Nickfromwales Posted May 6, 2018 Share Posted May 6, 2018 1 hour ago, Onoff said: Thinking... Turn on the shower valve for the rainfall head. Flow to the head operates a 15mm flow switch, one of these: https://www.ebay.co.uk/i/332534595956? The flow switch is used to trigger the scissor lift mechanism to lower the rainfall head AND brings on a ring of LEDs around the head. So, just to clarify....... Your actually seriously thinking about a rise and fall shower head? No, of course your not. You had me going there for a minute.......... 2 Link to comment Share on other sites More sharing options...
Onoff Posted May 6, 2018 Author Share Posted May 6, 2018 2 hours ago, Nickfromwales said: So, just to clarify....... Your actually seriously thinking about a rise and fall shower head? No, of course your not. You had me going there for a minute.......... I hadn't thought of adding sounds to it...thanks! https://youtu.be/ay7FwOKNp6M 1 Link to comment Share on other sites More sharing options...
Onoff Posted May 7, 2018 Author Share Posted May 7, 2018 3rd pocket over the wc carcassed at least. Link to comment Share on other sites More sharing options...
CC45 Posted May 8, 2018 Share Posted May 8, 2018 Ideally position such that if you go to pick something off it with wet slippery hands and fumble it ends up down the bog or if the item is heavy - chipping the bowl! Link to comment Share on other sites More sharing options...
newhome Posted May 8, 2018 Share Posted May 8, 2018 21 hours ago, Onoff said: 3rd pocket over the wc carcassed at least. The Mrs stole the shower gel back then? Link to comment Share on other sites More sharing options...
Onoff Posted May 8, 2018 Author Share Posted May 8, 2018 39 minutes ago, CC45 said: Ideally position such that if you go to pick something off it with wet slippery hands and fumble it ends up down the bog or if the item is heavy - chipping the bowl! It'll have some crappy ornament on it no doubt! I had half a thought to incorporate, in some way some of the wife's late cousin's geology collection in the pockets...maybe glazed...lit...? Link to comment Share on other sites More sharing options...
Onoff Posted May 8, 2018 Author Share Posted May 8, 2018 Aqua Panelling fitted loose in the last pocket: That's 50mm of Celotex behind (on an internal 1' thick solid wall) with the 25mm timber frame in front: Not sure if I should pack with more pir before I put the Aqua Panel on: Or leave it hollow behind: ? Link to comment Share on other sites More sharing options...
Construction Channel Posted May 8, 2018 Share Posted May 8, 2018 It would be a shame not to really. Link to comment Share on other sites More sharing options...
CC45 Posted May 8, 2018 Share Posted May 8, 2018 Pack it - why not? You could have set those rocks into the floor - that would be cool. It will all look v different when you get around to fully boarding it - crack on, lets see what it looks like. Link to comment Share on other sites More sharing options...
Onoff Posted May 9, 2018 Author Share Posted May 9, 2018 6 hours ago, CC45 said: Pack it - why not? You could have set those rocks into the floor - that would be cool. It will all look v different when you get around to fully boarding it - crack on, lets see what it looks like. I've got this possibly irrational, possibly not, worry about interstitial condensation in any voids I leave. Unfortunately as the walls taper I can't always avoid it. If I fill this bit between the battens then 25mm pir will sit flush with the front of the battens and be touching the Celotex behind on the rhs. On the left though there'll be a 1/4" gap between the rear of the 25mm pir and face of the Celotex. Best I can do is foam the edges before it goes in so there's hopefully an "airtight" void. In the floor is a really good shout for those rocks. Too late in the bathroom but maybe I can incorporate elsewhere. Link to comment Share on other sites More sharing options...
Trw144 Posted May 9, 2018 Share Posted May 9, 2018 (edited) 11 hours ago, Onoff said: It'll have some crappy ornament on it no doubt! I had half a thought to incorporate, in some way some of the wife's late cousin's geology collection in the pockets...maybe glazed...lit...? Oh they’re rocks are they. Must be me being half asleep looking and not following the thread (it is about the length of the bible and still not finished). I thought it was another experiment - the second picture being a Pitta bread with some left over chips on, and the first what happens to it if you leave it to go mouldy! On closet inspection I can in fact see they are rocks. Edited May 9, 2018 by Trw144 1 Link to comment Share on other sites More sharing options...
