November 18, 20214 yr 15 minutes ago, TryC said: i guess my question is, iff the PB is taken down, will it be OK until March 2022? Yes. It might be dusty, ugly, and feel like living in a building site, but there are no practical downsides.
November 18, 20214 yr I asked my wife if she knew hiw to find joist positions. She did. This is not just a bodge but dangerous. Screws into oists essential to revert to just a bodge. Really it should be removed along with the dots and start again. No payment!
November 18, 20214 yr 2 hours ago, TryC said: thank you all for your advice, I very much appreciate it. I just feel so down at the moment with the entire situation. he is a nice chap but will he stay nice after all is said and done?I do not know. I am very anxious about how he will react and get abusive. I'm female so I think this increases chances of happening as I've read so many stories about this happening! "I'm female so I think this increases chances of happening as I've read so many stories about this happening!" I my career I have met an awful lot of blokes that are brain dead. They can't multi task for example. I too have the odd brain dead moment, perfecting multi tasking is a struggle as I'm a bloke so speak from experience. It's not a so much gender thing these days.. it's just a lack of understanding and pride in the job. The trick is to write down on a bit of paper the things you want to ask. No matter what stick to your guns and don't let them side track you. Stick to the list. You can just copy and print off parts of the BH posts if you can and say.. can you answer these questions. If you feel vulnerable then ask a friend to attend. But make sure you hand over the list of questions. If they refuse to accept the list then that is their issue, offer but don't force.Then if you feel that the meeting has become aggressive ask them to leave immediatly. Say to them.. I feel uncomfortable as I feel you are being aggressive so get out of my house! But don't think I'm not going to chase you for your shoddy work..as a parting shot let them know they are far from being off the hook. Do not elaborate.. let them mull it over. Don't muck about. Sometimes getting chucked out of a meeting can crystalize a builders mind.. especially bullying builders as they realize that the Client may well be holding a bigger stick than they first thought. It gives them time to reflect and from time to time they come back with their tail between their legs. They may not of course but if so better to know this now. If they don't come back then you have the option of getting a new joiner to screw up the plasterboard, they will know a plasterer probably and you will get it finsihed for xmas. Edited November 18, 20214 yr by Gus Potter left handed typos and spell checker
November 19, 20214 yr Lots of good advice here but definitely mull over beating yourself up too much @TryC it's difficult sometimes when you get a bad egg I'm and don't know till its too late, but we've all had one at some point don't worry too much you'll get it sorted and it'll be fine. It'll just take a little longer.
November 19, 20214 yr When I read the original post I thought it was a bit odd because I have not heard of sticking plasterboard to a ceiling. Seeing the photos, the original ceiling is cracked and appears weak and defective. To sort this out, they should have suggested either: 1. Skim the ceiling with a thin coat of plaster 2. Overboard the ceiling by screwing new plasterboard into the joist and laths, then skim 3. Rip down the ceiling and laths, screw new plasterboard to joists, then skim. What they have done is stick new plasterboard onto defective plaster, adding to the weight that may come crashing down. The first 2 options would have been far safer and easier. What a knob-end. At least it is only one room.
November 19, 20214 yr Author 9 hours ago, Nickfromwales said: https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DXQ5UbE-h2vg&psig=AOvVaw3VoqFsJGD6Hzd3SPG3JyiH&ust=1637361517939000&source=images&cd=vfe&ved=0CAsQjRxqFwoTCLiA55X9ovQCFQAAAAAdAAAAABAD oh, i think my ceiling might a lath then??? this image is the ceiling in the upstairs bedroom. so one can only assume the downstairs ceiling is made the same way???
November 19, 20214 yr Author 8 hours ago, Mr Punter said: When I read the original post I thought it was a bit odd because I have not heard of sticking plasterboard to a ceiling. Seeing the photos, the original ceiling is cracked and appears weak and defective. To sort this out, they should have suggested either: 1. Skim the ceiling with a thin coat of plaster 2. Overboard the ceiling by screwing new plasterboard into the joist and laths, then skim 3. Rip down the ceiling and laths, screw new plasterboard to joists, then skim. What they have done is stick new plasterboard onto defective plaster, adding to the weight that may come crashing down. The first 2 options would have been far safer and easier. What a knob-end. At least it is only one room. yes, i had asked him to overboard and skim, then skim all the walls. Never would of guessed he doing what he be doing!!
November 19, 20214 yr Author 8 hours ago, SuperJohnG said: Lots of good advice here but definitely mull over beating yourself up too much @TryC it's difficult sometimes when you get a bad egg I'm and don't know till its too late, but we've all had one at some point don't worry too much you'll get it sorted and it'll be fine. It'll just take a little longer. thanks Super John. it is difficult when I think i have done my due diligence and read reviews and still select the bad egg. I have new fitted wardrobes coming in next week and now I am dreading that! hoping it won't be a shit show!
November 19, 20214 yr @TryC for piece of mind, (assuming they are leaving the board adhesive to cure a couple of days) give the new boards a knock and push/pull, if they sound hollow, not fixed correctly or fall off then it needs sorting out. If they seem solid then you will be ok. we have all had ‘bad egg’ tradies so don’t beat yourself up, and there are worse things in life to get stressed over so try not to.
