LnP
Everything posted by LnP
MVHR Enthalpy Exchangers, BS or SB?
LnP replied to LnP's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks for all the informative replies. I understand this much better now. The Zehnder webinar shared by @Nick Laslett was especially informative, and the Mollier diagram explanation in that was particularly helpful. Here are my conclusions regarding heating in cold weather: It is indeed thermodynamic nonsense to say, as Zehnder did, that an "enthalpy exchanger" becomes an Energy Recovery Ventilation (ERV) system, as opposed to solely a Heat Recovery Ventilation (HRV) system. It's marketing BS, which puts me off considering buying one, but there are reasons why you might. It was telling that the expert from the membrane company described the units more scientifically as "membrane energy recovery ventilation". The energy efficiency possibilities are not well explained and might not materialise for many customers. At 5:18 in the video, Zehnder share data showing that the conventional HRV unit has an efficiency of 90% compared to the 86% or the ERV. The "enthalpy exchanger" is less energy efficient. As @Mike pointed out with the quote from PassivHaus, you get some of that back. Without the membrane technology, the supply air is lower in humidity and therefore there is more water evaporation from the building elements, which will take latent heat out of the structure. However, perhaps that is just a transient effect because once the water content of the building elements reaches equilibrium with the dryer air, there won't be any more evaporation. Also while it's true to say that the membrane technology recycles the warm water vapour back into the supply air, some or all of that heat would have been recovered by condensing the water out of the exhaust air. Where there would undoubtedly be energy savings with the ERV vs the HRV, is if you want to control the humidity to get into the comfort zone (Zehnder video 24:20). In their example, with a conventional HRV you'll need to additionally run a humidifier to get the water content from 3 g/kg up to 5 or 6 g/kg to get into the comfort zone. But if you're not sensitive to humidity, and would be happy with whatever comes out of the HRV, the ERV might well be overall less energy efficient. If you're really sensitive to humidity, you might want to anyway have a humidifier even with an ERV, but you won't need to add as much water, so it should use less energy. There are the additional benefits of the enthalpy exchanger that you don't need a water drain and you don't need to protect against frost until -6 oC whereas for an HRV it's 0 oC. Bottom line for me is that, despite the enthalpy and energy marketing BS, the decision which type to get is not so much about energy, and more about comfort and humidity. And back to @Jolo's post I'm wondering whether his smells cross talk is due to a dodgy membrane. The membrane is only 1.5 microns thick (Zehnder video 43.02). He mentioned it can't be the exchanger because the supplier had put a replacement in and the problem had persisted ... maybe try putting in an aluminium exchanger instead of a membrane one and see if that changes anything. -
I saw @Jolo's post about smells transmitting across to the MVHR incoming air. I was curious about the term enthalpy exchanger, since any MVHR heat exchanger is by definition intended to increase the enthalpy of the incoming air by decreasing that of the outgoing one. So I did some Googling. The Zehnder web site says, "Choosing the enthalpy exchanger, rather than the standard heat exchanger, means that the unit becomes an Energy Recovery Ventilation (ERV) system, as opposed to solely a Heat Recovery Ventilation (HRV) system." Since this is thermodynamic BS, I was tempted to conclude the whole concept is BS. I read their web site further to try and understand how these things differ from a conventional MVHR unit. Is it a correct understanding that a conventional MVHR has an aluminium heat exchanger while an "enthalpy" one has a heat exchanger made from a membrane which is supposed to transmit not only heat but also be permeable to humidity i.e. water molecules? The Brink website is a bit clearer in that it only makes claims about humidity, but calling it an enthalpy exchanger is still thermodynamic BS. I suppose that if you want to increase the humidity of the incoming air, there is an energy efficiency advantage of doing that by recycling the water vapour from the extract air into the incoming air, rather than using additional heat to humidify the incoming air by evaporating water. But I'd be curious to know what Zehnder think that energy saving would be, i.e the latent heat of evaporation of the water required to achieve the required humidity. Compared to an aluminium heat exchanger, there would seem to be questions about a semi permeable, aka "enthalpy" one - is the membrane more fragile, does it let smells through as well as water molecules, does the membrane conduct heat as well as aluminium, to what extent will it transfer humidity, how much energy will it save? So I'm asking myself the question, even if they are mis-sold as "enthalpy" exchangers, are they the best thing since sliced bread or just BS?
