HughF Posted April 9, 2022 Posted April 9, 2022 2 hours ago, Onoff said: Bet you're a proper fanny magnet! 😂 I was joking…. I report a few a month. As an eBay seller myself, it gets my back up when businesses start flogging stuff on there to then say ‘final price is plus vat’….. it’s usually second hand plant.
Simplysimon Posted April 9, 2022 Posted April 9, 2022 really like the illbruck 330 have been going over all joints as well as ingoes (reveals, for the southerners) with the sp925 just to make sure it's airtight. that stuff is a whole different ball game.
Onoff Posted April 9, 2022 Author Posted April 9, 2022 1 hour ago, HughF said: I was joking…. I report a few a month. I rest my case, you must be beating them off with a sh!tty stick! 😂
Onoff Posted April 9, 2022 Author Posted April 9, 2022 43 minutes ago, Simplysimon said: really like the illbruck 330 have been going over all joints as well as ingoes (reveals, for the southerners) with the sp925 just to make sure it's airtight. that stuff is a whole different ball game. ...Googles sp295
MikeSharp01 Posted April 9, 2022 Posted April 9, 2022 23 hours ago, Onoff said: It's weird. Not like the crunchy run of the mill expanding foam. This stuff is like rubberised merengue...but in a good way. its got a 35% movement factor hence the jelly feel.
Onoff Posted April 9, 2022 Author Posted April 9, 2022 As there's a skin the other side i.e the non cut side of the foam I'm hoping that will provide the airtightness. Primer at the ready, got some battens ready too for bracing. 1
Simplysimon Posted April 9, 2022 Posted April 9, 2022 1 hour ago, Onoff said: ...Googles sp295 sorry, won't find much related to sealants, dyslexic fingers 😀 sp 925
vfrdave Posted April 9, 2022 Posted April 9, 2022 FM330 is great foam, unfortunately I am struggling to get it in Northern Ireland, and shipping prices are ridiculous from England it seems.
HughF Posted April 10, 2022 Posted April 10, 2022 15 hours ago, Onoff said: I rest my case, you must be beating them off with a sh!tty stick! 😂 You should know what I’m like by now, we’ve been members of ‘that other forum’ for long enough…. I thought I recognised your username. 😏
Onoff Posted April 10, 2022 Author Posted April 10, 2022 8 hours ago, HughF said: You should know what I’m like by now, we’ve been members of ‘that other forum’ for long enough…. I thought I recognised your username. 😏 You look different without your flat cap on! 😂
Pocster Posted April 10, 2022 Posted April 10, 2022 11 hours ago, HughF said: that other forum’ for long enough Pornhub ???
SteamyTea Posted April 11, 2022 Posted April 11, 2022 12 hours ago, Onoff said: You look different without your flat cap on 9 hours ago, pocster said: Pornhub I wear a Dutch Cap when I am there.
Onoff Posted April 12, 2022 Author Posted April 12, 2022 Got the soffit piece up. Held a piece of Marmox up and drew a line on the frame in pencil. Masking taped to that line or near enough. Primed the 4 sides with some tile primer about 2:1. Let it get tacky. Foamed upward onto the reveal concentrating on the edge where the window meets the soffit. Then foamed the top, internal corners of the reveals. Did some lines perpendicular to the window about every 300mm. Held the two soffit pieces up on a board and wedged with some battens down to the sill. Cocked up a tad as the little infill piece on the top right, is at a slight angle. I used the bottom of the masking tape as my guide. In the crap light last night I thought it was the frame! 😤 Plaster should hide it OK.
Russell griffiths Posted April 12, 2022 Posted April 12, 2022 On 10/04/2022 at 20:56, pocster said: Pornhub ??? Grinder
Russell griffiths Posted April 12, 2022 Posted April 12, 2022 @Onoff when fitting a piece of board use a spirit level instead of the board to keep it stiff and straight, you can see it’s level without having to keep checking it.
SteamyTea Posted April 12, 2022 Posted April 12, 2022 (edited) 9 minutes ago, Russell griffiths said: when fitting a piece of board use a spirit level instead of the board to keep it stiff and straight is this about fitting really, or 14 minutes ago, Russell griffiths said: Grinder Edited April 12, 2022 by SteamyTea 1
Pocster Posted April 12, 2022 Posted April 12, 2022 42 minutes ago, Onoff said: Hang on a minute . Is THIS the first ( only ) job you’ve actually finished ??
joe90 Posted April 12, 2022 Posted April 12, 2022 1 hour ago, pocster said: Hang on a minute . Is THIS the first ( only ) job you’ve actually finished ?? No, he finished my turnbuckles 😇 1
Onoff Posted April 12, 2022 Author Posted April 12, 2022 1 hour ago, pocster said: Hang on a minute . Is THIS the first ( only ) job you’ve actually finished ?? I've only done the top and bottom so far... 😉 1
