Tin Soldier Posted October 24, 2019 Share Posted October 24, 2019 (edited) New build large extension - completely separate drain/waste from old system until it meets well outside to go into septic tank Kitchen and bathroom have been plumbed in for months and months Kitchen has 1 waste will trap, thus no smell Bathroom has three waste points 1. toilet is plumbed in to 2. sink is almost plumbed in to 3. SVP leading to an AAV in the loft the sink has a 40mm pipe solvent welded to a reducer in a 110mm pipe, it comes upwards and out of the wall and is bunged at the end with an airtight bung. it was awaiting the wife painting the upcycled vanity unit (still bloody waiting) It was set up this way for months, no smell I put up a false wall, no smell I tiled the false wall, no smell months pass. unbearable stench seemingly coming from false wall. My thinking was one of the kids had slammed into the 40mm waste pipe broken the solvent weld, thus a small amount of gas is leaking. Last night, I punched a large hole through the wall, cut the waste pipe to sink, and replace it brand new, this morning I woke to a godawful smell again any ideas how/why this has started months after installation? my plan for tonight is to go up to loft and check on AAV, but I doubt that's it Edited October 24, 2019 by Tin Soldier Link to comment Share on other sites More sharing options...
Jeremy Harris Posted October 24, 2019 Share Posted October 24, 2019 Are all the traps full of water? We have to remember to run the tap in the bath in the second bathroom once a month or so (we don't use it) otherwise the MVHR extract in there pulls in smells from the treatment plant when the trap dries out. 1 Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 theres only two traps in the bathoom, one is the shower, which has plenty and I've run litres into, the other is the toilet, which is fully functional Like I said the sink waste doesnt have a trap, but an airtight bung in the kitchen, theres the kitchen waste trap which again is full Link to comment Share on other sites More sharing options...
Ferdinand Posted October 24, 2019 Share Posted October 24, 2019 (edited) What sort of awful smell is it - poo awful smell, stagnant drains awful smell, dead rat in the wall smell etc? Can you learn anything from the timings eg after someone has done a number 2, or had a bath or something? Are there any external factors that may affect? eg drain work next door? My first thought is if there is something coming back up one leg from another leg. Had that when we had just done my upstairs bathroom last month - because a bath running away puts more water through than a shower water was coming back up the drain of the downstairs shower and bringing gunge up into the shower tray through the drain. It also brought smells. The solution was a one way valve in the waste pipe of the downstairs shower to stop backwash. We put similar in when we added the pipework for a bath upstairs as it was all done in the very personal style of the previous selfbuilder and his belt needed some braces. And as JSH says - check traps. Ferdinand Edited October 24, 2019 by Ferdinand Link to comment Share on other sites More sharing options...
Onoff Posted October 24, 2019 Share Posted October 24, 2019 Our upstairs ensuite; the cistern overflow exits into the shower & basin waste pipe (I didn't do it). Sometimes a waft comes back up that way. My wall drain in the new downstairs bathroom has a hair trap. Both women here have hair like Cousin It. If I don't regularly (yes me) remove the face plate and clear the hair trap it starts backing up across the wet room corner. Happened recently but the hair trap was clear. The odd hair that had got through had built up on top the drain grille outside. (No holes in the grille for the pipe shoe as yet). Link to comment Share on other sites More sharing options...
SteamyTea Posted October 24, 2019 Share Posted October 24, 2019 (edited) Occasionally, a neighbour, about 100 metres from me, blocks the main sewer. This causes a back up to the 6th house where I am. The smell is very noticeable inside my house. So do you have had neighbours that are causing the problem. If so, report it to the water company, they fine the bend blocking culprits. Failing that, I find it is a hummus supper. Edited October 24, 2019 by SteamyTea Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 interesting so another question is If all the traps are full, and the pipes sealed how does the smell get out? does it force its way passed the seals in the soil pipe or? Link to comment Share on other sites More sharing options...
joe90 Posted October 24, 2019 Share Posted October 24, 2019 Faulty AAV? Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 fingers crossed Link to comment Share on other sites More sharing options...
epsilonGreedy Posted October 24, 2019 Share Posted October 24, 2019 7 hours ago, JSHarris said: Are all the traps full of water? We have to remember to run the tap in the bath in the second bathroom once a month or so (we don't use it) otherwise the MVHR extract in there pulls in smells from the treatment plant when the trap dries out. That is an interesting one, noted. Link to comment Share on other sites More sharing options...
Mr Punter Posted October 24, 2019 Share Posted October 24, 2019 I am pleased to note you blamed the kids first. Well done, that is what they are there for. Blocked drain below ground can cause issues. Lift a cover and have a look. Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 Hmmm replaced aav with a spare Question is should I be able to notice the diaphragm withing it moving at all when toilets are flushed Link to comment Share on other sites More sharing options...
