Is there a Rule of Thumb for estimating the ....
Ferdinand replied to ToughButterCup's topic in Electrics - Other
The last one I did I drew all the bits on the walls, took the lecky round for 20 minutes, and he gave me a list of what to buy two days later! This is amenable to a bottom up estimate imo, which should be quite quick to do. More seriously, I would do this by reviewing my plan, perhaps with a highlighter, and break it down into sub elements that I can do by inspection or guestimate in my head, then add a bit extra, then either accepting that I would use more cable later (piggery?), or buying the extra reel from somewhere I knew I could take it back 2 weeks later - as you would with tiles. It is nice that cable lasts for years and years. Or deconstruct it in my head - eg for a 10m x 10m house with a 3 room x 2 room plan, I know that a ring main round them all will be 4 full runs one way and 6 the other way from counting walls basically regardless of room shape and qty of sockets except for eg wiggly walls, which is 100m per floor plus twiddles for back to the CU, 3m per time to go upstairs, 300mm per double for the loopout, 1m per double on the worktop in the kitchen, rooms with no power etc. I would write each sub element I can do in my head in a list, and then add them up and do a cross check of some sort. Then repeat for each type of cable. That is how I do skirtings - how many front to back inside walls + side to side for overall dimensions for an estimate, then match the mix against lengths of individual walls eg 3.6 4.2 4.4 to minimise small offcuts (add this list back up to check the numbers are about the same), add a couple of lengths to avoid an extra delivery cost which will usually cost more for skirtings due to minimum order for free delivery, and match list 2 against price lists to give me the lowest total. Slight watch needed eg for outside corners which can require extra 100mm or so of skirting to be safe if there are several. I would say any I miss out is because of things I have forgotten, rather than things I have miss-estimated as I know my room sizes and distances quite well. The highlghter on the plan is one way to avoid missing things. F -
Wall u value is probably 0.25. Rockwool in the cavity, thermalite inner. F
Rust Removal Adventures: Electrolysis, Acid etc
Ferdinand replied to Onoff's topic in Tools & Equipment
So you are presumably in the market for Buildhub zinc roof offcuts ... -
Where would you put one sqm of extra space?
Ferdinand replied to Ferdinand's topic in New House & Self Build Design
Clearly, as ever, you all need to consort with Hermione. "Detritus exeat. Statim." -
Cheers. Splitter it is then. Unfortunately my tap is in the wall, and I don't even have one at the front.
Our family's last Ford was a Cortina Mk III L reg, and that *didn't* handle well. Which was why the next one was a Mk I Fiesta15 years later when I was desperate, bright yellow and known as Felicity by its previous owner. Sort of car that Florence from the Magic Roundabout might have, Though to be fair a Ford Cortina was not much competition for NSU RO80s, which followed it. When it was stolen they bailed within half a mile. F -
Getting to grips. I think I am missing 1 - An extra outside tap to dedicate to the drip system, or splitter. 2 - A converter for normal hose to 6mm, to enable a direct water buttonnection. F
I am getting a prehistoric Arthur Dent feeling about this. Confirmed by yesterday’s Cricket. I also have a couple of pieces I made as part of my EP-something, including a measure-twice-reminder toolbox with the handles welded onto the wrong end of the sheet of metal that became the lid , so every so often you get a reminder not to make that mistake again when it barks the knuckles. -
Brick and block. Inside the cavity insulation is block. Inside the house is some studwork, some block. F
Up early to work whilst it is a bit cooler, and cool the house by a few degrees for breakfast time, and I am wondering about purge ventilation. Hoping to drop the temp by 3-4 degrees from the 27C it was mainly at last evening. Is there (or has there been) any useful work on the amount of open window needed to cool a house down, or rules of thumb? This morning I have about 200mm x 600mm x 4 area (=.48 sqm) of open skylight (ie 600mm centre hinged open 200mm) upstairs, and a conservatory door open downstairs (=1.5 sqm ish), and it is going to have a noticeable effect. A couple of top windows would not be sufficient. It depends on the ΔT between the inside temperature and the outside temperature, and also the thermal characteristics and size of the house and the materials, decrement delay, thermal emissivity etc, time that it is open etc. Is anyone aware of anything? I am thinking of something as simple as the building regs rules about window area vs floor area for adequate light etc. My 'single data point guestimate' says 0.5-1 sqm of ventilation opening aperture per 100sqm of average storey floor area size should be enough. Probably. Cheers Ferdinand
Why? Are there not some lamp posts that need counting, or some baked beans that need eating with a cocktail stick, or something? Perhaps I will never understand.. -
An alternative would be Bifolds with a leaf size of say 330mm. With appropriate adjustments to the stud ... say a bookcase each side of the opening in the sitting area. F
Get a mixer, even if you eBay it afterwards imo. Mixing that amount of concrete by hand will be a learning experience.
