12 minutes ago, scottishjohn said:
I am a great lover of solar thermal  and spent many many hours and days trying to devise a system to provide all the heat for  a modern  house
Your post covers two separate issues: 1) interseasonal (or nearly so) storage for space heating and 2) use of solar thermal for DHW pre-heat. Only the second is on topic for this thread so I'll address that.
14 minutes ago, scottishjohn said:
there are very few days  ALL YEAR ROUND when you cannot get 30c-40c+ if pump speed is controlled  correctly for panel area
Exactly. That's ideal for pre-heating DHW to then be topped up to the temperature it'll actually be used at by a SunAmp or whatever so a large buffer tank is not required, just one to cover a day or two's usage which won't be much different from a normal domestic DHW tank.
of course that depends how may panels or tubes -
but my 40 tube system on a sunny day would take my 300 litre tank form 30c at first light  up to 70-80c by lunch time --
so i would  not underestimate the size of tank you need
and why not let it heat your UFH ,  dhw  or sunamp if it has the output any way ?
@scottishjohn, absolutely. Using solar thermal for DHW pre-heat and also for space heating is my plan but not using the same tank for the two jobs. However, this thread is about using an ASHP with a Sunamp - my post you were originally responding to was about using the ASHP to preheat the water going into the Sunamp. I just mentioned my intention to use solar thermal in a similar way. Let's not derail the main discussion - start a separate one if you want to.
no problem
will eave it as is
On 13/09/2019 at 15:07, Jeremy Harris said:
if doing it again I'd leave out the buffer, flow switch, heat exchanger etc I installed, as it just over-complicates things for the sake of saving a few pounds a year on the hot water bill (saves less than a tenner a year I reckon).
So you’d got fully Sunamp? How would you deal with UFH and cooling?   I assume you’d retain the ASHP and feed it directly  into the UFH.
Thanks for all the contributions to this and other Sunamp threads.
It’s crunch time for me, I’m starting first fix in the New Year, so need to finalise my space heating and hot water design.  I’m come to the conclusion that one large ( suitably sized) Sunamp, charged using solar PV and off peak grid electricity is the way to go for DHW. Still not sure about Space heating! In my case I’ve fitted hundreds of metres of pipe in the slab. Do I really need the cost of an ASHP and unventilated hot water store? Maybe the Willis heater is the way to go and in summer when it’s too hot, just open the windows and purge the hot air!
What keeps you awake at night?
All the above, and much more.
Thats our plan, Sunamp, PV, offpeak elec and Willis heaters...
and firmly crossed fingers.
Has anyone got a photo, sketch, layout plan for such a set up? I only ask as I find it easier to understand rather than a written description!
I'll PM you a couple when I get 5 mins ;)
I think there are a few of us on here @Nickfromwales who are looking at the Willis solution so why not create a new topic? I've contacted a few plumbers locally who either haven't responded or who are telling me this isn't possible (what do clients know anyway?). So having a dummies guide to Willis Heating for UFH would make a good sticky on BH!
EDIT: Looks like a similar request in UFH already! Shall e continued this Willis Heating there?
Edited by oranjeboom
added willis linky
On 06/10/2019 at 04:25, Dan Feist said:
I've been talking to Sunamp about use of ASHP with their units.
While they talk about the Daikin HT heat pumps in some of their literature
Sunamp sold a guy I work with a similar set up. He has a 16kw Daikin Altherma HT single phase ASHP. It's a split system and he also uses a Sunamp for heating (standard radiators so fairly high temperature). It was working fine until they started using the heating (fairly recently) but now the ASHP stops working every day. The installer told him to switch the ASHP off and on which he did and it started working ok but seems to stop regularly, then he discovered that it seems to reset itself when he just turns the Sunamp off and on so he is thinking that it's something to do with that and he's having to do that daily at present. The MCS installer is supposed to be coming out to look at it.
Point them at this
https://www.heatraesadia.com/products/heating-and-ventilation/electric-flow-boilers/amptec
Afaict it's a Willis heater in a fancy box with a shiny name on the outside.
The installation instructions has some example schematics that may (or may not) be a useful starting point for questions here too. It specifically gives UFH as one use case.
Bit of a price difference though! But yeah, an average plumber may have more interest in fitting this than a willis heater which just draws a blank face when I mention it.
Yes i got one of them, had it for years for another job -- could be used in new house and then see if i really need an ashp ,assuming by that time battry storage has dropped in price -loads of space fro solar pv
Edited by scottishjohn
4 hours ago, joth said:
Point them at this
yep ... and the U401 which is their UFH version is a cool £499...
A 3Kw Willis is ... £49.99?
It's a difficult choice....
6 hours ago, joth said:
Point them at this
I fitted one of those.  It is made to "look" like a normal boiler. It has some relays and controls and turns on the heaters (10KW in the case of the one I fitted) when it gets a "call for heat" and senses the water is flowing (pump on)
