Onoff Posted April 19 Author Posted April 19 It's finally happening: Using unistrut instead of proper channel so had to get creative with some 3D printed spacers: 1
marshian Posted April 20 Posted April 20 51 minutes ago, Pocster said: 9yrs ? Have you fixed your leak yet ? 😉 1
ToughButterCup Posted April 20 Posted April 20 How do you manage the water flow (piping) through the roof membrane(s) ?
Onoff Posted April 20 Author Posted April 20 1 hour ago, ToughButterCup said: How do you manage the water flow (piping) through the roof membrane(s) ? Something like this probably. I'm not BUYING a proper flashing. Going to wet diamond drill the tile and 3D print flashings. All glued down with CT1.
Onoff Posted April 21 Author Posted April 21 Would these corrugated stainless pipes do as the interconnects at the top of the panel between panels 1 and 2 then panel 2 and 3? https://ebay.us/m/hHy3Fm Various sizes. I presume I just equally space my panels on the rail and pick the right length /end fitting pipe? Then the pipes through the roof at each end of the array, same stuff or copper? A lad I'm talking to on another forum reckons he's used copper throughout, his system has been up and running 12 years with no issues.
Bramco Posted April 21 Posted April 21 1 hour ago, Onoff said: A lad I'm talking to on another forum reckons he's used copper throughout, his system has been up and running 12 years with no issues. If you use copper, use 10mm, it means there is less heated water in the hot pipe, so the heat gets to the coil in the tank quicker. we did this in a previous house and afaik, it's still running after 15 years... 😄
SteamyTea Posted April 21 Posted April 21 Just make sure all the joints are compression ones. I think those stainless, corrugated, pipes are to allow for expansion and movement. Make the system a drain back one and those problems go away, but gives you other problems.
Onoff Posted April 21 Author Posted April 21 11 hours ago, Bramco said: If you use copper, use 10mm, it means there is less heated water in the hot pipe, so the heat gets to the coil in the tank quicker. we did this in a previous house and afaik, it's still running after 15 years... 😄 It'll be pumped, will 15mm make much difference?
Bramco Posted April 22 Posted April 22 (edited) 10 hours ago, Onoff said: It'll be pumped, will 15mm make much difference? On our pump controller, the pump only ran when there was enough heat in the header on the solar array. I'm guessing yours will also work this way. So in marginal conditions, it only runs intermittently. Using a narrower bore means that the hot water will actually get through to the tank. With 15mm or bigger, you can get the situation where a hot slug is pumped into the pipe but never reaches the tank. I've not checked but I'm guessing 10mm is also cheaper than 15mm. So probably also a better option if you are on a budget. EDIT Try this, it has good insulation as well as a cable for the temperature sensor. https://www.bes.co.uk/solarquip-twin-flex-insulated-solar-pipe-dn16-x-10m-21102/ Edited April 22 by Bramco
Pocster Posted April 22 Posted April 22 11 hours ago, Onoff said: It'll be pumped, will 15mm make much difference? 🙄🙄🙄🙄😉
Onoff Posted April 22 Author Posted April 22 11 hours ago, Bramco said: Try this, it has good insulation as well as a cable for the temperature sensor How much? 😬
Onoff Posted April 23 Author Posted April 23 Render of a 3D printed tile flashing. It'll get CT1'd to the tile. A 110mm elbow will sit on top of this: 2
Nickfromwales Posted April 24 Posted April 24 On 23/04/2026 at 17:24, Onoff said: A 110mm elbow will sit on top of this: If you put a 110mm elbow on your roof, I'll come down there and multi-tool it back off. Just "NO!". It'll be fugly as feck. 1
Onoff Posted April 26 Author Posted April 26 I must have told my lad 110mm internal diameter 🤭 this is mind just a lightweight prototype print: That's obviously a 45⁰ bend rather than as 90 but it's just proof of concept. The pipes will run through it within rockwool type insulation.
Onoff Posted April 27 Author Posted April 27 Decided I definitely want to get a proper ladder between the panels and at each end. Meant extending the unistrut by 880 mm. Of course now the end overhang looks a bit silly so I'm debating adding another bracket at each end
Dillsue Posted April 28 Posted April 28 If you want a "ladder" so you can climb the roof, just slide every other tile up in a vertical row. Your tiles look exactly the same as ours and sliding them up and out of the way makes a great way to move around.
Onoff Posted April 28 Author Posted April 28 😡 In the cold light of day, in fact a cold dark day which matches my mood, I reckon I'm going to have to shift the brackets to offer better support to the extended rails. It's going to mean I think messing around with some ridge tiles on the hips to get the end brackets in on the top rail. Ah well! 4 brackets as is: Back to having a centre one and 5 brackets per rail:
Onoff Posted April 28 Author Posted April 28 I'm guessing nobody usually does this but I'm intending "shading" the installed 3 panels temporarily when done with a "99%" solar reflective blanket(s). Probably secured with bungee cords. This so the unfilled panels don't overheat. The idea being I can finish the roof side pretty much, have all the tubes up there, fitted and safely out of the way. Then concentrate on inside the loft which is another mission. I'll fill the system later on.
Onoff Posted May 25 Author Posted May 25 That one installed panel is the one without the evacuated tubes fitted. It was the one where they were all smashed to hell. Still need to get new ones. So that's both rails fitted, tiles back. Was way too hot to carry on. Even the stainless of the panels were scorching to the touch / bare arm etc! My sense of symmetry is now not offended too much:
Onoff Posted May 26 Author Posted May 26 (edited) Waiting for my AliExpress solar shade "blankets" before I put the two tubed panels up. As for the pipes to connect the panels together I'm not sure 🤔 I've bought some Chinesium, corrugated solar pipes but don't know if they're man enough. The white "top hat" insert seems to be some sort of silicone rubber maybe? People elsewhere have suggested just using 15mm copper instead of the corrugated tubes? Edited May 26 by Onoff
Nickfromwales Posted 14 hours ago Posted 14 hours ago He found it in a holiday let, and just happened to have a pipe cutter in the glovebox.....
jack Posted 2 hours ago Posted 2 hours ago 11 hours ago, Onoff said: Found a second hand cylinder at last: That's no way to refer to the lady.