Adapting a House for People who are Frail, Elderly or Disabled
Ferdinand commented on Ferdinand's blog entry in God is in the Details
Ok Problem fix. Half used soap falls through wire hangover soap dish. Solution is new kitchen scourer cut to size. if I were being posh, I would use one of the samples of walk on shower non slip matting I have. -
Exempt under critique and review. ?
Vicissitudes of life. My Claber kit, being examined, went in about 15 seconds from the previous “not interested” to “Bwahahah ! Mine !” Pah. Need now to order some more bits for the management. It is like cats and a bag of crisps. Have been informed that a water butt and a watering can are entirely adequate for my bit of the garden. F
Tempted to say clear something so you can monitor. Do Osmo do one?
Possibly not quite the terminology intended ?. It is about understanding different ways of modelling similar things. However people have tried, and here is a recent one with an SS to which many variations of build cost are included by quite a few people. May be useful to build on this.
May be worth the mixer. Not expensive ... around 300 for a Baby Belle type, and save a helluva lot of work / time. And you get decent quality concrete / cement. Ferdinand
Combined material orders / Purchase power of The Buildhub.
Ferdinand replied to Patrick's topic in Building Materials
This is an interesting one, with a number of difficulties. There have been one or maybe two occasions on which this has worked on BH. The biggest issue is perhaps that we are a herd of cats spread out in time and space. My comments 1 - I reckon BH could perhaps have groups of size 5 - 30. That is too small to work by mass-bludgeon. Instead we need to supply a notable boost and/or other benefits ie treat them as our customer too. 2 - Any group buy needs to offer savings enough to cover the work of doing it, and to out compete what any individual can achieve by surfin' and lookin' . BH supply side is mostly about more appropriate products, cheaper individual sources for the same thing or alternatives who do not price gouge. This needs to be better than that for the cases where it is used. 3 - Effectively we need to find things where we can help the business take out cost from *their* process, add very little extra (ie manage there being 20 customers), and perhaps us do things they would normally do. 4 - Perhaps the group within BH (or an audience segment we could develop) would be around those who are slightly risk-averse ie not those of us who are wheeler-dealers. May be custom or PM-ing types rather than those of us who start with a tree and a quarry and a computer and do it all ourselves. 5 - We need suppliers who will play ball. 6 - We need suppliers where the product is standard, or BH experience suggests the supplier is reliable. 7 - We perhaps need to think in terms of other than money - eg making real slates affordable rather than relying on a Chinese import. One might be stabilising cost and reducing risk in markets which are volatile in their pricing. 3G or kitchens? 8 - What is there that is out of reach for most of us, but would come into range for a good deal? Quite a challenge. Think we need to focus on particular things within the self-build process. Which brings us to: eg Kingspan are not going to give us 30-40% off insulation by buying orders for even 50 houses. It would need to be a big reduction because you can get nearly that much off by just shopping around, and for say Kingspan we would need to put together a regional-developer sized long term order, and some way to make it like dealing with a very few customers. The counterparty risk for KS on a big enough order would negate the benefit. So I have this as my guide as to where this might work: 1 - Look for products or services where we can take cost out of *their* process, or be significant to their business. 2 - Suggests places where the cost of customer acquisition is high, the value / margin is high, the process is complex (and BHers - whilst being awkwards sods - perhaps know more than average so can save there), or a smallish group will add a significant chunk to their business. 3 - Things where a knowledgeable customers may be a help not a hindrance. 4 - Smallish suppliers where say 25 orders at once or 25 orders spread out over 6-18 months would be beneficial. Are there semi-craft businesses wanting a bit more turnover? 5 - Look specifically for win-wins. 6 - We need a mechanism to prove that BHers are BHers, so they are getting a known customer. 