Tom
Everything posted by Tom
...and similar to the campaign to stop photoshopping in adverts/social media and the effect this has on adolescent mental health and the pressure to achieve the unachievable, perhaps there needs to be a similar ban on building mags/Grand designs for the sake of the mental health of middle aged men!
I'm beginning to get annoyed by imperfections, and we haven't even started our build yet! Could we have unrealistic expectations? You see all of these amazing looking places in magazines - all clean lines and perfect junctions, but is that achievable in the real world? We see selected images of these places, sometimes perhaps photoshopped, and certainly never see the bits that aren't quite so perfect. Not saying we should put up with substandard work, but if our goals are unachievable can we ever win?
Interestingly Stephen, we want shadow gaps with our concrete floor but our architect is warning against. He's worried that any irregularity/wavyness in the floor will be too easy to see with unforgiving shadow gaps. We're planning a power floated finish rather than polished. Are you happy you will be able to achieve a crisp finish - and if so can you share how?!
- 39 replies
- shadow
- shadow gap
MVHR and vaulted ceilings
Tom replied to Tom's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Our roof structure won't be exposed, but if the supply vents don't have to be high up - and theoretically can even be in the walls - then that simplifies things a bit. The extract in the kitchen I'm guessing needs to be near the apex though. -
Trying to get to grips with the MVHR design for our build. We have a large open-plan living area approx 18m x 9m with a vaulted ceiling - about 6m at the apex. A few of the other rooms (snug and master bedroom) will have even higher vaulted ceilings by the looks of it. Where should we position vents for the MVHR? As high as possible? Interested to see how others have addressed this, any pictures of how this can look would be greatly appreciated. Cheers all
Yep, barns untouched from initial part q application. Thanks all for your responses. I have contacted the LPA and hopefully they'll give the definitive answer soon. Will report back...
3 years I believe
Thanks Jimbo, that's what I thought as essentially they are PD rights. However, the planning approval states "for replacement of part Q approval" does that mean that from the date of the successful planning application there is no longer any part Q approval, or only if the planning permission is exercised and the structure built?
Quick question: if part Q change of use of a barn under permitted development has been confirmed, and I subsequently get full planning permission to completely knock down and rebuild, do I still have the PD rights to procede with the part Q conversion and ignore the planning permission?
...speaking of which, Jeremy Harris has been incommunicado for several months. Is he OK?
The Biodisc is upsold due to the extra revenue Kinspan/Klargester get from the repair of them - avoid like the plague *told this by an ex-Klargester rep
If you had to rebuild it I think the part q would no longer be valid - as structural works would have been carried out. I think you would need to insure to cover your financial losses if this happened.
Thanks Will, the ground is half made-up as the site was originally leveled for the barns by just scooping out of the hillside - I think this is why the SE has been cautious re the use of an insulated raft. One corner of what's there now is happily slipping down the hill as it is! I'm thinking that with strip foundations and the first few courses of ICF essentially forming a retaining wall this will allow us to properly compact the oversite and make a stable base for a groundbearing slab. Still, no great shakes if it's suspended though I suppose. Does any one know what the U value of marmox thermoblock is? On their site they state the thermal conductivity as 0.047W/mK - so am i right in thinking the U value would be, say for a 200mm block, = be 0.047 / 0.2 = 0.235? Not too bad I suppose. If we use the slab suspended on the perimeter like this I suppose we can use insulation under the rest that has a better U value than could be achieved with eg EPS 300?
So, our build is at the SE/detailed drawing stage. Our plan is to have a warm concrete slab and have the powerfloated finish as the final surface. Our SE has detailed a ring of marmox thermoblock around the perimeter and at intervals running across the slab on footings (the slab will be about 18x9m in total). I understand this is what makes it "suspended" - as it is essentially supported by the thermoblock strips and the insulation inbetween is not actually loadbearing. Does this make sense? Any reason why we can't just have 200mm of insulation under the entire slab and this be the loadbearing element, without having to introduce this marmox stuff? This is what happens with an insulated raft after all. We are having strip foundations and probably going for Nudura, so the insulation could directly abut the Nudura block and prevent cold bridging. Has any one any experience of strip foundations+ICF+warm concrete slab? Thanks all!
Hadn't thought of that... Just looked it up and agricultural buildings are exempt, no notice needed. Most definitely. Also need to hook up a static caravan at some stage...
Quick question if I may: planning permission granted, cosmic, conditions only apply if I go above slab level, alrighteythen, not in a CIL area, back of the net. Can I just crack on - or do I need to tell someone that I'm starting? By starting, I mean getting going with demolishing the existing barns and clearing the site.
Agree, looks fantastic. Whereabouts in S Devon are you James? We're about to embark on a self-build in the Totnes area.
I was wondering the same. I was looking at a thread the other day and looked like a load of his posts had been removed.
Good luck! Have a look on the planning portal and find similar successful applications near you, then follow their lead. I wrote the D+A statement myself and did all the paperwork - took a few hours total and was very simple TBH. We'd employed a planning consultant for the part Q originally and was amazed at how little work they actually did, so was keen to go it alone. Cheaper too!
Hi Sam - we're in south Devon.
No, open countryside.
It was pretty straight forward actually. The hard bit was getting the Part Q change of use to start with, but once you have changed the use to residential you are essentially applying for a replacement dwelling, which seems to be looked on relatively favourably. There is a Court of Appeal precedent (Mansell v Tonbridge and Malling BC [2017] EWCA Civ 1314) which essentially allows for the Part Q permission to be used as a fallback i.e you don't have actually had to have done the building work to convert to a house before wanting to replace, just having the option is enough. With this clear precedent, it seems the planners are concerned with whether the replacement dwelling is an "improvement" over the original Part Q conversion - and this is relatively easy to argue: fabric-first approach, improved air-tightness and insulation, sustainability etc etc We were not asking for anything radically different (in appearance) to what we could have done under the Part Q, but it will allow us to use ICF etc and will (hopefully) solve a lot of headaches. There are examples near us of quite radically different schemes that were given full planning though, so anything is theoretically possible, within limits. If any one is planning to go down the same route as us more than happy to help further if I can!
What do you mean? More than happy to go through specifics if that is what you're after
Got the very welcome news this week that we have been granted full planning permission on our Part Q barn - so we'll be able to demolish/rebuild rather than "convert" and have to deal with all the faff that that entails. Had a zoom meeting with the architect a few days ago so it seems like the wheels are very (very) slightly beginning to turn on this jugganaut. Looking forward to putting some of the last 2+ years of reading on this site in to actual practice! First decision to make: what level of involvement am I planning? This will dictate to what degree of detail the architect produced the drawings. I'm thinking main contractor to water-tight stage, and then I'll sub-contract myself the rest of it. Planning an ICF build with insulated slab/raft. Any pitfalls with this approach?
Restoring or converting?
