Alexphd1 Posted September 12, 2020 Posted September 12, 2020 Are you diy or contracting out the build?
scottishjohn Posted September 12, 2020 Posted September 12, 2020 51 minutes ago, Mako said: what system would you recommend for basement construction? As I have not built my house yet or indeed any ICF house I can only tell you what system I intend to use which will be a woodcrete type system ISOTEX or DURISOL I add again it is only my view and if there were no woodcrete type ICF systems ,then i would be happy using a poly icf system ,but not as confident that the walls would be as true . the main difference being no need for serious bracing systems and you can glue ,screw anything to the woodcrete blocks very simply anywhere -not just in certain places like some poly block systems. you must do your own investigations - and if including the hire of a full bracing system for your poly block system is as economic as the woodcrete types --then there should be little to choose , other then cladding should be easier to fix to woodcrete -my cladding will be granite slips mortared directly to the woodcrete -
Conor Posted September 13, 2020 Posted September 13, 2020 13 hours ago, tonyshouse said: There are alternatives to PH and current building regs awe woefully poor. I like MINERGIE — minimum energy and happily live without A heating system, use about 1/3 of PH energy use limit. think before you build- energy will only get more expensive. And the new European NZEB - near zero carbon emission buildings.
tonyshouse Posted September 13, 2020 Posted September 13, 2020 NZEB doesn’t seem to have energy use or heating demand numbers which I think it ought to and is why I like MINERGIE and PH
Mako Posted September 14, 2020 Author Posted September 14, 2020 On 13/09/2020 at 00:51, scottishjohn said: As I have not built my house yet or indeed any ICF house I can only tell you what system I intend to use which will be a woodcrete type system ISOTEX or DURISOL I add again it is only my view and if there were no woodcrete type ICF systems ,then i would be happy using a poly icf system ,but not as confident that the walls would be as true . the main difference being no need for serious bracing systems and you can glue ,screw anything to the woodcrete blocks very simply anywhere -not just in certain places like some poly block systems. you must do your own investigations - and if including the hire of a full bracing system for your poly block system is as economic as the woodcrete types --then there should be little to choose , other then cladding should be easier to fix to woodcrete -my cladding will be granite slips mortared directly to the woodcrete - Thank you, I have had a look at both systems, compare to Poly block system, there is no solid concrete layer, would that be a weakness? What stops water getting in? The poly block system has got the solid concrete, but it’s hard to fix anything into it. How do you waterproof below ground? would you recommend concrete shuttering for basement, and insulate from inside?
scottishjohn Posted September 14, 2020 Posted September 14, 2020 2 hours ago, Mako said: Thank you, I have had a look at both systems, compare to Poly block system, there is no solid concrete layer, would that be a weakness? What stops water getting in? even with poly block systems you have to "tank " the outside -so just the same do some investigations
Mako Posted September 18, 2020 Author Posted September 18, 2020 On 12/09/2020 at 23:50, Alexphd1 said: Are you diy or contracting out the build? At the moment I’m thinking of contracting the superstructure, and finishing the build by local trade
Mako Posted September 18, 2020 Author Posted September 18, 2020 On 14/09/2020 at 19:39, scottishjohn said: even with poly block systems you have to "tank " the outside -so just the same do some investigations I have done some I think, I believe you need to deliver two lines of defence, solid concrete is Considered as one, land the tanking as the other. if you were to use woodcrete how would you provide the second line of defence?
Nickfromwales Posted September 18, 2020 Posted September 18, 2020 On 13/09/2020 at 09:05, tonyshouse said: NZEB doesn’t seem to have energy use or heating demand numbers which I think it ought to and is why I like MINERGIE and PH Seemed to be massively hung up on RER when I recently put one through ( NZEB targeted but we got it down to ZEB ).
Ferdinand Posted September 18, 2020 Posted September 18, 2020 (edited) 2 hours ago, Nickfromwales said: RER What's RER? (Apart from Fido with a Stutter). (And the French acronym most difficult to pronounce in French - why did they make the Paris Regional Railway a linguistic chicane? Like giving a Russian R to a non-trombone playing Brit.) (Sounds like the kind of thing BRE might invent so they have to spend hundreds of K of Govt grants explaining it.) F Edited September 19, 2020 by Ferdinand
Nickfromwales Posted September 19, 2020 Posted September 19, 2020 17 hours ago, Ferdinand said: What's RER? Renewable Energy Ratio. What % of the consumed electricity will be offset by self ( eg mirco ) generation. We got 37% on that job which was apparently very good.
Nickfromwales Posted September 19, 2020 Posted September 19, 2020 Its only based on one type of base load, IIRC, and was an odd set of hoops to jump through. A bit of a converse way to get somewhere AFAIC.
MikeSharp01 Posted September 20, 2020 Posted September 20, 2020 On 18/09/2020 at 22:45, Nickfromwales said: Seemed to be massively hung up on RER when I recently put one through ( NZEB targeted but we got it down to ZEB ). I guess it needs to be as that is its reason for being but it does have, differs by country of adoption, some limits elsewhere to stop a person with a a 10 Hectare solar & wind farm building a single skin glass house. Which EU country's regs was the house you worked on aligned to? The N(ZEB) idea has been around since 2010 but the UK has not adopted it - mainly opting out of anything that might upset colleagues in the big housebuilders. You can read the starting point here: https://eur-lex.europa.eu/legal-content/EN/TXT/PDF/?uri=CELEX:32010L0031&from=EN (Page 17) from there you need pick a country if you want details and Ireland is the easy one as theirs is in English and they are taking it seriously. We (me and my other half) are going for PH with a SAP of over 100 which should meet a theoretical N(ZEB) depending on how you feel about how good SAP actually is as a proxey for engergy efficiencey.
