A Game of Draughts
2 hours ago, Onoff said:
Bet you're a proper fanny magnet! 😂
I was joking…. I report a few a month. As an eBay seller myself, it gets my back up when businesses start flogging stuff on there to then say ‘final price is plus vat’….. it’s usually second hand plant.
  • Replies 119
  • Views 17k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I might have said this before.  Knock down and rebuild (i'll get my coat)
  • Only yesterday was I reading an article in the Guardian about the cost of house renovation and extension and how you can maximise your return on investment. Sadly, there was absolutely no mention of e
  • We're the same. Our whole ethos was "how do we build a house that's big enough but without looking like showy tw*ts?   Think we did ok.
Posted Images
really like the illbruck 330 have been going over all joints as well as ingoes (reveals, for the southerners) with the sp925 just to make sure it's airtight. that stuff is a whole different ball game.
I rest my case, you must be beating them off with a sh!tty stick! 😂
...Googles sp295
23 hours ago, Onoff said:
It's weird. Not like the crunchy run of the mill expanding foam. This stuff is like rubberised merengue...but in a good way.
its got a 35% movement factor hence the jelly feel.
As there's a skin the other side i.e the non cut side of the foam I'm hoping that will provide the airtightness.
Primer at the ready, got some battens ready too for bracing.
1 hour ago, Onoff said:
...Googles sp295
sorry, won't find much related to sealants, dyslexic fingers 😀 sp 925
FM330 is great foam, unfortunately I am struggling to get it in Northern Ireland, and shipping prices are ridiculous from England it seems.
You should know what I’m like by now, we’ve been members of ‘that other forum’ for long enough…. I thought I recognised your username. 😏
You look different without your flat cap on! 😂
Pornhub ???
9 hours ago, pocster said:
Pornhub
I wear a Dutch Cap when I am there.
Got the soffit piece up.
Held a piece of Marmox up and drew a line on the frame in pencil. Masking taped to that line or near enough.
Primed the 4 sides with some tile primer about 2:1. Let it get tacky. Foamed upward onto the reveal concentrating on the edge where the window meets the soffit. Then foamed the top, internal corners of the reveals. Did some lines perpendicular to the window about every 300mm.
Held the two soffit pieces up on a board and wedged with some battens down to the sill.
Cocked up a tad as the little infill piece on the top right, is at a slight angle. I used the bottom of the masking tape as my guide. In the crap light last night I thought it was the frame! 😤 Plaster should hide it OK.
@Onoff
when fitting a piece of board use a spirit level instead of the board to keep it stiff and straight, you can see it’s level without having to keep checking it.
is this about fitting really, or
14 minutes ago, Russell griffiths said:
Grinder
Edited by SteamyTea
42 minutes ago, Onoff said:
Hang on a minute . Is THIS the first ( only ) job you’ve actually finished ??
No, he finished my turnbuckles 😇
I've only done the top and bottom so far... 😉
