Maybe do a full width, removable ply panel 3 tiles high and just screw in place? Still fancy something hinged...
2019-05-09_12-22-41
Edited by Onoff
It's coming along.
Go for a fully removable screwed panel, hinged might get on the way whilst working and I doubt you'll need to get in there anyway!
B@ll@cks!
SWMBO has just decreed that she wants to use the 51 leftover grey tiles in the yet to be started upstairs ensuite shower. Nom 1200x800.
Said I, "But there's not enough love!"
Apparently we're going to use tbe leftover mosaics to make it work.
Looks like I'll be plastering inside this cupboard then.
Couldn't find my part roll of green vcl so pressed a 1200mm long, clear refuse sack into use:
20190509_185801
Really can't fault this Parkside drywall gun:
20190509_192012
Can't decide on boarding this back bit...thinking down to and up as far as the green arrows and have a full width removable panel. Or do I overboard the narrow bit on the left too and have a smaller panel? This is all going to be plastered.
20190509_193513
Edited by Onoff
Got to decide how to finish this reveal off and not see the plasterboard edge. White upvc trim maybe and leave projecting by 3mm so the plaster comes up level?
2019-05-10_06-07-06