BNG / de minimis exemption / small site metric sm
LnP replied to Fi and J's topic in Planning Permission
In a nutshell: Consideration of biodiversity is required for all developments, with the possibility that you might have to demonstrate how you will achieve a net gain. The small sites biodiversity metric tool allows the calculation of biodiversity value for the purpose of BNG for small developments. Yours is a small development, so if you do need to do an assessment, you will use the SSM. There are two exemptions: the de minimis one you mentioned and the one for self builders. The obligations required by some LPAs to successfully claim the self build exemption are onerous. If you're looking to claim the de minimis exemption, your best route is to get an ecologist to provide an assessment supporting your claim. The LPA are unlikely to challenge an assessment by a competent ecologist. It cuts short all the back and forth. Some ecologists are not only providing ecology services but also operating BNG credit banks and will sell you the credits their assessment determines you need. It's clearly a conflict of interest, so find one who isn't doing that. Perhaps your planning consultant can recommend somebody. Otherwise phone round a few until you find one who sounds sympathetic. The assessment should only cost ~£300, Do some gardening before you get the assessment done .... My planning consultant thinks the days of BNG are numbered because of the problems it's causing, especially given the government's house building targets. Maybe we do have a problem with a loss of biodiversity, but there must be better ways to tackle it. Insofar as the concern is about what's going on in our gardens, I read a study recently that the average pet cat kills 22 rodents and small birds a year ....- 1 reply
If you don't want to remove the skirting and don't like the look of quarter round, you can get thicker skirting which goes over the existing skirting and has a recess to sit over the old skirting.
I shared some thoughts on the fluid mechanics and heat transfer aspects of antifreeze in the attached thread. It might explain why your required pump head doubles.... and the required power required might triple... not an expert but going back to first principles.
... and I should have added, pressure drop (required head) is proportional to the square of the flow rate, so in the example above of increasing the viscosity and hence the flow by 50% would mean pressure drop goes up by 1.52 = 2.25, i.e. more than double the head required at the pump. ... furthermore ... the power required by the pump is proportional to the head and the flow rate, so in this example, the head has gone up by a factor of 2.25 and the flow rate by a factor of 1.5, so the power required will go up by a factor of 3.38. I'm a bit rusty on my fluid mechanics, but it seems to me that adding antifreeze is not a trivial decision.
Domestic Client's responsibilities (again)
LnP replied to AndySat's topic in Project & Site Management
A further thought ... quite often, self build projects require an F10 notification to the HSE - more than 500 person days of work. The F10 has to declare who the principal contractor is. Is each of your contractors going to submit a new F10 as they are the new principal contractor? Or will you argue that each contract is a new project and less than 500 days? Could be an interesting discussion if an HSE inspector arrives at your site and asks why you've not submitted an F10. -
Not sure what you mean by different project sections. What are your sections? It sounds like you're self managing and will engage the various trades under separate contracts, in which case, are you really going to only have one trade on site at a time? Will your trades be prepared to be nominated as principal contractors? The best guidance I've seen on this is from the Self Build Portal, which the HSE point to in their web page on CDM and self build. If you're self managing, read the paragraph which starts, "The self builder acts as their own project manager, employing individual trades at different times." Long story short, you're the principal contractor. Unfortunately this guidance predates the recent changes with the Building Safety Act. If there's good guidance out there on how that applies to self builders, I'd be happy to hear about it. -
Ah, so those things I thought were acorns are actually oak cones! 😉
Maybe. Apart from the reduced specific heat capacity, something which would need to be checked is whether the higher viscosity of the glycol solution caused the flow regime to change from turbulent to laminar. For good heat transfer in the emitters (e.g. UFH pipes) and the ASHP heat exchanger, you want fully developed turbulent flow. In fluid mechanics, flow regime is characterised by the Reynolds Number, Re. For fully developed turbulent flow, Re needs to be > ~3000. If you have a system which worked fine with water, and not with antifreeze, it might be because the flow regime has transitioned from turbulent to laminar giving a lower heat transfer coefficient in your UFH pipes and ASHP heat exchanger. Re is proportional to flow velocity and inversely proportional to viscosity, so if you've added 50% to the viscosity, you'll have to add 50% to the flow velocity to get back to the same Re.
