My recent re-aquaintace with the mark 1 shovel, MOT1, and Glacial Till has made me much more cautious about how deep to dig my foul drain trench.
Its not a matter of popping down to fetch red diesel any more .....
I have found these two YT videos very helpful
Osma's guidance  (at 4:05)
and this
gentle bit of mickey taking ...
How much shingle needs to be put under the drainage pipe? The guy from Osma says 100mm; is he right? I can't find any guidance that says it must be 100mm.
4 minutes ago, Russell griffiths said:
I’m putting normal diesel in the digger, breaking my heart and bank account
£60 this week already
100mm by the way.
What size you using? I got a solid 3 days graft out of a little e10 for less than 20 quid in white
This is for dumper and digger, digger probably only uses 10 litres a day, but I’ve been sat on it for the last fortnight and will be for the next couple of weeks.
Me too. But the red here was close to £1/litre unless you could find space for a 500 litre tank before the virus kicked off, so not much difference.
I am doing 100mm for the drains as in diagram 10 part b in Approved Document H
32 minutes ago, JFDIY said:
You need to befriend your local farmers, bet they'll sell you a few gallons.
yup, my friendly farmer sold me 50 litres at 55p per litre, (I did round it up a few quid as the local garage that normally sold red charges 80p per litre).
The gravel also makes it easier to level the bottom of the trench. I think it would be hard to keep the bottom of the trench flat enough to allow much less than 100mm.
Worth considering the pipe bedding material. Where I live pea shingle (6mm) is £25/t but graded limestone 'pipe bedding' which is basically 6-10mm clean is only 18/t. Better check with your building inspector but mine was happy with either. I'm laying around 100m of it so it does make a difference.
On 13/04/2020 at 08:43, Oz07 said:
Even better recycled crushed concrete 10mm clean where I am 10 quid a tonne
Delivered? That's Cheap