Nickfromwales Posted May 9, 2018 Share Posted May 9, 2018 If the second one is full of teeth I wouldn't want to meet whatever owned them! Thats not a labradoodle The first one is uber cool. If its getting in the way i'll have it. Link to comment Share on other sites More sharing options...
Onoff Posted May 9, 2018 Author Share Posted May 9, 2018 2 minutes ago, Nickfromwales said: If the second one is full of teeth I wouldn't want to meet whatever owned them! Thats not a labradoodle The first one is uber cool. If its getting in the way i'll have it. Nice aren't they! (Thought I'd put these up before actually). Something died & got its head flattened millions of years ago: Beautiful but brittle: The scale of them (amethyst?): Vertebrae? Maybe I'll CT1 this somewhere! They all hold sentimental value. I also have his flint collection, parts of which will be inset in brick gate pillars. Link to comment Share on other sites More sharing options...
Nickfromwales Posted May 9, 2018 Share Posted May 9, 2018 Yea, you have posted them before but I won't get tired of looking at them. Do you know where they came from? Regions etc ? Link to comment Share on other sites More sharing options...
newhome Posted May 9, 2018 Share Posted May 9, 2018 Put them round the hot tub with some lights for now. They are too cool to keep in a box. Link to comment Share on other sites More sharing options...
Nickfromwales Posted May 9, 2018 Share Posted May 9, 2018 No! He'll trip over them when pissed and break them..... 1 Link to comment Share on other sites More sharing options...
Pocster Posted May 9, 2018 Share Posted May 9, 2018 6 hours ago, Onoff said: Nice aren't they! (Thought I'd put these up before actually). Something died & got its head flattened millions of years ago: Beautiful but brittle: The scale of them (amethyst?): Vertebrae? Maybe I'll CT1 this somewhere! They all hold sentimental value. I also have his flint collection, parts of which will be inset in brick gate pillars. These would look amazing sat in the floor beneath some walk on glass ... 1 Link to comment Share on other sites More sharing options...
Onoff Posted May 9, 2018 Author Share Posted May 9, 2018 1 minute ago, pocster said: These would look amazing sat in the floor beneath some walk on glass ... Did cross my mind...slippery though! Link to comment Share on other sites More sharing options...
Pocster Posted May 9, 2018 Share Posted May 9, 2018 1 minute ago, Onoff said: Did cross my mind...slippery though! No, no, no. Not slippery at all!. What an incredible feature it would make. Problem is walk on glass is very expensive... Link to comment Share on other sites More sharing options...
dpmiller Posted May 9, 2018 Share Posted May 9, 2018 ... but you know a man that... 2 Link to comment Share on other sites More sharing options...
Onoff Posted May 10, 2018 Author Share Posted May 10, 2018 3rd pocket panelled and cheapo deck light whacked in loose. Looks SO much better in real life in the dark: Continuing the theme of making things accessible for replacement I've decided I'll drop x3 25mm galv conduits down from the loft above each light fitting. I'll stop short of the light itself. Should allow me to easily withdraw these lights and cabling at a later date. 1 Link to comment Share on other sites More sharing options...
newhome Posted May 10, 2018 Share Posted May 10, 2018 And here is just the thing to complement that! ? https://www.amazon.co.uk/gp/aw/d/B074P3F7JL/ref=mp_s_a_1_5?ie=UTF8&qid=1525987374&sr=8-5&pi=AC_SX236_SY340_QL65&keywords=toilet+light&dpPl=1&dpID=51hSF7zH6uL&ref=plSrch 2 1 Link to comment Share on other sites More sharing options...
Onoff Posted May 10, 2018 Author Share Posted May 10, 2018 4 minutes ago, newhome said: And here is just the thing to complement that! ? https://www.amazon.co.uk/gp/aw/d/B074P3F7JL/ref=mp_s_a_1_5?ie=UTF8&qid=1525987374&sr=8-5&pi=AC_SX236_SY340_QL65&keywords=toilet+light&dpPl=1&dpID=51hSF7zH6uL&ref=plSrch Like I'd have something as naff as that in my bathroom! 2 Link to comment Share on other sites More sharing options...
Ferdinand Posted May 10, 2018 Share Posted May 10, 2018 Have you chosen the noise for the flush yet? 1 Link to comment Share on other sites More sharing options...
Onoff Posted May 11, 2018 Author Share Posted May 11, 2018 7 hours ago, Ferdinand said: Have you chosen the noise for the flush yet? Something dropping from a great height? This then. A tenuous link but I just love the track. It gets me "going": 1 Link to comment Share on other sites More sharing options...