7 - High value / small size. Also well-defined so we avoid rejection risks. For me this is saying "not commodities" are the lowest hanging fruit. So where does that leave us for areas that may be amenable? My immediate thoughts are double glazing, front doors, some services eg soil testing, small suppliers or those with innovative products, product trials / research exercises, maybe house shells eg MBC or Scotframe, "luxuries" some of us want eg Sageglass, importers who could get a bigger wagon, smaller suppliers, helping create a simple and durable new House Management system, AliG swimming pools, unusual roofs or high quality rainwater goods? Plus windfall opportunities eg job lots of things. That probably needs the prices to be 10-20% of retail or less. Current example of this might be these. We may perhaps trigger some to offer "Buildhub versions" of their product or service. Think this will need to be an action-learning thing, as a route to create a template as to how to do it. Ferdinand -
Is that not a game that anyone can play with any country? Though I would probably say that the UK is perhaps very eclectic in diet, even by Western European standards, if we manage to avoid the attentions of some of our aspirational militant beef banners. For Germany perhaps starting with the real brick-like black bread, or some of the more distinctive offal dishes, or the Germoline Pink Herring Salad. Horse, for example, is delicious and still I think common in France but unpopular here - and that is mainly a matter of fashion / prejudice. Put a hunk of horse in the fridge in a student house, especially say a named variety such as Dartmoor Pony, and it may have interesting results. (Apparently Asian supermarkets in Gernmany are the place for teabags). Ferdinand
A weekend thought about design ideas. Given an extra 1 sqm of space, where would you put it in your house for most benefit? Either the current house, or the previous house. I am exploring opinions on which constraints are most beneficial to release very slightly. I have three answers: 1 - To make a small hob a big hob with a bit of extra space at the side. 2 - Inside the shower, to make a shower cubicle into a walk-in shower. 3 - Into the staircase to change the angle from 42 degres to 37 degrees. The first two are spaces where we spend a lot of time in a small space, so the extra benefit is perceived often. The third is again making something we use multiple times a day feel more relaxed. Any other ideas? Ferdinand
@Onoff is a One-off. Kyrie eleison . (My iPad cannot even get liturgical Greek right without mangling it. Lord, have mercy ... since no one asked.)
I'm not dealing with the "thick northern racist" thing, through I think that is perhaps an underlying cultural perception for some at the BBC - see for example the 'personal' twitter feeds of some presenters and staff. The Guardian has no external regulator, and would need a team of dozens just to keep track on the pratfalls imo. It has cost them their reputation. Now, on the BBC being held to account - imo they are tenacious in refusing to correct when challenged, and get a large number of things wrong. For example, you remember this graph from the Euro Election months ago, on the BBC - where they got a 'majority for remain' by pretending that the Tories were not pro-Brexit. From this page (now removed): https://www.bbc.co.uk/news/uk-politics-48403131 To hold them to account for this took three rounds of complaints, and a threat to go to OFCOM, before they switched from dead-bat tactics to admitting an editorial "misjudgement". And this for what they finally claim is a minor mistake. The history is here: There was another one iirc last week where the BBC extensively reported on "the need to stop eating beef" as a prioirity to stop climate change, entirely out of context of the actual international report which also included many other things as equally, or more, significant. No time to round that up now. This concerns me as they are the UK's media monopolist, with around a 40% share. They are just not very good at news istm, and refuse to be held properly to account short of extreme efforts. Not good enough for a tax funded setup. Ferdinand
Getting old and bathroom grab handles:
Ferdinand replied to ToughButterCup's topic in Bathrooms, Ensuites & Wetrooms
