Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. If it was me, I'd re-grout (just scrape off any loose grout and re-apply) and re-silicone the join with the tray and that should be good for another 5 years. If tiles are actually loose, then by all means take off an re-mount and re-grout also, but I wouldn't pull any off that are stuck fairly firmly. Check the drain if you're feeling thorough. A day max if there are no loose tiles.
  2. The heritage officer was outraged that we didn't submit a heritage report. This is mentioned anywhere on the LPA's portal - no. Report needed for the same plot for the previous successful application - no. Also the LPA asked for a contamination report - also not listed on the LPA's portal despite the fact they have a detailed 'validation checklist'. Also not needed for the previous application. Making it up as they go along...
  3. >>> We've got site's in the Shires that are mothballed because the lack of buyers. I think that's easy - for the big developers, the LPA's just need a condition which reads not 'start within 3 years' but 'finish within 3 years or cash penalty for every plot that's not completed'.
  4. >>> Any evidence on what percentage of houses are bought for cash? I saw that recently, BBC I think ~30% from memory. Yeah, see here: https://www.google.com/search?q=what+percentage+of+houses+are+bought+for+cash
  5. Yes, agree, my sympathies, usual LPA BS in my view. Insufficient detail on what constitutes a valid application - check. Inability to locate information on drawings - check. Obvious that the rules don't apply equally to their regular applicants - check. Silly overreach on requirements that may never be needed if the application is turned down - check. Each LPA's requirements are different - check. Universal list irrespective of whether the applicant is applying for one dwelling, 10 or 100 - check. 'Validation' done by least qualified and most junior member of staff with no common sense - check. At least your validation response was probably signed by an actual human, the inspectorate takes, say 15 weeks, can't see stuff on the drawings and then sign themselves Validation Officer A8 or some such nonsense. These should probably all be added to the 'reform the planning system' list.
  6. So that's two government departments and three quangos including BRE ... why do I think this isn't going to go well? https://www.local.gov.uk/roles-and-responsibilities-relating-suds
  7. >>> Affordable Housing contributions Jeez, didn't know that was a thing. Given that that and CIL are yet another tax on building (and thus a discouragement) and not consistent between LPA's - they should both be canned. >>> I think the biggest problem is younger people cannot afford to get on the housing ladder, if house prices fall to a more sustainable level it will be fairer. Yeah agree, let them fall by 50% or more to the old 3x salary level. Houses should be for living in (duh) not surrogate pension pots. Also, the current state of affairs means they represent a net transfer of wealth from young people to old. That's not fair, is it?
  8. Where I am today is a 5th floor flat and consequently the mains pressure is fairly low. There are two stuart turner 3 bar twin pumps which pressurise all the water apart from the kitchen cold tap: https://www.screwfix.com/p/stuart-turner-monsoon-universal-regenerative-twin-shower-pump-3-0bar/79703 I know one is 30 years old, one 25-ish - pretty much one for each bathroom. Not cheap at the time - about £500 quid from memory. Two because we wanted some non-panic time-flexibility if one were to fail. This is an old 'vented' water system with hot and cold water tanks. They make a bit of noise when they run and the little pressure vessels have been replaced a couple of times - otherwise they're very good. If the power went off we would have no water except for the kitchen cold tap - but I can't remember the last time the power went off. Because they're twin pumps, hot and cold pressures are balanced and there's no impact, for instance, when you're showering and a toilet is flushed. To be clear - the pressure vessels are little 2L ones (original was 0.6L) - they're just there to get the pump to start. They run better than ever now I've converted them to use off-the-shelf pressure vessels rather than the over-priced ST ones. I would use this system again if necessary.
  9. >>> we do like to challenge the normal ways of doing things to save both time and money Nothing wrong with that, but then it's even more important that the detail is nailed down and you're on top of it. Maybe the key question to ask the architect and builders is 'have you ever done this kind of class Q on a steel frame before. If so, what EPC and air change rates did it get? How did you handle the thermal breaks? What were the challenges and how did you overcome them?' If you get the answer 'no' and/or baffled faces, then pass. If they get out their pencil to sketch the solutions they've figured out before, then listen and be ready to get your wallet / contract signing pen out.
  10. Most ditches flow somewhere, wouldn’t have been much incentive to dig it otherwise. Look at a detailed contour map and maybe take a walk or two and you should be able to see how the local area drains. Talk to the neighbours and they’ll add some more info on the history and behaviour over time.
  11. Assume you’ve tried with an off-the-shelf pre-formed network cable?
  12. >>> If you are changing materials you will need to go back to planning permission But only with a non-material (ta-da ) amendment.
