Alan Ambrose
Everything posted by Alan Ambrose
Depends what you have in your shed I guess. I have a bunch of heavy machine tools in mine.
>>> You can claim back at the end of your project though The context is this - in the case of 'self-build zero rate' ... if you nevertheless get charged 20% VAT on something that's otherwise eligible - say a bolshy but key supplier or VAT paid on an import ... then you can claim that back at the end. I imagine this also applies to your case, but it's specialised enough that you would need to ask/confirm with HMRC.
I'm a fan of epdm too. In another recent thread, it was pointed out that it (at least some of it) can be hot welded. Robin Clevett has a video on a system - you might be able to pick up a few tips. Although it's branded 'Alwitra', I understand that it's epdm.
>>> minimum 6mm sheets Steel is properly heavy - about 3x the density of aluminium. You would need quite a a serious structure to support a 6mm steel skin - each m^2 on 6mm would weight about 50Kg. Or make the corten steel itself structural, weld and support by say a steel frame. I'm not sure why the OP decided aluminium was not DIY friendly. You can get custom cut and custom powder coated panels made fairly easily. Aluminium is soft, so you need to be careful fixing to avoid dents and creases, but I would think aluminium shingles would be v DIY friendly.
If not an SE, you can test before putting the window in by, say, having 4 or 5 people add their combined weight around where the window will bear. The roof load is, say, 150Kg + occasional maintenance load, say 100Kg. For a safety factor of, say, 2, you can apply a test load of double that i.e. 500Kg, - i.e. however many people that is, in your case.
If you asked me to guess, I would think that the landlord is in control of access roads. Would an enquiry to the landlord help?
Thanks for letting us know about this gotcha. What’s the service cost and are there any contract terms to avoid you being held hostage for the duration?
I think I would send your LPA a very polite but formal letter describing the exact situation with names, dates, appended docs etc. Ask them whether they are planning on issuing an official enforcement notice or are they just making a request. Tell them that stopping your contractor will involve you in significant cost (get your contractor to write a letter with a cost estimate for the delay) and that you will look to the LPA for damages and re-reimbursement of costs for any unnecessary delays they cause. Suggest that your neighbour (name him) doesn't understand the rules correctly. Copy to the head of planning if you're feeling bolshy. Likewise, send a copy to your neighbour - there's nothing like a bit of transparency to shake people up. I expect you will receive official withdrawal and go-ahead within a day, maybe two.
I expect so - you'll find similar discussions here re zero VAT & self builds. The summary seems to be: yes that's right, but it's not always easy to convince the contractor (and they have to finance the VAT part). You can claim back at the end of your project though - in which case you have to finance it. Some on here say that the right VAT specialist can save as much as they bill you. As you can imagine, yours is not a common situation, so you might need to consult a specialist to get a (somewhat) conclusive answer. There's also an HMRC forum where you can ask questions and get slow replies - phrase as a real life actual situation, rather that a hypothetical - otherwise they won't answer it. See here: https://community.hmrc.gov.uk/customerforums/vat
I didn't know that you could heat weld epdm, very interesting. I think the choice boils down to aesthetics, which only you can judge as we don't know the location, sun direction, shading etc. I'm sure the engineering can be made to work, but do you have an SE you can buy a few hours of work from to double check as the rooflight(s) will be heavyish? Will you use the roof as a terrace too?
>>> unless I put the potty on the roof Is that what they call an upside-down house? Good view?
>>> But what is sensible? You’re the best judge of that, but some mix of - what skills do you have? what cost savings can you make? what do you like doing? what things are critical to the function and aesthetics of your well-built house and what not (e.g. air tightness is, garden planting maybe not)? what’s the most risky aspects of your build? - you might want experienced trades on those. You can probably save most money easily by careful buying - trades won’t care if they’re simply re-charging you. You can probably control quality and avoid mishaps best by selecting & briefing trades carefully, understanding the detailed work, and being around to keep an eye on progress.
I replaced some DGUs recently. They came with big stickers with the spec on and a big ‘this side out’ notice. Suggest a proper supplier like Internorm would probably do something similar.
High solar production in Germany forces rates negative
Alan Ambrose replied to Alan Ambrose's topic in Housing Politics
If I remember rightly, it's what Mark Jacobson at Stanford University predicted i.e. a glut of cheap solar power. Suggests a real push for storage as the input energy cost will be very low at times. Also, as @joe90 said - it might make for two cheap daily periods, overnight when everyone, including most industry is asleep, and in the middle of the sunny day. But will it make the economics worse for all generation capacity but better overall for the consumer? -
Yes, they get their strength from the fill. Use sharp stone rather than rounded shingle for max strength.
>>> This must be hard to police Also, pretty dumb. The UK is hardly likely to end up like the Southern US, where A/C is a big load. And, when the need is greatest - those unusual sunny & hot days, PV generation will be at max and there will be power looking for places to be used up. Sure think about reducing summer solar gain. But you'll likely reduce solar gain the rest of the year too, and therefore increase energy use overall. Guess what, we have more heating days than potential cooling days in the UK. Even in Texas heat and a/c energy uses are fairly balanced: https://www.eia.gov/consumption/residential/reports/2009/state_briefs/pdf/TX.pdf I would love to know who invents these dumb 'rules'.
Outline Planning Permission - should I do it myself?
Alan Ambrose replied to Mike Wynn's topic in Planning Permission
>>> you'll make more money if you can get permission for something smaller rather than larger err, or vv, I'm sure you know what I mean -
Inherited Property
Alan Ambrose replied to MikeGrahamT21's topic in Party Wall & Property Legal Issues
For about 6 quid, you can get copies online of the official registration docs for the property from the land registry. That's the 'official' position and should list type of joint arrangement / share proportions if there are any. Make sure you use the .gov site, not some fraudster. You will need some kind of valuation for probate. I just used some online sources (Zoopla etc) but for not much money you can get an estate agent's valuation 'for probate'. Maybe they'll throw this in for free if they think they'll get a listing. -
The idea is that you would rather not have the base (or any other bit) sitting in water for any length of time as it'll rot. Another option to raise it up, if your slab is level, is gravel grid. If you are careful with gutters, down pipe exits, drip edge, think about water splash from rain hitting the floor etc, it'll last a long time. I might be inclined to use epdm for the roof as it'll last longer. I also might beef up the floor a bit as it's that that'll fail first.
That's curious - it's usually a gotcha form - forget and you get penalised. This is from your local CIL guys at your LPA? I might send one to them anyway for safety.
Inherited Property
>>> are we legally allowed to put it on the market for sale, or do we need to wait for probate to come through? Yes, you can put it on the market and any estate agent will be used to this situation. I think you can exchange, but you can't complete (memory fails me) - but check with your conveyancing solicitor.