Mako Posted September 29, 2020 Author Posted September 29, 2020 Guys, sorry been quiet for a while, been researching, came across interesting systems like Durisol, Isotex and Velox. have you got any experience with those? Based on my research it has been suggested to follow a concrete structure, rather than Timberframe or traditional build. Any suggestions?
Nickfromwales Posted September 30, 2020 Posted September 30, 2020 2 hours ago, Mako said: Based on my research it has been suggested to follow a concrete structure, All depends on what boxes you need ticked. I’ve not liked what I’ve seen of Durisol up to now, but quite impressed with both Velox and Isotex. When the time comes, it’ll be a warm cell blown TF for me without a second thought. Good thing with Isotex is the UK company offers turnkey packages including foundations, so much easier to get a frame up ( for eg for novice self builders ).
ToughButterCup Posted September 30, 2020 Posted September 30, 2020 4 hours ago, Mako said: Guys, sorry been quiet for a while, been researching, came across interesting systems like Durisol, .... have you got any experience with those?... Yes. Durisol. Here's a search listing of everything I have posted on Durisol . Not all good. But the opposite is also true. A great deal of rubbish is posted about ICFs. Outlandish claims are common. Visceral criticism of one or other is also common. The way through that fog of misinformation is to go and look at - visit ‐ a few builds of each type. There'll be good and bad installations in each type of ICF. One will click for you. I'd use Durisol again - but only because I know - mostly - what to look for.
Mako Posted October 1, 2020 Author Posted October 1, 2020 On 30/09/2020 at 01:32, Nickfromwales said: All depends on what boxes you need ticked. I’ve not liked what I’ve seen of Durisol up to now, but quite impressed with both Velox and Isotex. When the time comes, it’ll be a warm cell blown TF for me without a second thought. Good thing with Isotex is the UK company offers turnkey packages including foundations, so much easier to get a frame up ( for eg for novice self builders ). The question is, why warm cell blown? What are the benefits? durisol I have not heard good things either, but the concrete is still interesting me. just read about the Thermal mass benefits. Based on my read many members are underestimating the benefits. solar gains, storage, and heat release when required without any input. Why is that not a benefit? Surely it saves energy for heating/cooling. More I’m reading more I’m gravitating towards concrete structures. Isotex is one of the options, it seem a better product compared to Durisol.
scottishjohn Posted October 1, 2020 Posted October 1, 2020 4 hours ago, Mako said: More I’m reading more I’m gravitating towards concrete structures. Isotex is one of the options, it seem a better product compared to Durisol. having studied both very close and looked at samples -but not built with either the main difference between the the 2 would be a finer finish and accurate width dimension on the istoex when compared to durisol durisol you can only be sure to have one side totally flat due to some differences in thickness of blocks , length and height dimensions seem to be accurate though --not a great problem really and the other difference is the concrete core is 120mm on isotex and 150mm on durisol if I remember correctly - so a 25%saving on concrete costs - check yourself in case things have changed
SteamyTea Posted October 1, 2020 Posted October 1, 2020 4 hours ago, Mako said: just read about the Thermal mass benefits. Based on my read many members are underestimating the benefits. solar gains, storage, and heat release when required without any input. Why is that not a benefit? Surely it saves energy for heating/cooling. Oh dear, where have your read this. 1
joe90 Posted October 1, 2020 Posted October 1, 2020 (edited) @Mako you are about to get a lecture ? (On the other hand I am a fan of a “heavy house” and built mine that way). Edited October 1, 2020 by joe90
Ferdinand Posted October 1, 2020 Posted October 1, 2020 (edited) Welcome, @Mako. I'll sit this one out in my deckchair. Edited October 1, 2020 by Ferdinand
scottishjohn Posted October 1, 2020 Posted October 1, 2020 6 minutes ago, joe90 said: @Mako you are about to get a lecture ? (On the other hand I am a fan of a “heavy house” and built mine that way). me too
Nickfromwales Posted October 1, 2020 Posted October 1, 2020 Why would you want a concrete core to absorb heat from the house, and then have to try to stop it then conveying that to atmosphere by piling more insulation externally? Keep the heated element in the house and wrap it with insulation Adding the concrete core is a downside IMO which creates a path for the heat to be exchanged. You can mitigate with said extra insulation, but even though the U value is good on paper the decrement delay differs from blown cellulose, which is where my money would be. TF feels as solid as most traditional builds, plus you don’t need to large coat before installing the floors to get you airtight. Lots of gotchas with ICF. As for the opinion on Dirisol, I just speak as I find. Velox and Isotex both have bigger blocks and very excellent uniformity, so less junctions to deal with and less making good before internal finishes get applied. TF still remains the easiest for getting very close to airtight. A couple have seen 0.25 and 0.26 ACH which is exceptionally good.
Dan F Posted October 1, 2020 Posted October 1, 2020 6 hours ago, Mako said: More I’m reading more I’m gravitating towards concrete structures. You do realise that there is a. bit of a contridiction in building a passive house out of concrete? Concrete production accounts for 8% of global Co2 emmisions, whereas a timber structure from a sustainable source actually stores carbon. So, your passive house might reduce your yearly carbon footprint, but to fully consider it's environmental impact you need to consider the build and it's materials too. There is a lot of useful information on this here: https://www.leti.london/
Mr Punter Posted October 1, 2020 Posted October 1, 2020 On 12/09/2020 at 18:01, tonyshouse said: energy will only get more expensive Why do you think this will be the case?