  13. Assume you’re talking wet ufh. The response time is largely due to the ‘thermal mass’ of the floor. Minimum screed and max insulation under - fast response. Huge thick slab and no insulation - v slow response. Electrical ufh on good insulation is v fast - a matter of minutes. Our wet ufh here (probably not on great insulation and not sure the temperatures and flows are set up right) is a day or two to get up from say 16 to 22. Response time may not matter - most people in well insulated set-ups just leave the whole thing running to temp 24/7. The make of controller doesn’t make much difference - electrical controller switching takes a second or so (most delay is app/wifi related), the actuators if you have them take maybe 20 seconds to open or close.
  14. >>> And most were built by the landed elite, that also sat and made the rules for the rest of us to follow. Let me see, who benefits most from planning application approvals? The landowners. The system is still rigged to extract the maximum amount of wealth from the lower & middle classes and hand it to the landed elite. Keep planning approvals down by inventing an ever increasing number of hoops to jump through thus restricting supply and keeping profit from planning approvals (which goes into the landowners pockets) at a maximum. Plus ca change.
  15. Maybe split the job into tasks if you can. Let them do one bit first (blockwork maybe) and if both parties are happy when that’s done , you can go on from there or switch horses.
  16. In your experience, is the SuDS requirement a planning, BC or EA demand? Also I remember reading about some new organisations that were going to police SuDS?
  17. My hairdresser remarked recently that in Japan (she’s Japanese), with the exception of some historic buildings, they plan for 50 years lifetime for dwellings and then expect to re-build. The epc calc should be open-sourced (code and calculations) and put up as a free web app. Trying to meet government targets that are both mysterious and flawed is complete and utter nonsense. Imagine if the tax laws worked like this.
  18. >>> What is really needed is a mechanism to make poor EPC houses genuinely be worth less than good ones. I suppose an easy way is to point out, say in the EPC docs or on the .gov epc site, how much it'll cost to run vs. a well insulated house. Capitalise that annual amount to a lump sum today i.e. extra annual expense / discount rate. So, if the discount rate is, say, 5% then extra annual expense x 20. e.g. 'This dwelling is estimated to cost an extra £2K a year in heating bills to run over an identical house rated as EPC B. That will be £40K total lifetime cost and therefore it should be £40K cheaper than if it was insulated to EPC B standard.
  19. @garrymartin >>> The balance is whether the harms "significantly and demonstrably" outweigh the benefits. So, you're happy with the system? Could this trade-off between (as I understand it) sustainable travel vs. a new unit of housing have been decided in a quicker, simpler, lower cost way? Is this the best outcome for society?
  20. @SteamyTea >>> Maybe a big tombola with geo coordinates as the prises. £10 per ticket and a daily draw. If you win, you can do what you like with the bit of land. Most of the buildings we love now, listed and otherwise were built before the planning system began in 1947. We admire them for their idiosyncratic styles, over-the-top designs and budgets, quality and innovations in materials and building methods, prominent positions in the countryside, generous proportions etc etc etc. That is, 'they did what they liked with their bit of land'. And that's exactly what we prevent with our current system.
  21. >>> You don't seem to like LPAs. @saveasteading Anyone's personal feelings are irrelevant regarding changes of policy ... but individual's personal experiences of the planning system are relevant in that they can illustrate problems although in a narrative rather than a statistical way. Take @garrymartin 's experience - he's wasted his time, energy and money pursuing approval on a plot that his LPA could and should have told him in 5 minutes they were never going to allow - simply because it is in the countryside. The LPA's excuse is some complex nonsense about 'sustainable travel' disguising their policy that they simply won't allow approvals in the countryside. That could and should have been made clear - probably before he even applied. Maybe an 'important planning policies' section on the LPA's website. The whole thing was a dreadful waste of his, the LPA's and the inspectorate's time and energy and demonstrates huge inefficiency. Do you disagree that the planning system should be swift, efficient, open, rational, equitable, predictable and proportionate. That's not what we have right now. It should be obvious that the LPAs and the Inspectorate should themselves obey the planning rules and also not mislead the public and government. The context as we all know is longer and longer planning delays, a continuing failure to meet house building targets, decisions based on badly-justified personal opinions. ATM we're playing a sort of very expensive 20 questions game - 'will this work?' - 'no, and we're not going to be clear on why and what you can do to make it work'. OK 'will this work then'. etc etc etc Biggest changes IMO are to (a) ensure the often 100x profits from obtaining permission are fairly distributed, (b) have a quick, collaborative, evidence & data-based decision system, (c) make it proportionate (that means far fewer rules for self-builders than larger developers), (d) consistency both within LPAs and between LPAs, (e) make it proactive for the LPAs (yes, get them to source land to meet their targets and figure out appropriate design guides).
  22. >>> 8 effective hours is pushing it 3 hours of work on a good day + 1 hour going to the trade counter + 1 hour general chat + 1 hour on the phone to new potential and old tee-ed off clients + 1 hour on social media + 1 hour making an influencer video?
  23. If you've got the bath already, there's an easy way to tell