Imo mainly by being realistic and talking. This is largely a bit of a self-feedback screed from mine, but touches on the q. 1 - You do not know completely what you will need, in the main. (In your case, you can perhaps predict eg some aspects of hand-grip - or lack of - to design for, just as I can predict possible ultimate blindness, preceded by eye conditions, and maybe an amputationor two from my Type I diabetes). I would argue that preparations now need a bit more flexibility than 'strong points for grab handles' - say to allow for different heights etc. You may have this covered. 2 - You also need to cater for other users. eg I am now more than a foot taller than mum, who has shrunk by nearly 6 inches over 15 years as her back has collapsed after a career as a physio and a hobby maintaining a 2 acre garden for 40 years. We are used to this in our kitchens (eg no wall units iirc from one of our BH 'one and a half' couples). But it also applies in spades to things like shower seats and steadying rails; if you put he seat at the height for a taller person, the shorter person may have no purchase on the shower tray with their feet. OTOH a relation who is sometimes here has just had an early hip replacement, and is 15-18 stone. So my downstairs shower seat needs to cater for the larger person "plonking" onto it, because the consequences of an injury for someone already more vulnerable are unthinkable. And so it has 100mm bfo screws into breeze blocks. 3 - Aesthetics vs the best safety possible. Ultimately imo it must surely be function over form, but you can be creative. I speculated about chrome handrails, and my fitter pointed out quite bluntly the potential extra likelihood of slips, and the devastating potential impact on someone in her 80s of say a fall in the shower, or a trip over a door threshold onto porcelain tiles. Bye bye chrome rails except where they are "lean on" only. It may be that be as younger older people you can get away with a different compromise first time around. 4 - What do you get if you cross a growing-older person with a shower cubicle? Bloody great screw holes all over your multipanel. Once you have put grabrails and things in, your nice pristine shower will be a complete mess should you ever move them. I have largish tiles, and no fewer than 12 of them now have almost 30 screwholes drilled for adaptations. What happens if it changes? Will you gut it and start again, or have you a strategy planned for repairs? Being strictly practical, I have the advantage here that my older person has already gone beyond incidental adaptations, so I know that the next stage is likely to be residential care and probably will not have to move it all around again. Ideas for Flexibility? A - One thing that has been manageable but not thought about, is that currently we are sharing a shower due to the other one not being refurbished yet. And requirements are very different. Mum needs the shower head at my belly-button height to match the seat, which would make it annoying to move around every day. Fortunately it is a dual mode rainfall / shower head thing, so it is OK. You will need the shower head to wash your feet when you stiffen up. B - Take time thinking, which you do anyway. We spent a couple of hours in the shower room talking about grab rails and other things, and working it out afterwards. It has to be done sitting there. The closed loo was a good convenient guide to height for us. C - Places where most force will be needed are where you need the best grips. These will be ribbed plastic, but for aesthetics knurled stainless, rubber sleeves, or rubber inserts can be OK. The latter three are probably better for 'first time around'. Careful positioning really matters. Inside our front door I have installed an oak handrail to match the banisters as it is just a 'hang on whilst opening the door' thing. For aesthetics such could be part of a built-in umbrella stand, for example. Or a walking stick stand, of which I am suffering a plague like Egypt. How can one have 6 walking sticks, and they are all always somewhere else? Ditto mobility equipment (Sholley, Skimmer, Zimmer, Chair .. Wheelchair, Imo mainly by being realistic and talking. This is largely a bit of a self-feedback screed from mine, but touches on the q. 1 - You do not know completely what you will need, in the main. (In your case, you can perhaps predict eg some aspects of hand-grip - or lack of - to design for, just as I can predict possible ultimate blindness, preceded by eye conditions, and maybe an amputationor two from my Type I diabetes). I would argue that preparations now need a bit more flexibility than 'strong points for grab handles' - say to allow for different heights etc. You may have this covered. 