1 hour ago, Onoff said:
Thinking...
Turn on the shower valve for the rainfall head. Flow to the head operates a 15mm flow switch, one of these:
https://www.ebay.co.uk/i/332534595956?
The flow switch is used to trigger the scissor lift mechanism to lower the rainfall head AND brings on a ring of LEDs around the head.
So, just to clarify.......
Your actually seriously thinking about a rise and fall shower head?
No, of course your not. You had me going there for a minute..........
  • Haha 2
I hadn't thought of adding sounds to it...thanks!
https://youtu.be/ay7FwOKNp6M
  • Confused 1
Ideally position such that if you go to pick something off it with wet slippery hands and fumble it ends up down the bog or if the item is heavy  - chipping the bowl!
21 hours ago, Onoff said:
3rd pocket over the wc carcassed at least.
The Mrs stole the shower gel back then? ;)
It'll have some crappy ornament on it no doubt! :)
I had half a thought to incorporate, in some way some of the wife's late cousin's geology collection in the pockets...maybe glazed...lit...?
SAM_5602
SAM_5600
Aqua Panelling fitted loose in the last  pocket:
20180508_203653
That's 50mm of Celotex behind (on an internal 1' thick solid wall) with the 25mm timber frame in front:
20180508_203819
Not sure if I should pack with more pir before I put the Aqua Panel on:
20180508_203859
Or leave it hollow behind:
20180508_203914
Pack it - why not?
You could have set those rocks into the floor - that would be cool.
It will all look v different when you get around to fully boarding it - crack on, lets see what it looks like.
6 hours ago, CC45 said:
Pack it - why not?
I've got this possibly irrational, possibly not, worry about interstitial condensation in any voids I leave. Unfortunately as the walls taper I can't always avoid it. If I fill this bit between the battens then 25mm pir will sit flush with the front of the battens and be touching the Celotex behind on the rhs. On the left though there'll be a 1/4" gap between the rear of the 25mm pir and face of the Celotex. Best I can do is foam the edges before it goes in so there's hopefully an "airtight" void.
In the floor is a really good shout for those rocks. Too late in the bathroom but maybe I can incorporate elsewhere.
SAM_5602
SAM_5600
Oh they’re rocks are they. Must be me being half asleep looking and not following the thread (it is about the length of the bible and still not finished). I thought it was another experiment - the second picture being a Pitta bread with some left over chips on, and the first what happens to it if you leave it to go mouldy!
On closet inspection I can in fact see they are rocks.
Edited by Trw144
If the second one is full of teeth I wouldn't want to meet whatever owned them!  Thats not a labradoodle :S
The first one is uber cool. If its getting in the way i'll have it. :ph34r:
Nice aren't they! (Thought I'd put these up before actually).
Something died & got its head flattened millions of years ago:
SAM_5601
Beautiful but brittle:
SAM_5599
The scale of them (amethyst?):
SAM_5605
Vertebrae?
SAM_5595
Maybe I'll CT1 this somewhere!
SAM_5604
They all hold sentimental value. I also have his flint collection, parts of which will be inset in brick gate pillars.
Put them round the hot tub with some lights for now. They are too cool to keep  in a box.
SAM_5601
SAM_5599
SAM_5605
Vertebrae?
SAM_5595
SAM_5604
These would look amazing sat in the floor beneath some walk on glass ...
Did cross my mind...slippery though!
No, no, no.
Not slippery at all!. What an incredible feature it would make. Problem is walk on glass is very expensive...
3rd pocket panelled and cheapo deck light whacked in loose.
20180510_211115
Looks SO much better in real life in the dark:
20180510_211725
Continuing the theme of making things accessible for replacement I've decided I'll drop x3 25mm galv conduits down from the loft above each light fitting. I'll stop short of the light itself. Should allow me to easily withdraw these lights and cabling at a later date.
7 hours ago, Ferdinand said:
Have you chosen the noise for the flush yet?
Something dropping from a great height? This then. A tenuous link but I just love the track. It gets me "going":
