Ferdinand
    41
  1. How do they make it 10% when my Heat Recovery Fan claims to recover 70-80%? Welcome, Tarik. If it was Manchester, presumably the stories are mainly about rain and football. 😎 I have educated myself and I am told that the new pronunciation for the name of Turkey is (phonetically in English) "Turkier" or "Turkia". I tried to make it Turk-e-i (as in E-I-E-O from a couple of English songs), but was corrected quite firmly. I enjoy visiting Turkey too - I sometimes fly to Istanbul and stay at a high end hotel for transit elsewhere. But last time I went to the City itself and took a folding bike with me on the aeroplane. The bike worked very well, apart from the tramlines. I came off the bike and an enterprising gent rescued me, then tried to sell me a carpet - an interesting experience. Very enjoyable overall. Ferdinand
  2. I am thinking about using a pressure washer to let me work at a reasonable height. One of the applications is to clean my solar panels, which are now quite "lichened" after a few years - partly because some are modestly tree-compromised. This will require me to work from a flat roof over the garage, where the roof plane begins. The top of the array of panels is about 5.5m vertically high above the garage roof. I have a reasonably high end Nilfisk Excellent E160.1 model, which has a 10m hose so may well be suitable even sitting on the ground to avoid taking weight up even a short ladder to the flat roof, and can be fed either from a hose, or a barrel (ie wheelie bin) of water. An alternative is to look at a portable item. I am a Makita setup, and they have a good portable item which costs £400 (!) without batteries. The alternative portable would be something cheap and cheerful. I'm after experience as to what other people have done. Thanks for any comment. Ferdinand
  3. There are a lot of strange solar proposals around in response to the increased electric prices, quite often puffed by bits of media as Gee-Wizz products. The ones I have seen are usually less than half efficient than basic panels. Isn't this one similar?
  4. A demolish / newbuild can quite often be a better idea than an extensive / expensive renovation. Have you considered both, and are you beyond the point of no return?
  5. Remember that you will need an accessible entrance - though that need not be at this particular entrance.
  6. My old installer closed down the solar side entirely, and now does scaffolding hire !
  7. Morning, @richo106. Floor AIUI there are two things here. 1 - Insulation value, where the differences between Jabfloor EPS70 and EPS100 are marginal - 0.038 vs 0.036 u-values respectively. On the U-value, you will need something like 350mm of EPS to give you the same insulation value as your 200mm of PIR. EPS100 would save you ~25mm on the thickness required afaics. Significant? 2 - Compression strength, where it needs to take whatever weight you are putting on it without collapse. According to the datasheet either seems applicable under a domestic floor. https://www.jablite.co.uk/wp-content/uploads/2016/12/Jabfloor-70-100-150-200-250-below-slab-Technical-Data-Sheet.pdf Wall I think you may be constrained by building regs here depending on what type of blocks you are using for teh inner leaf and what extra you have inside the inner leaf. EPS may only barely meet the required standard depending on That may force you down the PIR route. TBH I would plump for the one that insulates better, given what has happened to heating costs. Then worry about any of the house which is less insulated. Ferdinand
  8. Yay. Someone doing my homework !
  9. But you get sloe gin and puncture wounds ! @Adam2, go for varieties of pyracantha (firethorn) with several colours of berries, and plant them spread out along nearish the bottom, then let them develop into a thicket if you have space, and birds will love it.
  10. Holly? Especially Ilex Ferox. Though a huge 10ft high pile of pyracantha sounds good. Perhaps Blackthorn.
  11. Listen to yourself not the BCO on the insulation, needless to say 🙂 .
  12. There's a lot in that, and that may be the easy way out - keep it on site. The are umpteen threads on BH about composting loos. Here's a fairly comprehensive one a couple of years old: I love that letter, @Temp - 25 pages including 13 Appendices.
