epsilonGreedy Posted September 18, 2019 Share Posted September 18, 2019 (edited) The garage end of my outbuilding incorporates a brick lean-to shed 3m x 2m. This is an architectural embellishment that breaks up the shape of the main garage rectangle. The lean-to shed is accessed internally from the garage and is otherwise windowless, hence the only natural light will be via the main garage door when open. At the last minute I have decided to add a very small south facing window 1 block wide and two blocks high at eye level, think small sky light in the wall. The wall has a 100mm cavity with facing bricks. My self build neighbour suggested buying the cheapest small window from Wickes and customizing the masonry aperture to the purchased window. Cheap windows are surprisingly expensive. My Plan: Form a 450mm square hole in the wall. Create a wooden frame from 200mm x 35mm softwood using my mitre saw at 45 degrees. Fix frame with a 60mm reveal in the facing bricks to keep it out of the weather. The frame will act as a cavity closure ( no cavity insulation planned). Fit single pane of glass the old fashioned way with wooden bead and putty. What could go wrong? Edited September 19, 2019 by epsilonGreedy Link to comment Share on other sites More sharing options...
Onoff Posted September 18, 2019 Share Posted September 18, 2019 How about incorporating the glass door from a defunct washing machine? Makes a nice smugglers window...if you've a small head... 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted September 18, 2019 Share Posted September 18, 2019 Find a tame window fitter. Follow him round for a bit. Watch, learn, scavenge. Link to comment Share on other sites More sharing options...
Temp Posted September 18, 2019 Share Posted September 18, 2019 Tried eBay? uPVC £5 but collect from kent https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F113889566322 Link to comment Share on other sites More sharing options...
ProDave Posted September 18, 2019 Share Posted September 18, 2019 Oddly enough I picked up a tip from a joiner today. Go to your local double glazing window company and ask to see their "graveyard" where all the wrong size / damaged / rejected windows are stacked up. Find one about the right size and start haggling. You can sometimes get a bargain. 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 18, 2019 Share Posted September 18, 2019 That window will be under £100 why bother running around getting a piece of glass cut, then you need to paint it forever more, buy one online and get it delivered while you get on with something else. Link to comment Share on other sites More sharing options...
Stones Posted September 18, 2019 Share Posted September 18, 2019 Glass bricks? 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 18, 2019 Share Posted September 18, 2019 Just now, Stones said: Glass bricks? Now that’s a good idea, 4 or 6 bricks done. Link to comment Share on other sites More sharing options...
Stones Posted September 18, 2019 Share Posted September 18, 2019 Simple, quick, easy. Link to comment Share on other sites More sharing options...
Onoff Posted September 18, 2019 Share Posted September 18, 2019 Wine bottle window: Link to comment Share on other sites More sharing options...
Jeremy Harris Posted September 18, 2019 Share Posted September 18, 2019 I used glass bricks to make an internal, high level, window, that lets a bit of light into one of our bathrooms from the hall. Not only were they relatively cheap, but they are also pretty good at keeping noise out. They let a surprisingly large amount of light in. The window I built is four bricks wide and three bricks high. You really need to use the thin stainless steel strengthening rods in the joints, though, to give the window enough strength. Link to comment Share on other sites More sharing options...
SteamyTea Posted September 18, 2019 Share Posted September 18, 2019 Ask @pocster, he knows a thing or two about cheap glazing. 1 1 Link to comment Share on other sites More sharing options...
Pocster Posted September 19, 2019 Share Posted September 19, 2019 11 hours ago, SteamyTea said: Ask @pocster, he knows a thing or two about cheap glazing. I am indeed the man to ask ! Link to comment Share on other sites More sharing options...
epsilonGreedy Posted September 19, 2019 Author Share Posted September 19, 2019 12 hours ago, JSHarris said: I used glass bricks to make an internal, high level, window, that lets a bit of light into one of our bathrooms from the hall. Not only were they relatively cheap, but they are also pretty good at keeping noise out. They let a surprisingly large amount of light in. The window I built is four bricks wide and three bricks high. Since reading your post I have been looking at glass bricks online, previously I thought they were thick bottle-green lumps with poor light transmission. These look promising: https://glassblocksdirect.co.uk/product/clearview Four will create my porthole window for £10 though the white mortar at £21 for a full bag distorts the over call cost plus another £17 for delivery. 12 hours ago, JSHarris said: You really need to use the thin stainless steel strengthening rods in the joints, though, to give the window enough strength. My window will be about nose height in the gable wall of the brick lean-to with about 6 courses of regular facing bricks above, which raises a question about whether a lintel is required above the glass bricks in such a lightly loaded situation. Link to comment Share on other sites More sharing options...
Jeremy Harris Posted September 19, 2019 Share Posted September 19, 2019 Those look like the same make as the ones I used, except mine were conventional brick size. I found that the mortar seemed to be very like white tile adhesive, and if I had to guess I'd say it was exactly the same stuff. I also found that it was essential to use the reinforcing rods. Wickes stocked these when I was looking around for some. Link to comment Share on other sites More sharing options...
Cpd Posted September 19, 2019 Share Posted September 19, 2019 14 hours ago, ProDave said: Oddly enough I picked up a tip from a joiner today. Go to your local double glazing window company and ask to see their "graveyard" where all the wrong size / damaged / rejected windows are stacked up. Find one about the right size and start haggling. You can sometimes get a bargain. ‘Personally I think the glass brick is the way to go or as Russell says just buy a small window.... however at some point I had it in mind to build a garden room and got given about 10k worth of double glazing units for free..... they came brand new from one of the big window manufacturers, just wrong sizes or wrong orders etc and they handed them over for free to a friend who was going to make an aviary out of them but it never happened..... I feel like I could be heading in the same direction! But I will hang onto them in the hope that I get there one day. I also regularly turn down brand new units from local hardwares as I have so bloody many already ! So the moral of the story is if you want some random glass just go and ask and get them for free, they would have to pay to dump them. Link to comment Share on other sites More sharing options...