November 19, 20214 yr Author 1 minute ago, markc said: @TryC for piece of mind, (assuming they are leaving the board adhesive to cure a couple of days) give the new boards a knock and push/pull, if they sound hollow, not fixed correctly or fall off then it needs sorting out. If they seem solid then you will be ok. we have all had ‘bad egg’ tradies so don’t beat yourself up, and there are worse things in life to get stressed over so try not to. that is true, but if it kills someone, or something, it is on me if I leave it up?
November 19, 20214 yr Just now, TryC said: that is true, but if it kills someone, or something, it is on me if I leave it up? Agreed, that’s why I said give it a knock and push/pull to see if they are stuck, and I have never heard of anyone being killed by a bit of plasterboard falling a couple of feet, I reckon at the very worst it could crack, become loose and look an ar#e but isn’t going to hurt anyone. but, knowing what it’s like to live with anxiety and worry, then get it all ripped down and start again if that’s what is needed to put your mind at rest.
November 19, 20214 yr Author 10 minutes ago, markc said: Agreed, that’s why I said give it a knock and push/pull to see if they are stuck, and I have never heard of anyone being killed by a bit of plasterboard falling a couple of feet, I reckon at the very worst it could crack, become loose and look an ar#e but isn’t going to hurt anyone. but, knowing what it’s like to live with anxiety and worry, then get it all ripped down and start again if that’s what is needed to put your mind at rest. thanks Mark. Yes, but it could be pulling down the original ceiling which adds to the weight and I have elderly people in the house and it might seriously injure a pet This entire thing has been a shit show and I grow tired of these cowboys, but I don't know until it is too late.
November 19, 20214 yr 5 minutes ago, TryC said: thanks Mark. Yes, but it could be pulling down the original ceiling which adds to the weight and I have elderly people in the house and it might seriously injure a pet This entire thing has been a shit show and I grow tired of these cowboys, but I don't know until it is too late. You will never see a large area of old lath ceiling fall down, one of the worst jobs in renovations is pulling these old ceilings down, all the laths are nailed and the horse hair plaster holds on tight, old plasterboard will come down in sheets.
November 19, 20214 yr Author 9 minutes ago, markc said: You will never see a large area of old lath ceiling fall down, one of the worst jobs in renovations is pulling these old ceilings down, all the laths are nailed and the horse hair plaster holds on tight, old plasterboard will come down in sheets. i see. but he hasn't stuck them up in sheets, he stuck them up in smaller rectangles. sorry, this is all very confusing for me. It might make sense to you, but not for me They picked up their materials and they are not happy, but still being polite and said they have been doing this for years and that the only option was to stick it. As they cannot screw it in - this is the first time they have mentioned they cannot do this with screws. I'm trying to keep this civil, as I think he is.
November 19, 20214 yr 13 hours ago, Cpd said: Much more knowledgeable people will be along to advise but to my eyes it looks like a hash. @nod ? This is indeed a hash job. Do not trust this guy to complete the work unsupervised. Tell him to to it to British gypsum specifications or take it down and leave the site as he got it. Let him know that you will be getting it checked over before skimming and pay a tradesman to check it over.
November 19, 20214 yr Author 3 minutes ago, Gordo said: This is indeed a hash job. Do not trust this guy to complete the work unsupervised. Tell him to to it to British gypsum specifications or take it down and leave the site as he got it. Let him know that you will be getting it checked over before skimming and pay a tradesman to check it over. ahh, thanks for clarifying this. I asked him to remove and he said this is standard procedure when you cannot screw into joists and was not amused I listen to others over his many years of experience said he will try his best to remove but insisted it is stuck solid, and will not fall down after explaining my concerns. Edited November 19, 20214 yr by TryC
November 19, 20214 yr Ask him for the manufacturers installation instructions so you can check… that will shut him up. get him to remove it and kick him off site he’s talking absolute rubbish..
November 19, 20214 yr Author Just now, TonyT said: Ask him for the manufacturers installation instructions so you can check… that will shut him up. get him to remove it and kick him off site he’s talking absolute rubbish.. question now is, what if he seeks payment for work/bodge work done and materials used?
November 19, 20214 yr 4 minutes ago, TryC said: question now is, what if he seeks payment for work/bodge work done and materials used? Say “Sling your hook and I’ll see you in court moron and if I have to make good on your work you are accountable for costs” Edited November 19, 20214 yr by Gordo
November 19, 20214 yr Author 3 minutes ago, TonyT said: Report him to trading standards…. i've never had to do this before, will this send shivers down his spine? how does this process work? will i get backlash??
November 19, 20214 yr If the work had been done to standard , then the tradesman would have had nothing to fear. Inspection by another competent tradesman would have shown the work was done properly and you have been obliged to pay. The image (immediately above) documents bad, possibly dangerous practice. Document everything, then smile, say bye bye and ignore any invoices that come your way. How trades folk think they can get away with this stuff beats me. Honestly.
November 19, 20214 yr Author 54 minutes ago, markc said: Is that the finished item or the ceiling with the new stuff removed ceiling with the dot dab plasterboard removed