Potton homes return as of today
LnP replied to Post and beam's topic in General Self Build & DIY Discussion
CEO Designate RH Steve Baker, and he's going to take up the role full time.As his Wikipedia profile puts it "Baker argues Brexit presents an opportunity for more free trade outside the EU". His new employer has to hope he shows better judgement when it comes to house building. At least this development gets him out of politics. https://www.stevebaker.info/2025/10/homeatix-press-release/ -
I understand it depends on whether there are complications, for example in a conservation area, which would require specialist involvement. They're short staffed and failing to meet targets... like so many other government services. They publish statistics link here. For a new single dwelling it looks like the median time is 27 weeks unless there are hearings or enquiries, in which case it's longer. There's a "fast track" (ha ha) process for extensions etc.
The builder on a parapet wall I was having built forgot to install a cavity tray. I found out about it when the job was not yet finished and we had heavy rain and water appeared through the already plastered ceiling. We agreed he would fit a cavity tray - strip of DPM as described above tied into the mortar beds of the inner and outer walls, with weep holes. That meant dismantling the top 2 or 3 courses of brick and block along about 20 m of wall. It was his mistake but I nevertheless felt stressed dealing with it with him. But It was actually not as big a deal to go back and fix it as I’d thought. Dismantling brick and block is not that difficult, depending what’s above it.
Work to a Perlin roof without notifying us
LnP replied to Andy62's topic in Roofing, Tiling & Slating
I completely re-roofed my last house, all the tiles replaced, and I didn't talk to BC. I just checked the Planning Portal and realise now that I should have. When I sold it, nobody asked. I don't recall it being asked in the seller's questionnaire I had to fill out and it didn't come up in the survey. -
I feel a bit the same way, but was encouraged by what Emma Pinchbeck, CEO of the Climate Change Committee, said in this interview on The Rest is Politics Leading. And the Climate Change Committee's Seventh Carbon Budget talks a lot of sense. Up to now Parliament has accepted the CCC's carbon budgets, but has not yet voted on this one. The framework for this is the Climate Change Act (2008) which was quite clever in the way it empowers the market to take advantage of changing technologies (with their changing costs) and avoided prescribing the path to Net Zero. At the same time, I'm coming round to agreeing with people who say we're better to target Net 5% or Net 10%, because the last 5 or 10% could be prohibitively expensive.
If you don't have time to read her book, you can hear her being interviewed by Michael Liebreich on his podcast, Less Doom, More Data: Debunking the Biggest Climate Myths | Ep223: Dr. Hannah Ritchie To the other discussions on this thread, I also recommend his podcast Audioblog 15: The Pragmatic Climate Reset Part 1 — The Energy Transition Is Not Dead
Am I missing something? Everything up to (and not including) your meter is the responsibility of SSEN. You won't be pulling SSEN's cable. What sort of duct needs to be there and how it's laid out is for SSEN to specify. You're asking questions about facilities which are their responsibility. They will have expectations about what you will do and what they will do, so you'd better ask these questions to them.
In my case the supplier was SPEN. They required the supply from the street (not a pole) to the meter to be in 100mm red conduit. They supplied the conduit, I dug the trench and laid the conduit, about 20m. If you have questions about what needs to happen between the meter and the supply, you should ask SSEN.
I got mine here https://meterboxesuk.co.uk/product-category/electric-meter-boxes/
I know some people use their architect, but you'll pay either way. If there's anything at all tricky about your application (conservation area, objections from neighbours, challenging configuration ...), my view is that you're better off using someone with the correct core skills, a consultant town planner. Ours used to be head of development and control at our LA. You can find suitable local ones from the RTPI web site and get quotes. The one we're using has a fixed fee for the preparation and submission of the planning application and that covers dealing with whatever issues arise. When we started with our application (2021 and not done yet 🫤) it was £2160. Ours has dragged on so long and taken so many turns I actually told him he needed to invoice us for more money - he hasn't. He's also been useful in providing references for other professional services, e.g. ecologists for the bat survey, BNG etc. Useful as he knows which ones are "helpful" and which ones to avoid...
