zoothorn Posted June 6, 2022 Posted June 6, 2022 Hi chaps, Ā I'veĀ Planning Permission for a wood balcony, on my 2019 extention. I need to start the job. In retrospect my french windows (doors) would've opened IN & I just add a quick juliet balcony. D'oh! So, I have to continue with the timber balcony idea. Ā I did a 'prep' design ideas thread, a year ago. Now I need to crack on. I'd really appreciate your help; I'm more adept with timber, & my cabin basework a good prior job giving me confidence. And I hope you too.Ā Ā My original design (I have PP for) included outside steps up. This idea shelved/ no steps now. I need to check with BCOĀ that I can do this lesser plan, but assuming logic says I can:- Ā Job to be based on this local eg: I think, unless anyone disagrees, useful to use this to copy as far as possible. It closely resembles my plan. Less width main difference. And mine in softwood, local one hardwood (?). Ā Main reference pic here.Ā Thanks for reading, Zoothorn. Ā Ā Ā Ā Ā Ā Ā Ā Ā
ProDave Posted June 6, 2022 Posted June 6, 2022 I will watch this with interest as we too have a "balcony pending" but ours probably won't be done this year.Ā This years money is being saved up to get the driveway finished and surfaced properly. Ā The difference in design, is ours, the support pillars (there will only be 2) will be at the mid point of the balcony, not the outer edge, so almost all the weight will be on the pillars and the attachment to the house wall is just to stop it falling over.Ā And we hope to use glass ballustrades.
zoothorn Posted June 7, 2022 Author Posted June 7, 2022 (edited) Hi ProDave, I'm open to suggestions on the design if you think this one isn't up to par. Ā I'm going through designs & builds as much as I can to get ideas, clips etc. Ā One option is to get a pro in, & I know just the guy, to do the " frame".. then I can be left to do the nogs, ballustrades, handrails all else. Or might it be perfectly do-able myself? Not quite sure. Ā The one hindernce is the render of the extention it'll attatch to. It's " hilly " IE the render has a 'contoured' inny-outy effect. But, thankfully this ^ design attaches along just one top section.. not over whole wall. Ā Anyway a rough build plan is my goal to start. Ā Thanks, zh Ā Ā Ā Ā Edited June 7, 2022 by zoothorn
joe90 Posted June 7, 2022 Posted June 7, 2022 1 hour ago, zoothorn said: Or might it be perfectly do-able myself? Definitely š, you have proved yourself that with a little advise you are quite capable. 1 hour ago, zoothorn said: The one hindernce is the render of the extention it'll attatch to. It's " hilly " I would fix the wall timber with threaded rod epoxied into the ātop of the hillsā, and if needed pack out a low bit. I suggest you draw a plan up, post it here and you will get advise on whether it needs amending or not. Crack on sunshine š
zoothorn Posted June 7, 2022 Author Posted June 7, 2022 8 hours ago, joe90 said: Definitely š, you have proved yourself that with a little advise you are quite capable. I would fix the wall timber with threaded rod epoxied into the ātop of the hillsā, and if needed pack out a low bit. I suggest you draw a plan up, post it here and you will get advise on whether it needs amending or not. Crack on sunshine š Hi J.. that gives me confidence. Cheers. Yup good idea I'll draw up a plan once researched a bit more. Ā Got that yellow racer roaring yet? Ā Zh
joe90 Posted June 7, 2022 Posted June 7, 2022 1 minute ago, zoothorn said: Got that yellow racer roaring yet? Eh?
joe90 Posted June 7, 2022 Posted June 7, 2022 4 minutes ago, zoothorn said: Mg Ā Itās red š¤, ah yes all welded up, sprayed and ready for the road š 3
zoothorn Posted June 7, 2022 Author Posted June 7, 2022 Peach Joe90! (Im sure it was yellow in garage.. undercoat? ) Anyway that.. is the nicest looking mg Ive seen. Positively E type ish.Ā 1
zoothorn Posted June 7, 2022 Author Posted June 7, 2022 Pininfarina.. well well I never knew had any doings to any uk car. I can see the difference this makes, as never once has any mg caught my eye, but yours.. just does. What engine? I think a MG gt-? & 60's by looks of the plate?
joe90 Posted June 8, 2022 Posted June 8, 2022 Pininfarina also design the Austin a40 (the later one) š¤Æ, itās 1972, 1798cc
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 17 minutes ago, joe90 said: Pininfarina also design the Austin a40 (the later one) š¤Æ, itās 1972, 1798cc Hmm.. from looks of it I think he designed that one when he was drunk. I think the curvy one looks miles better.Ā Ā Anyway I mustn't digress, car design could polax my thread! 1
joe90 Posted June 8, 2022 Posted June 8, 2022 3 minutes ago, zoothorn said: Anyway I mustn't digress, Yup, get those drawings done and we can advise š
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 Ok balcony to be 1 pillar less than the photo eg. Ā This eg I thought (stepped it out) was 1400mm Depth. Is that an average UK balcony D would anyone know? Ā Thanks zoot. Ā
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 I have Joe90's idea of beam A here. And some form of a frame here A,B,C,D.. but this doesn't follow the photo eg. Ā Tbh Im stuck at the first fence! As how could this frame be supported, so it needs 2 pillars before B, C, D.. maybe.
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 I have this underside photo eg, giving me idea of the longwise beams A to D. Ā But it seems to have no beam A.. but instead 2 side vertical struts fixed to the wall, up @ balcony level.
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 Just now, ProDave said: Ours will be more like 2M depth and 4M wide. Ā Ā I'm sure it will. I think I might have put in for even 1300mm, being tentative thinking I'm never likely to get PP for it. Ā
Happy Valley Posted June 8, 2022 Posted June 8, 2022 We need a 4m wide balcony on a sloping site. Only need 1m depth and don't want any maintenance so I think wood is out of the equation for me.  Have looked at these but coming in at over £4000 incl delivery:  https://diometonline.co.uk/balconies/walk-out-balconies/walk-out-balcony-glass-balustrade
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 4 minutes ago, joe90 said: 1400m. Depth š, what length? Well on my PP drawings it had the steps up, so I am guessing a bit right nowĀ @ Ā L 3200mm.
joe90 Posted June 8, 2022 Posted June 8, 2022 I would do it this way, 6 x 2 around the edges but the short ones could be 4 x 2 on joist hangers @ 600 mm max
Onoff Posted June 8, 2022 Posted June 8, 2022 How did you get so close to take those photos of the local property? š Ā What length is 1 to 4?
zoothorn Posted June 8, 2022 Author Posted June 8, 2022 43 minutes ago, Onoff said: How did you get so close to take those photos of the local property? š Ā What length is 1 to 4? No I didn't trespass.. taken from a very convenient close side road. Anyhow SO obviously a holiday house. I did snooping only yr honour. Ā @joe90Ā Dims (firm) are: L 3320mm x W 1250mm Ā These are what I have PP for; well, what I have PP for is more/ steps too/ like this..
Modernista Posted June 8, 2022 Posted June 8, 2022 (edited) I'm sure you've thought of it but won't it affect the view when you are sitting or in bed in that upstairs room? Especially if you have vertical balusters like that? the balustrade height in the drawing you posted just now looks low in proportion to the doors (and compared to the one you have been eyeing up). Edited June 8, 2022 by Modernista
