Alan Ambrose
Everything posted by Alan Ambrose
Building Dispute with contractor
Alan Ambrose replied to James Frome's topic in Costing & Estimating
@saveasteading Know any hard-arsed QS to argue the client's case on a £2.5m project? To be clear, this is not my project but one I'm familiar with and the contractor's QS has gone rogue. -
Octopus Zero Bills
Alan Ambrose replied to Little_Miss_Tidy's topic in General Alternative Energy Issues
Or calories - there, that reduces the confusion... -
I would say that's maybe 8 person days max of brush cutting at whatever daily rate (EUR 200?), so EUR 1,600? A few hundred to have it carted away. EUR 2K all in? Maybe 50% of that or less if most can be done with a small tractor and a flail mower ... and they have the equipment sitting around and live within a km or two.
I'm guessing the nearest blue dot (to your green dot) is meant to be the chamber. As everyone has said - take the lid off and you'll figure everything out including depth. May only take you a few minutes. Actually the map shows two inspection chambers either side of you plot and one in the middle (the latter unlikely but worth looking for). Any two points located with depths etc and you're probably home and dry (so to speak). A topo at a later date will give you the respective invert levels and positions accurately on the map. A bit weird that they didn't just run it along the side of the road and not through your plot. You could ask them how much to move it to give you maximum flexibility.
How much cooling does a passive house need?
Alan Ambrose replied to WisteriaMews's topic in Air Source Heat Pumps (ASHP)
>>> I veto the build Ah, a reminder that there are some things which trump the laws of physics It would be most thermally efficient if there were no windows at all - but we could show a real time picture of the garden on the TV 😒 -
>>> PHPP will tell us our heating demand (e.g. 10W/m² heating load), but I'm not aware of it giving a cooling load. Here are the tabs in the PHPP spreadsheet (below) - a bunch for heating / shading / ventilation, a bunch for cooling, and a bunch for overall energy use and HP sizing. Also look at https://passipedia.org/ Your architects should be on top of both heating and cooling. Personally I don't see any environmental problem with running A/C or HP in cooling mode if it is driven by PV. By and large, the heating / cooling balance is governed by the amount of glazing - particularly S, W, E glazing. Little glazing roughly means easy to heat and cool, much glazing means potential heating and cooling problem. You can intervene with shading, external binds, low g glass etc but the amount of glazing is key. I'm wrangling this balance too atm. I'm coming round to the idea that you can somewhat balance winter solar gains (desired) with summer solar gains (somewhat undesired). FYI PHPP has an analysis of positive winter heat gains by window vs. undesirable summer heat gains (bottom image) which I'm trying to fully understand. -
>>> has anyone got an EDPM roof that’s over 10years old ? The general guarantee is 20 years if that helps. I've wondered whether the sun might eventually do mine in - it gets awful hot on there in summer. Mine's been there 5 years already and the last time I was up there it looked as good as new. >>> I used the thicker Firestone EPDM the 1.5mm stuff?
What kind of pipe has it got labelled on the map? Would it make sense that the manhole you have found is on the route? How big is the manhole cover? Want to post some of this up, we”re kind of working in the dark here.
@Marvin Put it on myself. 5m by 12m. Bloody hell - how did you do that? Impressed. 135kg by my reckoning.
@saveasteading >>> A Q S is like a lawyer in that he can argue your case to your maximum advantage and does not have to be fair and equitable. Possible to say more about that? If you didn’t know better (I don’t ) you might think the QS is doing a kind of scientific / accounting-type reckoning, no? That is, given the job spec you might hope different QSs might arrive in the same ball park? -
Octopus Zero Bills
Well I give them credit for ‘thinking outside the box’ even if I don’t yet get their whole economics analysis. Maybe the clue is in the work ‘Kraken’ i.e. a legendary sea monster of gigantic size . Colour me cynical - is this the next ‘houses sold as leasehold’, ‘cladding’ or ‘crazily escalating ground rents’ scandal? -
I like epdm a lot after using it on my shed roof. I think sticking it down is a bit of an art (like getting sticky back plastic down without any air bubbles) and I wasn’t that convinced by the glue that came from the same supplier - it looked suspiciously like PVA. The odd air bubble isn’t going to make any difference to the watertightness. My bit was 6x4m - so half the size. We could manage fairly easily with two guys. You might want more bodies (a) to get it up there and (b) to manhandle it into the right spot / orientation.
>>> Is this not like anything you were to buy that it’s the business or sellers responsibility to charge the correct VAT and not the customer or consumer? It sounds like good logic, but most quotes / contracts / invoices say '+VAT at the applicable rate' or similar. For 99% of consumer transactions that's obvious, but not for building stuff. If he did make a mistake as he claimed and you 'relied' on it in legal speak, it wouldn't be unreasonable to offer to meet him halfway. The extra VAT is about £4K? I think it could go either way in County Court maybe depending on the exact text of any docs, emails etc. It would probably cost £1-2K or so each if you both use solicitors and (unusually) you actually do get to court. It'll also take at least a day each of your time and 9 months or so elapsed and a fair amount of aggravation unless you're very thick-skinned. So, it would be better to sit down and negotiate a solution. Failing that, have the solicitors try and negotiate a solution. As LSB says, check whether he's VAT registered, how you got here, and get the fullest story you can on 'how he came to make the mistake'. By all means document that conversation.
