Alan Ambrose
Everything posted by Alan Ambrose
>>> the only thing stolen on our site was wheel barrows (X2) that reminds me of an old joke... https://jokesfunnystories.quora.com/What-was-a-loophole-that-you-found-and-exploited-the-hell-out-of-356
Planning Permission battles
Alan Ambrose replied to Indy's topic in General Self Build & DIY Discussion
@Indy B....x - commiserations, I feel for you. -
In this issue of Homebuilding & Renovating p24-31 (the 1st image doesn't have a wavy ceiling, it's just the way the magazine is sitting on my desk). I like the look a lot. My question is: how do they do this without covering the whole thing in plasterboard etc for fire protection? Standard paint over intumescent paint maybe?
Adjustable wall fixing
Alan Ambrose replied to Pocster's topic in General Self Build & DIY Discussion
I like these things for that sort of job: https://www.fischer.co.uk/en-gb/products/cavity-fixings/board-fixing/metal-cavity-fixing-hm Only the Fischer ones, the competitor ones are rubbish. You really do need to use the pliers thingy ('setting tool') to pull them tight before you screw into them. Ask me how I know. With these you can screw and remove as often as you like. -
Buying a house without a new build warranty
Alan Ambrose replied to oksleator's topic in New House & Structural Warranties
>>> surely the Building Control inspected whilst it was being built. Good point, if it was the local authority BC, I've seen before a property advertised with 'LABC warranty' i.e. these guys: https://www.labcwarranty.co.uk/ -
Help designing our home network
Alan Ambrose replied to MechanicalBuilder's topic in Networks, AV, Security & Automation
Just think of anywhere you might want to put a wifi access point, a camera, doorbell, gate opener, plug in a computer, tv, have a smart device etc etc etc. Note that, if you forget one, that in the future you can split a network cable into two if you need, but it need a couple of tails and the solution is OK where you don't need max bandwidth. Run the cables back to one or more hubs - more than one might reduce the amount of cable considerably. CAT6 should be fine. -
I think that is holding up the edge of the asphalt - so remove it and the edge is likely to crumble over time.
>>> The new Fischer ones are stunning. They are in TS or SF @saveasteading I’m interested exactly which ones - the duopower, sx, ux, self drilling? https://www.fischer.co.uk/en-gb/products/standard-fixings
>>> So if I can justify PHPP is equivalent to TM59 criteria, its ok. This is from your BC? They should know that these are not the same, so unless that particular LPA has decided to accept PHPP (some will/do) then that's a somewhat polite way of saying TM59 or nothing.
3Kw quiet site generator. Recommendations?
Alan Ambrose replied to flanagaj's topic in Tools & Equipment
I've not made my mind up yet, but I was looking at the little Hyundai 2kW 'suitcase' generators e.g. HY2000Si . The framed ones look a little too heavy at 50kg to move around a lot - in a wheelbarrow maybe. Max sabre saw is ~1.5kW, so that should be OK. Having said that you could probably buy a cordless sabre saw kit cheaper than a generator. -
The worst 'vaidation' shenanigans for me were with Openreach. The plans I sent them had already been validated by my LPA - but they were not good enough for Openreach... Eventually I raised an official complaint and that sorted the matter out fairly quickly. Not sure I would do that with my LPA unless pushed though.