  13. Welcome.
  14. I can't call it; I'd love to see a piece by a senior planning professional. Boiling it down to the core after my brief excursion into language, and trying to provide a useful summary: Is this a leftover from all the EU law being read across into UK law in the European Union (Withdrawal) Act 2018 (I think it is that one; there are about 3 or 4 similar acts.) Is it English Nature being too precautionary? Are LPAs listening to English Nature too much? The LPA response has been to ignore it if deemed n/a, stop apps if they think a big issue, or require a "prove Nitrate Neutrality" report. Possible responses are: Keep it all onsite (eg etc), as many of us do. Develop high nitrate ground, which makes a net loss easier to demonstrate. Appeal, perhaps for non-determination of they try to freeze it. Argue that the nitrate issue should trigger draining to the main sewer "last resort". Argue that a single-self build is de minimis. I am sure there are other options. F
  15. I do not think I am up to a scrambled hegg from a hostrich ...
  16. It's very straightforward - Hs are at risk of going extinct, and need to be saved. Around here, most people drop them - 'ouse, 'Arry, 'effelump, 'artlepool. Except, ironically, from the name of the letter: HAITCH. Incidentally, that should be Hinspector Morse. So we need to rescue them and attach to suitable habitats, such as the word 'egg'. Which now becomes HEGG. Simple, and you will earn the undying appreciation of Natural England, Scrabble Users - an H worth 8 points because of rarity is unconscionable, and the Ghost of my late mother. As it happens, my tea tonight is a hostrich steak.
  17. I scatter crushed heggshells on the top of hosta-pots to keep slugs away. If you need a big batch, then buy a lot of heggs (perhaps 2 or 3 trays), and lightly mix them together in say 3s (to make an omelette or scrambled heggs) for the freezer. Then your heggs store in a much smaller place - perhaps 1.5-2 dozen in a margarine pot - and you get pre-portioned heggs and less clutter. Works for me.
  18. Catching up. If you put a Feng Shoooey chap in that lot, he would come back like one of these lost Japanese Officers from WW2 in the jungle in 3 decades' time.
  19. Banned as of 1 April 2022, I'm afraid. https://www.countryliving.com/uk/homes-interiors/gardens/a39606324/slug-pellets-banned-uk/
  20. Point of Order. Eggs has an H at the start. HEGGS.
  21. There's a decent piece on this over at Planning Resource from late 2019: https://www.planningresource.co.uk/article/1665502/algae-blocking-10000-planned-homes I don't understand why in 2019/2022 English Nature are taking such heavy notice of a 2018 ECJ ruling centering on a legal action about a development in the Netherlands from even further back. Does the ECJ have competence over our planning law? Is this classic bureaucrat gold-plating? Having said that, there look to be enough alternate routes within planning law for most self-builders to find a way, especially as so many of us process our .. er .. soot on site. Unless LAs are actually saying "refuse to accept PA", in which case it is an interesting little conundrum. Nor am I sure about whether SPAs actually apply here - I have mainly met them wrt to birds such as Dartford Warblers. A Chinese Puzzle. I think the Housing Minister needs to put English Nature back in their toybox, and come up with some balanced ideas. Ferdinand
  22. Can't you FOI it, as surely it is a matter of public record?
  23. The size of what you have outline for is another important factor.
  24. On the other hand there is a tradeoff of money vs risk. If you sell it AMM and your buyer thinks that x, y or z may take extra money to sort, then they will assume the max and take that off their potential offer. Ones that could scare people are around access, what is underground (eg insecure soil, mineshafts etc), possibly trees which may get a TPO and are key to the development, contamination, cost of power or sewerage. You need to consider each, and what it will cost you to remove that risk, then perhaps select the ones that you consider will benefit your sale price by significantly more than the cost of removing / reducing the risk. Also if you have more informal information such as proof of usage for 50 years (so unlikely to be contaminated), then that can be of benefit. As an example, when my family sold a bruiser of a listed dwelling where "listed" would scare people, we had a full structural survey done for £500 as part of our sales package. The last plot I did I had at outline AMM except for the Entrance.