Nickfromwales Posted October 24, 2019 Share Posted October 24, 2019 1 hour ago, Tin Soldier said: Hmmm replaced aav with a spare Question is should I be able to notice the diaphragm withing it moving at all when toilets are flushed You should hear it open tbh as the gurgle sound of the water flowing is open to atmosphere at the AAV when it functions. Can you block off the AAV temporarily to start a process of elimination? Last job like this ( same symptoms ) was a big juicy dead ? that got jammed in the battens behind the wallboards. The thing was dripping out of its own back end when I found it. Yuk. Smell is very similar but also distinctively rat, not crap, is easily identifiable to those who’s nose knows. ? Link to comment Share on other sites More sharing options...
Onoff Posted October 24, 2019 Share Posted October 24, 2019 8 minutes ago, Nickfromwales said: Smell is very similar but also distinctively rat, not crap, is easily identifiable to those who’s nose knows. ? I'd describe the smell when they die and rot as somewhat "meaty"... @Tin Soldier, noticed any more flies than usual, always a sign. Link to comment Share on other sites More sharing options...
ProDave Posted October 24, 2019 Share Posted October 24, 2019 The correct diagnosis would be to to do the normal air pressure test on the pipes to see if anything is leaking. Link to comment Share on other sites More sharing options...
Nickfromwales Posted October 24, 2019 Share Posted October 24, 2019 1 hour ago, ProDave said: The correct diagnosis would be to to do the normal air pressure test on the pipes to see if anything is leaking. He has a point Link to comment Share on other sites More sharing options...
Onoff Posted October 24, 2019 Share Posted October 24, 2019 2 hours ago, ProDave said: The correct diagnosis would be to to do the normal air pressure test on the pipes to see if anything is leaking. Daft question but how do you physically test for leaks at joints when testing if the pressure is dropping, logic says soapy water at the joints? Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 I can't test the svp behind the false wall without a lot of destruction ? I just can't understand how everythings Been fine for months and this week it starts stinking Link to comment Share on other sites More sharing options...
Onoff Posted October 24, 2019 Share Posted October 24, 2019 2 minutes ago, Tin Soldier said: I can't test the svp behind the false wall without a lot of destruction ? I just can't understand how everythings Been fine for months and this week it starts stinking What smell is it? Poo, rat, 10 Rillington Place type decomposition? ... Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 24, 2019 Author Share Posted October 24, 2019 Poo Link to comment Share on other sites More sharing options...
JFDIY Posted October 25, 2019 Share Posted October 25, 2019 Is there any means of positive pressure getting out, i.e is there an open stack on the system anywhere? Could be when another user on the system flushes it pushes a slug of foul air through one of your traps, you might just have the smallest trap depth in that room. Link to comment Share on other sites More sharing options...
ProDave Posted October 25, 2019 Share Posted October 25, 2019 Okay another possibility You have a dead mouse in the wall. Don't under estimate how much stench a rotting mouse corpse can make as it decomposes until you have smelled it. It might be nothing to do with the pipes at all? Link to comment Share on other sites More sharing options...
recoveringbuilder Posted October 25, 2019 Share Posted October 25, 2019 I feel for you! We had this in our last house. It wasn’t happening for the first couple of years then all of a sudden it started happening. We would have it for a few days then it would disappear for months only to return again, we tried everything, new aav, put an outside stack in , tested pipes, resealed all the pipes at the toilet pan , nothing worked, one plumber we spoke to said the under floor heating was causing it drying out the shower trap but we never did get to the bottom of it. Link to comment Share on other sites More sharing options...
SteamyTea Posted October 26, 2019 Share Posted October 26, 2019 (edited) Can you flush gallons of water down everything, talking a tonne or two, not a bucket. See if it goes away, or backs up. Maybe with some bleach to act as a marker smell. Edited October 26, 2019 by SteamyTea Link to comment Share on other sites More sharing options...
Tin Soldier Posted October 26, 2019 Author Share Posted October 26, 2019 Well I got to the bottom of it There was very little water going through the inspection chamber I basically did as above and ran gallons and gallons of water down every outlet at the same time, very little making its way out 5 mins later I heard something slowly moving down the pipe outside like a rat crawling down it, until... Well you don't want to know what it looked like, Needless to say it was massive, it was brown and it stunk.. It spewed our of the inspection chamber base broke up and was followed by a torrent of water Diagnosis Baby wipes, bits of plaster, bits of plastic all probably places there whilst pipes were open and kids could get to them I am smell free! 1 Link to comment Share on other sites More sharing options...