Standing Seam, 2nd side of the Roof and Fakro Windows
Alan Ambrose commented on Patrick's blog entry in Timber Portal Frame - but stick built
OK small ones: 265 x 165? handmade? . I think it should still be a bit of fun, if you have, say a telehandler, to avoid the muscle work and the roof pitch isn't crazy high. -
Scotia beading around corners
Alan Ambrose replied to Chriswills's topic in Wood & Laminate Flooring
Steaming works well with softwood, not sure how well it’ll go with hardwood. I used to help my dad build wooden boats when I was a teenager. Amazing what you can do with a former, some tensioning device (e.g. string), a standard kettle and a bit of patience. I seem to remember we did it in stages i.e. steam and tension, leave to cool, repeat until you get what you want. If that little moulding is softwood, it shouldn’t be a problem. Oak may work but it’s a bit brittle. Use softwood for that bit and then stain? Otherwise (depending how much you want this) you could router the shape out of a bit of solid plank. A local carpenter could do it for you if you want. -
Problem with planning - Two storey rear extension
Alan Ambrose replied to Tennisman's topic in Planning Permission
Ever get the feeling that you’re your starring in someone else’s Kafka play? -
Shortish Read: this is really, really weird
Alan Ambrose replied to SteamyTea's topic in Boffin's Corner
Here I am wondering about insulation thickness and somebody is telling me that temperature is all b…..ks anyway. -
All LPAs have a bunch of ‘validation rules’ as does the appeal body (as do some utilities companies). Some LPAs document them well, sometimes they’ll have rules that they don’t bother to tell you about. I get the impression that ‘validation’ is left to a junior, there is no common sense applied, they just run through the rules as automatons. If it says you need a road name, you need a road name. If it says you need a North indication, you need a North indicator. If it says you need a scale bar, you need a scale bar. Etc, etc, etc, etc. Sometimes the rules don’t make any sense and sometimes, some of their regular architects seem to be able to evade the rules. Sometimes the rules apply to one person or application (e.g. heritage impact statement) sometimes they don’t (even for the same plot). By and large it’s just easier to play along. Sometimes when they’re being dumb and annoying, I send them the answer back perfectly politely but with the ‘missing item’ (that actually wasn’t missing) with a big arrow and 24pt bold red text. They probably don’t get the sarcasm, or maybe they do and they don’t care. What’s that phrase - choose your battles?
@flanagaj 1,800 tiles maybe? Actually it’s all v quick. I’ve only done one but suggest: + 20% of time/effort for membrane/ battens. Yeah, layout carefully but v easy job. Get the laps right on the membrane. + 30% for getting tiles in stacks on the roof. Bit of physical effort. I had a forklift to get them to eaves height. Suggest telehandler / lift is worth it. +30% for laying, v quick and easy, a bit hard on the knees. Nail about 15% especially edges? + 15% for fitting hip / ridge tiles etc. Just a bit fiddly. Cut clean through my angle grinder cable without blowing a fuse. Be more careful than me. + 5% guttering. I was nailing by hand, a nail pouch on a belt is handy. -
Part of this is ‘we’re too expensive / precious / (insert your own adjective) to deal with you as a human, talk to our computer instead’ thing that is wildly prevalent these days.
Alternative plaster finishes?
Alan Ambrose replied to Alan Ambrose's topic in Plastering & Rendering
Those sound good. Anyone used lime plaster internally or lime paint? @SimonD - your mum might reveal the recipe she used? -
Piled foundations and private drain question
Alan Ambrose replied to JackOfNoTrades's topic in Foundations
Standard paving slabs loose laid on the shingle and along the pipe - if only so you remember where the damn thing is? -
I'm sympathetic - I even paid for an optional face-to-face meeting only to have my LPA renege, change their policy and not give me my money back. Lovely, eh. Sometimes I see it as an exercise to wear down applicants - that and the crazy slow response time. How else are you going to keep the rate of building down and preserve the wealth of the ruling classes?
Anyone used any plaster finishes which are not just matt painted plasterboard? I have in my minds eye something with a bit more actual and visual texture? Yeah, start by making all the jokes about Artex and 80s rag roll finishes etc you want - I'm thinking of something classy , maybe something a bit ... continental.... This kind of thing maybe? https://www.architecturaldigest.com/story/venetian-plaster-trend-guide
>>> spin it out while you gather support Maybe get your Architect to propose (verbally without drawings) some ideas to 'mitigate' the visual impact - some roof amendments, planting ideas, anything - just to keep them engaged. File some good photomontages or models etc - sometimes the idea of a negative impact goes away when you can illustrate the actual visual impact? Lots of people can't 'imagine' in 3D very well from 2D drawings.
