Alan Ambrose
Everything posted by Alan Ambrose
Sewage Treatment Plant self install
Alan Ambrose replied to MortarThePoint's topic in Waste & Sewerage
We were working on this today. A properly anal approach, but I wanted to be able to get it out easily if there was a future problem. Very doable DIY - although it would be easier .... the next time đ. Main issues were falls (courtesy of some earlier careless groundworkers) and, believe it or not, making the straps work sensibly. My digger skills are improving, although the original dig out was done by an experienced guy in one day. There was properly hard dried out clay that far down. The dry mix was done by hand on a piece of ply - we didn't even bother to get the cement mixer out. The perforated twinwall in the last picture is for checking on GW level. -
Well I'm sorry to hear that and it's a good thing that someone is taking this nonsense on. >>> after submitting a minor amendment to our already-exempt planning permission, we didnât realise we had to send in a second CIL commencement notice I've never heard of that particular excuse before - is it possible to say a bit more. What kind of amendment and 'non-material' or 'minor material amendment' and/or a 'Section 73 amendment'? I'm interested what part of the CIL law details that gotcha? Did the LPA explain with reference to the law or did they just assert their position? I know some LPAs do make stuff up / 'have their own special interpretation' where the law is a bit vague. Was the LPA's assertion challenged by a solicitor?
Architects have messed up. Next steps?
Alan Ambrose replied to flanagaj's topic in General Self Build & DIY Discussion
How big is the plot? Would it âmake much differenceâ if the dwelling was moved over a bit? -
Credit/Debit Reward Cards, Discounts etc
Alan Ambrose replied to Ferdinand's topic in General Self Build & DIY Discussion
The thing to watch out for is the FX rates/spread - a lot of bank cards these days use the Visa or Mastercard rates which are not crazy bad (but not crazy good) at 2% of the transaction. As usual, financial services usually takes the micky on anything that isn't written in plain English in front of you. See e.g. Currency Converter â Exchange Rate Calculator | Visa Whenever you see 'zero or no commission' that means they're trying to fool you into thinking there is no transaction charge. Some people call that 'lying'.- 151 replies
- credit cards
- rewards cards
- (and 6 more)
Maybe sheet piles would give you the room you need?
Errr, one method is just to use the piles as the 'shuttering' for the excavation, then a metre gap for working room, then the actual shuttering for your basement walls. Apply some external insulation before you backfill. What are you doing for the other sides?
V nice, btw are you pleased with your windows?
Ah, strikes me the HMRC rules are over-complicated. Also, if this is meant to put us on a level footing with small builders (who can presumably claim back all their VAT) ... it doesn't. I'm guessing our VAT reclaim/zero-rate is actually applicable to ~50% of our actual costs. Also, is the obvious 'mitigation' to get, say, a groundworks company to incorporate muckaway and labour in the same same job, which will then mean the muckaway is zero-rated?
See: Why are Solar PV Panels Getting Bigger? âą Solar Energy UK It seems this is not helpful for later panel replacement, so I'm now assuming something like a 20-year complete rebuild of fixings + panels.
Ah, I found out why my joist manufacturers didn't call me back following my email enquiry with some teaser drawings. I broke down and called them both today. It's evident they regard the sale/purchase process as a power battle - I need to prove that I'm worthy of their product. If I can jump over their hoops and satisfy their requirements, they may deign to deal with me. I've never dealt with a Ferrari dealer (one day maybe) but I've heard they take much the same approach. Mutter mutter mutter, 12-week process, duty-of-care, British Standards, mutter mutter mutter. They both spent most of the call telling me what their requirements were, about the limitations of their software, how they need to avoid being sued etc. Why did I want roof joist that deep, that's very unusual (Passive house standards maybe)? The Easi-Joist guys said their software doesn't figure out the roof lights in their deep joists. They both ignored my stated needs and wishes. A good job we don't have all that BS when ordering standard timber.
Congrats
How to make a shower-cubicle floor waterproof?
Alan Ambrose replied to David001's topic in Bathrooms, Ensuites & Wetrooms
Looks like someone has had a look at this and not found the problem yet. Maybe check out other odd possibilities that have not been fully checked out. Is any silicone seal 100%? Possible that itâs a leak behind the mixer tap? Iâve seen both of those cause a hard to find leak. -
Unfortunately, I doubt it. The thing that I find odd is that the tiling looks quite neat which suggests a careful job. If youâve regrouted, the grout should be fine, so might it be a plumbing problem? Worth checking that the pipework joints are tight. I think unless you can see where the leak is, it might be quickest to rebuild the whole set-up from scratch. Try an endoscope camera maybe? Post up a pic from underneath? -
ASHP shutdown on over current
Alan Ambrose replied to JohnMo's topic in Air Source Heat Pumps (ASHP)
Btw those wifi devices are partly cute but note that Mike of mikeselectricstuff thinks theyâre quite dodgy: -
I have an old site office container and itâs fine. Not sure how itâs insulated, but so far (we have not used it for a winter yet) itâs good.
Might be easy to cut a neat 1 foot square hole in the plasterboard in the ceiling below to get an idea whatâs going on. -
MVHR calculator
Alan Ambrose replied to Mike's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Fantastic, and good timing đ- 2 replies
- mvhr design
- mvhr calculator
(and 2 more)
Reckon, 1.5mm will take >4kW, box is probably <100W.
I just got my Octopus bill, which reminded me of the weirdiama billing they've been doing over the summer. I wonder whether Octopus was hacked - no company fails to bill for nearly 4 months unless they have major systems problems.
- 70 replies
- utilities
- electric bill
(and 3 more)
Yeah, I contracted two posi-joist manufacturers on Monday, attached a few drawings, and asked them to contact me. I'm expecting to spend well into 5 figures on joists. Think they can be bothered? Well not yet certainly. I also have a couple of suppliers that I expect to spend over ÂŁ100K with. Think they can be bothered to act like suppliers that give a .... monkeys?
This has been discussed on 't 'ub numerous times before - feel free to search.
OK I thought I would report back for anyone else looking at this subject in future. There don't seem to be an great timber-specialist suppliers in our area BTW. DIY Building Supplies, Materials Market & Sheet Materials Supply Wholesale will ship both small and large quantities and put up bulk quantity prices on their website - at least for some variants. Their prices are look cheapish and the product is almost certainly Chinese. Proper external grade i.e. 'waterproof' is BS 1088 Class 3. I also found these other professional suppliers - they actually have datasheets / certificate for their ply which gives the structural strength, country of original, wood species etc: Meyer / Robbins / International. There are probably a few others. They don't have prices on their websites and most likely supply wholesale only. But they have great info - apparently the best plywood is Gaboon or Sapele species from Africa and Meranti or Eucalyptus species from Indonesia or Malaysia. The glue for all class 3 products seems to be formaldehyde.
I've also seen some kind of surface treatment to the inside roof - ah yeah, one is called Grafo-Therm. Don't know how well it works. Also Absorpoles. Think I would keep clothes in one of those airtight sacks you suck the air out of.
