zoothorn Posted April 15, 2022 Posted April 15, 2022 Hi chaps. I'm in need of a workshop wall addition for tools. I don't know the name I'm on about tho; I see eg's with a board fixed to your bench wall, with thousands of tiny holes in, you add tool hanger metal things into-? The best eg is on a TV show, Joe Pera Talks With You. A gentle comedy (like therapy it is), the main chap's paranoid girlfriend having a fine 'end of days' basement (stocked full etc) with a work bench & great wall thingy. I'll try source a pic. Best eg. My bench is a pickle as you can see, but so used to it Ive never organised my small (hand) tools. Just a tangle of xyz! Any help appreciated, zoot.
Carrerahill Posted April 15, 2022 Posted April 15, 2022 (edited) 8 minutes ago, zoothorn said: Hi chaps. I'm in need of a workshop wall addition for tools. I don't know the name I'm on about tho; I see eg's with a board fixed to your bench wall, with thousands of tiny holes in, you add tool hanger metal things into-? The best eg is on a TV show, Joe Pera Talks With You. A gentle comedy (like therapy it is), the main chap's paranoid girlfriend having a fine 'end of days' basement (stocked full etc) with a work bench & great wall thingy. I'll try source a pic. Best eg. My bench is a pickle as you can see, but so used to it Ive never organised my small (hand) tools. Just a tangle of xyz! Any help appreciated, zoot. You need something like perfo board or "shadow board". https://www.zoro.co.uk/shop/storage-and-handling/storage-systems/14025115-11-0-5m-perfo-panel-single/p/ZT1021308X?utm_source=google&utm_campaign=pla%2B|%2BStorage %26 Handling&utm_term=ZT1021308X&utm_medium=pla_css_2&targetid=pla-395480001257&loc_physical_ms=1007336&dev=c&gclid=Cj0KCQjwr-SSBhC9ARIsANhzu16z25Hc8ruFNQ2aXnppzH5Y2irm_EBZqnA8vuse6MaMri9p8rcudHAaAkhZEALw_wcB I use a sheet of 4x8 ply or OSB, painted white and carefully mark out and fit hooks and pins. Edited April 15, 2022 by Carrerahill
Linto Posted April 15, 2022 Posted April 15, 2022 I think you mean a peg board wall. Something like this?Peg board
zoothorn Posted April 15, 2022 Author Posted April 15, 2022 @Carrerahill Hi there that's useful to put a name to it thanks, perf board/ yup its this stuff indeed. I'll searc screwfix etc with these two words. What I need is a bigger 1400 x 80mm ( or so) 'perf' board. But are the hanger things specific to each Co's holes I wonder? or maybe a general standard " perf board Hammer Hanger" thing for eg, you buy & stick in.. Im just after the most cost effective way. Maybe if I wait someone might have done similar & recommend an eg. The hanger addition things seem likely the dearest part. Thanks, Zoot.
zoothorn Posted April 15, 2022 Author Posted April 15, 2022 18 minutes ago, Linto said: I think you mean a peg board wall. Something like this?Peg board Hi Linto that's another two words I can use to search. Thanks alot. zh.
ToughButterCup Posted April 15, 2022 Posted April 15, 2022 That bench looks perfectly well organised to me @zoothorn Everything visible, everything to hand, plenty of light, electricity on tap. Wait until you feel ashamed - unprepared to show BH members a photo - of your tool bench before you decide how to organise it. The longer you wait, the better and cheaper the design. I can just about walk into my workshop - almost. 1
zoothorn Posted April 15, 2022 Author Posted April 15, 2022 13 minutes ago, ToughButterCup said: That bench looks perfectly well organised to me @zoothorn Everything visible, everything to hand, plenty of light, electricity on tap. Wait until you feel ashamed - unprepared to show BH members a photo - of your tool bench before you decide how to organise it. The longer you wait, the better and cheaper the design. I can just about walk into my workshop - almost. Hi TBC. Well thing is partly I make my living in here, so the benches are as good as I want, but not the top here: with tools all in a bunch pushed to LHS I'm always digging about for a file or s'driver & so much swearing ensues. Im not doing my new workshop & new benches (both I made) justice. I saw this basement, on the tv show, so well organised & lit.. & got major yearnings for something similar. Even a french horn hanging up. Can't find a www photo eg of it tho. Thanks, zoot.
Carrerahill Posted April 15, 2022 Posted April 15, 2022 57 minutes ago, zoothorn said: @Carrerahill Hi there that's useful to put a name to it thanks, perf board/ yup its this stuff indeed. I'll searc screwfix etc with these two words. What I need is a bigger 1400 x 80mm ( or so) 'perf' board. But are the hanger things specific to each Co's holes I wonder? or maybe a general standard " perf board Hammer Hanger" thing for eg, you buy & stick in.. Im just after the most cost effective way. Maybe if I wait someone might have done similar & recommend an eg. The hanger addition things seem likely the dearest part. Thanks, Zoot. I got a piece of 18mm OSB, built a frame under it with 2x4, sanded it and gave it a coat of clearcoat so it actually looks decent (well for a garage workshop) resin anchored some threaded rod into the wall, put this "shelf" up just above head height above my work bench, it gave me some hanging space, somewhere to mount a task light (just a 4500Lumen 4000K LED batten on a local switch) - next decent offcut of OSB or ply I will make my tool board. But having the shelf there solved so many immediate issues. I call it the tool gantry. I have my safety specs, carpenters square, hammer, level, hand saw and things like that all hung there as they are sort of the everyday stuff. Toolchest and safe next to the bench so everything is within a few steps.
joe90 Posted April 15, 2022 Posted April 15, 2022 @zoothorn can you reach that back wall? If you can I would put shelves on that wall and a piece of thick ply on the left hand wall and bang nails in to hang tools on, you could always draw around the tool and paint the shape so you can see instantly where things go (I was going to do this but it never got off the bottom of my “to do list”.