>>> the site is about 800sqm, my main concern is to find a possible water pipe underneath the ground so that I can build at 3m away from that You'll probably get what you need straight from your local water authority - at least a rough approximation to the location. Sometimes the records are missing or not accurate though. That'll hopefully give you a rough idea for planning a house location. The doc might have already been obtained in the searches when you bought the plot. The authority should also be able to tell you what kind of pipe it is, which'll be useful so you know how fragile it is. If the pipe is going to provide your own supply, you'll make much progress by going through the 'apply for a new supply' application and get an actual bod on site. They often know stuff that's not on the plans. That's probably all you need to kick off an architect. To get it accurately though, which you'll want to do at some time, you might need to dig down to it at a few points to verify and to get the level. You might be able to locate it remotely if iron, otherwise some sleuth work and some digging. Re a proper topo - yeah, dwg / dxf CAD file is key for people to draw on (computer-wise) using it as a base. Prints / pdfs are negligible extra cost. You probably need to specify exactly what you want - here's my spec (below), but I probably missed a few things - some tree stumps, eave heights of neighbouring buildings, height of mid-point of LV line. Local firm is good, as it's probably 1/2 day for a team of two. £400-500 + VAT maybe depending on how big the site is / how much it varies in height / how many 'features' there are / what grid size you want etc. Boundaries with heights & description Pick up the gates, driveway & the relationship to the highway The position & invert level of the ditch culvert at the front of the plot and the position and top level of the culvert pipe (now exposed) at the rear of the plot (one point at each end) as marked on the plan provided. The top being ~70cm down from the surface. This is behind the Ash tree. A paint line indicates the approx line of the culvert, please pick up one other on the surface from that so we can establish the approximate track The invert points of the culvert pipe in the ditch next to the highway have been highlighted The location and height of the poles at each end of the LV line All street furniture All service covers Overhead Cables Buildings (Outlines) All changes in surface All water features Trees; Location of the four trees and, if possible, the approximate tree height & extent of the foliage. Also pick up position & heights of 3 trees on the opposite side of the road Trees fully detailed - surveyed trunk & 4 points on canopy Road markings Existing building outlines Contours (interval) Existing building heights and neighbouring buildings The ridge height (only) of the 4 nearby barns (assuming these can easily be sited reflectorless from the plot). Levels over the site - 10m grid Floor Window and Door Heights of existing buildings Visibility splays - include all nearside features with heights (trees/hedges/fences etc.), with requested distance of splays in each direction from site access
My epdm shed roof was supplied with a pva-looking glue to hold the majority of it down and a contact-adhesive looking glue for the edges. I guess sticking the free edge down with contact adhesive would be a good start. But epdm isn't very expensive, so it wouldn't be a big deal to replace it with a bit the right size.
Commiserations, how annoying.
It could be that he's had a visit by the VAT-man who has pulled up these invoices - they generally like to pull up one or two. Or maybe his accountant has done the annual accounts & audit. Start by asking the builder why he has changed his tune and why now? Have you figured out whether the 'empty for 2 years' is a thing for VAT? And, if so, do you qualify? Sometimes the exact status of the customer does affect the VAT situation - charities for instance. It wouldn't be unreasonable in the situation to ask for some evidence that the VAT will be charged correctly and paid over to the VAT man correctly.
Camera to monitor tree work
Alan Ambrose replied to Ferdinand's topic in General Self Build & DIY Discussion
>>> Reolink do a stand alone 4G camera that’s solar powered. Can I ask - is that working well? Any drawbacks? -
>>> were in Norfolk OMG - that far away!
Well done. I would think there's a good chance the whole things drains downhill somewhere too. Always interesting to find out. I assume you didn't get any complaints / info about flooding since you didn't mention it. If not, then probably BC / EA will be OK with you draining rainwater to it. Maybe via an attenuation set-up of some kind - the latter depending on how much they're on top of SuDS / concerned about flooding.
Unless I am mistaken, it seems to me this is still really hard: (a) choose a PV panel size that is going to be supported into the future (!). Assume these are all fitted portrait orientation as that's the way Veluxes (?) generally go (choose landscape if you insist).To check for max number of PV panels / PV output - check that it fits on your roof envelope fairly sensibly. Something like minimum 30cm margins at roof edges. Use Easy PV maybe. (b) the Velux sizes that seem to be supported right now are MK06/08/10 & PK08/10 i.e. 78Wx118H - 140H - 160H & 94Wx140H - 160H (all in cm). Select a Velux size - probably a smaller size than the panel size you have selected. The max Velux sizes seem to be 160cm high, so with common PV panels, that suggests MK10 or PK10. (c) figure out which GSE frame supports both. Use GSE's app if you like. See if those frames are obtainable in the UK. Otherwise go to (a). (d) that gives you the regular grid size (presumably the GSE frame size). Check that the possible Velux locations are vaguely where the architect intended and move them around to fit the grid. Otherwise go to (a) or (b). (e) figure out the fittings required (maybe the GSE app again) or Easy PV. See whether you can buy those in the UK. If not go back a few steps. (f) all you have to do is buy all the parts and fit them now ... oh you'll need to do something with batten locations. Is that right?
Thanks, I remember looking 6m ago and there were many documents with big matrices of numbers. 😒 Oh yeah, I remember...
Goodness this seems hard to figure out. @LiamJones - you seem to have a neat set-up there. Can ask what the horizontal and vertical repeat distances are please? i.e. the 'grid size'. Also, can I ask what size solar panels you're putting in the v2022 frames?