2 - You also need to cater for other users. eg I am now more than a foot taller than mum, who has shrunk by nearly 6 inches over 15 years as her back has collapsed after a career as a physio and a hobby maintaining a 2 acre garden for 40 years. We are used to this in our kitchens (eg no wall units iirc from one of our BH 'one and a half' couples). But it also applies in spades to things like shower seats and steadying rails; if you put he seat at the height for a taller person, the shorter person may have no purchase on the shower tray with their feet. OTOH a relation who is sometimes here has just had an early hip replacement, and is 15-18 stone. So my downstairs shower seat needs to cater for the larger person "plonking" onto it, because the consequences of an injury for someone already more vulnerable are unthinkable. And so it has 100mm bfo screws into breeze blocks. 3 - Aesthetics vs the best safety possible. Ultimately imo it must surely be function over form, but you can be creative. I speculated about chrome handrails, and my fitter pointed out quite bluntly the potential extra likelihood of slips, and the devastating potential impact on someone in her 80s of say a fall in the shower, or a trip over a door threshold onto porcelain tiles. Bye bye chrome rails except where they are "lean on" only. It may be that be as younger older people you can get away with a different compromise first time around. 4 - What do you get if you cross a growing-older person with a shower cubicle? Bloody great screw holes all over your multipanel. Once you have put grabrails and things in, your nice pristine shower will be a complete mess should you ever move them. I have largish tiles, and no fewer than 12 of them now have almost 30 screwholes drilled for adaptations. What happens if it changes? Will you gut it and start again, or have you a strategy planned for repairs? Being strictly practical, I have the advantage here that my older person has already gone beyond incidental adaptations, so I know that the next stage is likely to be residential care and probably will not have to move it all around again. Ideas for Flexibility? A - One thing that has been manageable but not thought about, is that currently we are sharing a shower due to the other one not being refurbished yet. And requirements are very different. Mum needs the shower head at my belly-button height to match the seat, which would make it annoying to move around every day. Fortunately it is a dual mode rainfall / shower head thing, so it is OK. You will need the shower head to wash your feet when you stiffen up. B - Take time thinking, which you do anyway. We spent a couple of hours in the shower room talking about grab rails and other things, and working it out afterwards. It has to be done sitting there. The closed loo was a good convenient guide to height for us. C - Places where most force will be needed are where you need the best grips. These will be ribbed plastic, but for aesthetics knurled stainless, rubber sleeves, or rubber inserts can be OK. The latter three are probably better for 'first time around'. Careful positioning really matters. Inside our front door I have installed an oak handrail to match the banisters as it is just a 'hang on whilst opening the door' thing. For aesthetics such could be part of a built-in umbrella stand, for example. Or a walking stick stand, of which I am suffering a plague like Egypt. How can one have 6 walking sticks, and they are all always somewhere else? Ditto mobility equipment (Sholley, Skimmer, Zimmer, Chair .. Wheelchair, Walker, Self ... like firemen in Trumpton); nearly needs an extra garage. D - Think rails not just handles. And whether they will need to take full bodyweight or just steadying. I would suggest two tall rails either side of the shower apparatus is a good idea and unobtrusive - perhaps textured stainless for now, and you can add a very grippy sleeve when needed. E - Occupational therapists and eg Age UK will offer excellent advice, as may the Council. We had a free visit. Prob would not get priority, but it would probably help them too to think about possibilities in custom builds. F - Ultimately you will need to think about moving around the whole house comfortably, but that is a different can of worms. G - Standalone stools can be OK in the shower eg for putting feet on to wash - say from bamboo or other material. May be a good compromise. H - I have an inkling that flexible handles as seen used by straphangers on the tube may be an interesting discreet interim idea, or leather versions thereof, or even rope. Perhaps not for showers. Have not seen this, nor tested it. Loops to tension against on the wrist can be better than things that have to be gripped with fingers. Just thoughts. There is quite a lot of this touched on in my accessible bathroom stuff, and a list of links here. Ferdinand