Onoff Posted April 15, 2022 Posted April 15, 2022 4 hours ago, ToughButterCup said: Wait until you feel ashamed - unprepared to show BH members a photo - of your tool bench before you decide how to organise it. Bet I win on the shame front. 3 benches, all a state.
zoothorn Posted April 15, 2022 Author Posted April 15, 2022 4 hours ago, joe90 said: @zoothorn can you reach that back wall? If you can I would put shelves on that wall and a piece of thick ply on the left hand wall and bang nails in to hang tools on, you could always draw around the tool and paint the shape so you can see instantly where things go (I was going to do this but it never got off the bottom of my “to do list”. Hi J. Good q.. I can with a slight stretch. Made my tops fairly deep. I see your point it'll be annoying to stretch. The idea of the perf board stuff, plus whatnots you insert, isn't quite the affordable idea I thought. Im still trawling tho. So your idea here of an added sheet of ply & diy tool hangers, might be the sensible option. I do like the ease of popping in hanger whatnots wherever you choose to a holed perf board though.. it's sort of future-proof, if maybe not such a cheap idea. I'll trawl www over the wknd. Thanks chaps. Zoot.
zoothorn Posted April 15, 2022 Author Posted April 15, 2022 1 hour ago, Onoff said: Bet I win on the shame front. 3 benches, all a state. You can't have the BH shame cup, & the BH longest ever ever thread cup too. So greedy. 1
AdamSee Posted April 15, 2022 Posted April 15, 2022 The Bott Perfo panels are good. The last commercial workshop I was in had made walls using the panels to split up the different areas of the shop floor. Was great for quickly reorganising the place. If you have the time and tools. I would go down the French cleat system. Google has many images of how it works. You an make a dedicated holder for everything and rapidly rearrange it.
Onoff Posted April 19, 2022 Posted April 19, 2022 Lidl have these in: You get 3 boards the size I'm holding, in a pack along with clips for I think a fiver. Picture on the packet shows 3 together. 1
zoothorn Posted April 19, 2022 Author Posted April 19, 2022 On 15/04/2022 at 19:49, AdamSee said: The Bott Perfo panels are good. The last commercial workshop I was in had made walls using the panels to split up the different areas of the shop floor. Was great for quickly reorganising the place. If you have the time and tools. I would go down the French cleat system. Google has many images of how it works. You an make a dedicated holder for everything and rapidly rearrange it. Hi Adam. That bott perfo looks ideal/ & size too is mostly what I need. So what then goes into the holes.. metal thingies specific to this particular board? Or a more general thingy. Its the thingies Im not so clear on/ hangers/ hooks is it I'm on about? I don't know. French cleat idea looks terrific, & if I had the time to make.. but I really need a quick fix/ board up to go. Appreciated. Zoot
zoothorn Posted April 19, 2022 Author Posted April 19, 2022 @Onoff lidl? Well wel, that's ideal for the sidewall for sure & damn that's cheap too. I think maybe ours doesn't do tools though. But will go& see. Thanks zh
AdamSee Posted April 20, 2022 Posted April 20, 2022 I'm not sure if there are suitable alternative of hooks to use with the Bott system other than their own brand. You can buy a mix pack of hangers and you can arrange them as necessary to hold things. I would expect to spend the same on hooks as I would the wall panel. For holding items such as cordless drills its best to combine 2 different hanging parts to make a "holster" suitable for it. Items such as hammers, screwdrivers, spanners, etc, all have their own dedicated hook. Here's the ones I hung in my dads garage for him. Panel 1 of 2 (circa 2011) Again, there's plenty of inspiration on google. 1
joe90 Posted April 20, 2022 Posted April 20, 2022 Can I enter the “messiest bench” competition? (You want to see the rest of my workshop 🤷♂️)
ProDave Posted April 20, 2022 Posted April 20, 2022 Take a good look. It is rarely that tidy. The rear wall has OSB before the plasterboard went on and just nails to hang the tools on, then drawn round them with a big marker pen.
Carrerahill Posted April 20, 2022 Posted April 20, 2022 8 minutes ago, joe90 said: Can I enter the “messiest bench” competition? (You want to see the rest of my workshop 🤷♂️) That is immaculate! 1
markc Posted April 20, 2022 Posted April 20, 2022 (edited) If anyone broke in and ransacked my garage or workshop they would probably leave it tidier than they found it Edited April 20, 2022 by markc 1
Radian Posted April 20, 2022 Posted April 20, 2022 24 minutes ago, joe90 said: You want to see the rest of my workshop 🤷♂️ Yes
Onoff Posted April 20, 2022 Posted April 20, 2022 This was tidy for me: My trouble is I need to differentiate between working space and the "that'll come in handy one day" tat I can't say no to. 1
joe90 Posted April 20, 2022 Posted April 20, 2022 35 minutes ago, Radian said: Yes You asked for it…..now I finished the build I am Into classic car restoration (learning to spray currently) 2
