Hi all,
my build is 165m2 single story. I'd had a few quotes for supply only with design and they are coming the following excluding VAT:
CVC Direct: £5678 (full design done). Unit itself £2023
Paul: £5200 estimate. Unit itself £2820
Local company: £5120 . Includes installation though, but not very confident on their 'design' or components.
Green Build Store: £4700 to £5200.
Enhabit: £4850  estimate (old quote, might be more now)
It seems that half the cost is the pipework. Its all a combination of steel pipework for main extract/inlet and then basically Zehnder’s ComfoFresh (PVC?) ducting or equivalent.
Does these quotes seem reasonable? It just seems expensive to me.
Thanks
Edited by gc100
Slightly smaller house, £400 for mvhr unit from ebay.  Design done by house designer, Pipework, semi rigid 75mm radial system a little over £1000 from BPC, self installed in a couple of days. Dead easy.
Thanks. Which ducting did you use?
Regarding MVHR units themselves there seems to be a massive about of variance in these. I have been looking at this unit Zehnder ComfoAir Q 350 which is not cheap at around £2800, but it seems this is the unit I'm constantly quoted for mostly and it does seem good looking at specs etc. However do I really need that kind of quality? The unit itself will be in the garage so noise is less of an issue.
Looking at one of the quotes it says I need a boost at 247m3/h which this unit seems a bit overkill.
Edited by gc100
It's a semi rigid plastic ducting, in my case two ducts in parallel to each vent.
And they all lead back to two plenum boxes next to the mvhr unit
I paid £1.5k or thereabout for the unit, then about £2k on ducting/manifolds/plenums. Self designed and installed. Up and running but only 1/3 of house actively being conditioned (other outlets plugged for the moment).
I've said it many times on here my choice of unit (vent-axia) was because I want to use it as kitchen extractor over an island hob so saved the expense of downdraft set-up. The unit I have allows a cooker mode with  upto 100% speed on extract and bypass the heat exchanger to prevent fouling.
Twin wall pretty smooth on the inside.
Total cost £1072 from BPC for all ducting, terminal vents, plenum boxes etc but not the large duct from the plenum boxes to the mvhr unit, they came from another self builder left over from his job.
BPC did not do the design, I am not sure what they would have charged if they did,
1 minute ago, nod said:
Do you guys with MVRH have UFH
Or is there no need
UFH downstairs from ASHP. No heating needed upstairs.
Thanks
While we decided against for our build The next one has no access to gas
I didn’t fancy going down the route of oil filled
So it seems a no brainier
But we do like the UFH
158m2 ground floor Even with gas it’s remarkably cheap to run
10 minutes ago, Alexphd1 said:
Also have a look at blauberg.
I used their ducting/manifolds etc. Set up a trade account online and they're nearly half the cost of most others.
Bought all my kit from BPC last October. Vent Axia unit + all ducting, plenum etc. for about £2600 for self install which I’ll be doing in the next month or so.  Extract from 3 bathrooms, WC, utility and kitchen.  Supply to study, hall, dining, living and 3 bedrooms.  About 170 sq. m over two storeys. They did the design, cost then was £100, deducted from the order.
They’re still working during the lockdown, so might be worth a call.
Or is there no need
The need for heating, underfloor or not, is not related to the need for MVHR, which is driven by airtightness.
We are very airtight Doors and windows are open all the time
Even in winter
It would be nice to have a means of cooling the house
MVHR won't help cool very much.
You need air con for that. It has been suggested that an air con chiller coil on the MVHR supply side ducting might work, but might cause condensation drop out issues in the ducting when in use.
Even in winter
If the doors and windows are open all the time then there won't be a requirement for MVHR but there will be a requirement for a lot of space heating unless you like living in a low temperature house. As @JFDIY says air con is the best way of cooling the house down.
  • 5 years later...
Or is there no need
Have both, MVHR just reduces the ventilation heat loss, fabric heat loss is still there.
1 hour ago, flanagaj said:
That’s very interesting.
I have the same, but we decided to retrofit electric heaters in our bathrooms a few years after we moved in. It wasn't like they were freezing, but stepping out of the shower onto unheated tiles wasn't very pleasant in the depths of winter. I also found that a bit more heat reduced the amount of condensation we were getting when it was cold.
If I were doing it again I'd absolutely have gone for some form of UFH in the bathrooms. Some have used electric mats under tiling to good effect.
The rest of the upstairs is fine unheated.
UFH via a heat pump in cooling mode, is working quite well. Mostly if house gets too warm from solar gain, the period to get back to normal is shorter.
You can get the same outlet temperature with a water based coil. Doesn't really change the science of the flow rate being too low to be effective. Only really way to make MVHR cool is to have everything oversized for high flow rates. Configure setback to be normal rate, normal rate to be boost, then the normal boost setting to be a super boost just for cooling. Basically have the unit run full speed for cooling, still won't be that good.
