Tom
Everything posted by Tom
  1. I'm planning on using tung oil - you?
  2. We're planning on using this - reuse the cladding boards already on one if the barns and char them ourselves. The end result, if diy, is going to be quite user-dependent I suppose, and definitely less forgiving than paint. But get it right and I think the charred wood is supposed to be far longer lasting.
  3. tank connector?? https://www.diy.com/departments/floplast-push-fit-straight-waste-tank-connector-dia-40mm/152672_BQ.prd
  4. Thanks all. I'll make sure the sparks is happy with everything.
  5. So we're moving our consumer unit etc out of one of the barns that we're dismantling ready for our build, and at the same time will put in a new run of armoured cable to supply the caravan. I have an electrician coming to connect it all up, but I will be putting the cable in and want to get all the sockets etc that I need. I'm trying to find the right sort of hook-up socket for the caravan that I can fix to a wooden stake outside. Would this do?: https://www.toolstation.com/industrial-socket-ip67/p31599 Ideally I'd like a weather proof socket next to it to so that the builders can plug in stuff that they might need, but can't find an all-in-one unit. Is IP67 sufficient? Thanks all.
  6. Right, a big thankyou to all that have given advice, big thumbs up to ProDave and Onoff. I managed to isolate the fault by splitting the ring in to smaller sections and have bypassed this with a new length of twin and earth. After discussion with Onoff looks like I could have just left it as is and in essence used the split ring main as two radial circuits, but would have needed a few new MCB's so that the rating of the wire didn't exceed the rating of the existing MCB. Anyway, running the wire was a simpler solution in the end, so all working again now. Thanks everyone. To anyone in a similar situation and testing for a neutral/earth fault - remove both ends of a ring main from the MCB when testing the RCD...
  7. ...but of course all that risk is factored in to any fixed price contract (to an extent), so you will be paying for it either way. Though with a fixed price you will DEFINITELY be paying for it...
  8. Good point Conor. I think splitting it up into chunks as you say would be far more sensible. I will have another think - we're meeting the builder on-site tomorrow to discuss.
  9. Agree this is a good idea, but how would this work in practice on a time+materials basis? What's to stop the builder inflating their time costs to cover for this? Is snagging only something for fixed price arrangements?
  10. Thanks onoff, have I not got a neutral/earth fault based on the tests so far, and I'm assuming there is no way to find where on the ring main this fault is?
  11. Checked all sockets and can't find anything. Unfortunately the cables run in the walls so can't check them. Just typical this happens a day after moving in, I guess must be us moving around or plugging/unplugging things must have shifted something. Is the only option now a new ring main?
  12. ok, just tested and continuity between neutral and earth (0 ohms) and no continuity between live and earth/neutral. I guess that's what we expected?
  13. Hmmm, a multimeter and one of those screwdrivers with a bulb in it and that's about it! Would it be worth investing in one of those plug-in testers https://www.toolstation.com/socket-tester/p82826 - though TBH unless there is a fault easily accessible in the socket there is no way I'm going to start pulling the walls apart, so might as well cut my losses and just run a new ring main under the caravan. I just wonder if there is something I'm overlooking though.... Absolutely nothing plugged in - so what else could it be?
  14. Good point, but I think one of the factors being that I can potentially work/labour as and when I can and bring the costs down, which I couldn't with a fixed price Is the RIBA template aimed at fixed price?
  15. The tenders were very detailed as it happened - just very expensive! They were based on the full set of drawings from the architect - one builder said he'd never seen such a comprehensive set of drawings. We didn't provide any more information than that TBH. No CIL where we are and building regs approved on drawings. We're just south of Totnes - whereabouts are you?
  16. So we hope to start our build in the next 6 weeks or so. We have had a few fixed price tenders back which are way over budget so they are a non-starter, a local builder we know has built similar and is convinced he can bring the project in for what we need, and has suggested a time+materials arrangement and we've decided to go with this. We are going to meet up again in the next few days to sort out more details etc but I'm wondering if any one has any advice on what details we need to nail down at the start? I'm thinking: - rough timeline, so we can get some idea as we go along if things are slipping, costs going up etc - payment schedule: weekly? monthly? in construction stages, foundations, walls etc? - retention of final £X% for snagging etc? - what if I'm not happy with something - some sort of agreement on rectifying without cost to myself? - site insurance - some sort of commitment on hours/week? - I don't want the build dragging on as it's being used to fill in hours around other jobs etc Is the above reasonable? What else? Thanks all
  17. So, got a replacement RCD yesterday... no change. Worth a gamble I suppose but hey ho. Worked out what the problem is though: its the ring main. What I had done when I was testing it before was only remove one side of the ring main at one time, rather than both (slaps forehead). Should have read your post more carefully Dave! So, I have completely disconnected the ring main from the first MCD and the others now work, so at least we have lights. Still stuck trying to work out why the ring main is faulty though. Nothing is plugged in so I guess it has to be an earth fault in the wiring. Why should this suddenly happen though? The ring main wiring is run through the walls of the static rather than underneath so can't get at it. I suppose I can check all the sockets for a fault there but if that draws a blank I will have to rewire a new ring main I guess and run it up through the floor to new sockets. Any other ideas?
  18. ? on a tasty FIT so definitely reusing!
  19. Thanks Dave, don't worry, I'm more than aware of my own limitations (which are legion, according to the wife) so wont do anything silly. Your lights wont start flickering as I fry what remains of my hair.... There's a good chance I'll be passing a TLC tomorrow so if I can pick up a like for like replacement rcd I will do, if that doesn't work or I can't find one I'll call a sparks in. There is one coming soon anyway to remove the PV from the barn and move the various consumer units to a temporary location for the build, at which point I'll get a proper supply to the caravan sorted, so this is only tempory. I'm being careful though and won't do anything stupid.
  20. Would this do the job? https://www.toolstation.com/axiom-incomer-devices/p65443
  21. The caravan is effectively a spur from the barn. Just thinking: is there any point measuring the resistance between the neutral and earth rails in the box? Presume should be high unless there is a fault?
  22. one more... do I need to replace the rcd like for like or are they a generic fitment and I can just get the same ampage?
  23. Was working fine, but then went. No digging and no chaffing. Would a supply fault to the caravan cause the RCD to trip though? The RCD in the barn from which it is connected is not tripping. Just having a look now at the board thinking I might go through it and test again, but cannot now switch the RCD on at all. All MCBs off.
  24. The lighting MCB trips it when I switch it to on true, but I can switch the other two MCBs on but then any load on those trips it too. So can it be a fault on any one circuit? No extractor fan in the loo (unfortunately). There is no earth rod for the van itself, but the supply is from one of the barns via the 3phase supply to these - it's a 16a cable. I've already tried replacing this as I was initially thinking it must have been a fault on the supply.
