Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. My better 1/2 resolved a problem with Wren recently. The quartz worktop suppliers nominated by Wren came up with a stupid layout with a cut right in the middle of one of the main surfaces - halfway between the hob and the sink FFS. Both the quartz guys and Wren argued vehemently that their solution was the only one that was possible. So she found a couple of other quartz companies that did an obviously sensible layout and she ordered from one of them. Only at that point, after she had proved that a cut in the middle of the worktop was unnecessary did Wren relent and credited her with the fees they had taken for the worktop. It probably helped that she was trained as a lawyer. Not their finest hour.
  2. FYI I just found the g & U-value for Velux's various glazing options. It took me quite a while so I thought I would record it here: In short, the common triple-glazing option '66' is 0.6/.44, Slightly, better options are '62' & '67' at 0.5 and average g-values. '70' is the standard double glazed at U-value of 1.0. The 'heat protection' option '69' is an oddball with g-value (transmittance) of .27 but a not so great U-value of 0.7. This is from: Velux_GGU_Technical_Data_Sheet.pdf
  3. Anyone have any thoughts / tips re extract & supply valve positions - particularly in a vaulted ceiling room? Is there an advantage / disadvantage in having the valves high up in the ceiling?
  4. >>> but it only resulted in a 0.1Uw decrease so probably isn’t worth the extra cost That's a very good point. I just did some quick variations in PHPP substituting different Velux glazing: '66' triple glazed over '70' double glazed gave a 1.5% reduction in annual heating requirement and a 0.4% reduction in solar gain (worth about £25 a year) ... but at a 44% (£724) capital cost increment.
  5. FYI ArtisanElectrics have a video where they put PV on the curved metal roof of their new office. Probably trapezoidal rather than standing seam.
  6. @Smallholdertoo I would be interested to hear how you got on with this - I'm looking for a similar thing.
  7. Is it time for another meet? You’re welcome at my plot although I’m a bit concerned that there’s nothing too interesting there. (There’s a slab, an oak frame, and we’ve just started roofing.) Failing that, a chinwag at a central-ish pub somewhere? Other suggestions?
  8. Thanks Nick. I thought I would report back: I ended up ordering from Sheet Materials Supply and was pleasantly surprised when their marine plywood turned up. I was sure it would be Chinese, but it turned out to be Malaysian. AFAIK, Malaysia along with Gabon and a few other places in Africa produce the best of this kind of ply. So, I got a better deal than I expected.
  9. I ask because I could do with one on-hand for the geometry, but triple-glazed seems to have a long lead time. I've seen that there are some double glaze replacement sealed units available, which sort of suggests this swap might be true.
  10. PHPP is a 20-30 page spreadsheet. Pretty complicated but not indecipherable. The manual is pretty good and a good primer on relevant building physics. Highly suggest using PHPP if you’re not daunted by big spreadsheets. You may want to, or may have to (depending on your BCO) get it checked by a kosher PHPP ‘expert’. It will let you make tradeoffs on your design e.g. window schedule vs. overheating.
  11. Ah thanks - on metal roof a bit as described here: and
  12. I'm monkeying around trying to line up some Velux MK-08s in a PV array - so the exact spacing is fairly important as the Veluxes will go in before the PV. The Renusol configurator defaults to a 24mm gap between PV panels. Does that sound about right?
  13. Thanks, but both BS 5250 and NHBC seem to just have prescriptions for the common stack-ups. Go, slightly off-piste...and you're on your own. And I was trying to understand the building physics rather than find a somewhat-relevant cookbook in the relevant standard. For instance NHBC says: NHBC: 7.2.15 Ventilation, vapour control and insulation - NHBC Standards 2025 NHBC Standards 2025 Where a Type LR underlay is fully supported on sarking sheets or boards which offer a high resistance to the passage of air or water vapour, such as plywood, OSB, chipboard, or tongue and grooved sarking boards, the Type LR underlay and sarking should be treated as a Type HR underlay, for roof ventilation purposes. ... and that's kind of what I've got.
  14. If it helps any we have had some MOT 3 with quite variable composition. Some was quite chunky, some had more fines than you would expect. I took it all and I think it'll work out OK in our application - which was a permeable driveway. I've seen no standing water since, so it must be draining. I'm suspecting that as it's a more unusual material that maybe it has more variable quality.
  15. >>> Will your trades be prepared to be nominated as principal contractors? In practical terms, I have not found a mechanism to tell BC that I've swapped from one PC to another.
  16. Anyone have any thoughts on this? Ubakhus seems to have found a moisture problem beneath the outer ply. Is this a real problem? Seems to me that whatever the most outside skin is, it would throw up this problem, no? Is the internal membrane doing anything useful given that it's backing some fairly air-impermeable ply? Is this the key sentence? During the winter season of 90 days, a total of 0,021 kg of condensation water per square meter is generated. This quantity dries in summer in 5 days (Drying season according to DIN 4108-3:2014-11). In accordance with DIN 4108-3, the maximum allowable amount of condensate is 1,0 kg/m² if all affected layers are capillary water absorbable, else 0.5 kg/m². That implies it's fine?
  17. >>> get a surveyor to site to mark out the boundary according to land registry If you look at the land registry web site they say that the vast majority of the boundaries they have recorded are not definitive. Yes, they do provide a bit of a clue, but they can’t be relied on as an authoritative source. The whole area is a bit of a fudge at best. Possible to agree the boundary with your neighbour? That would be a good start. There is then a process for recording a definitive boundary with the land registry if you choose. I suspect the red lines on deeds are usually drawn in a few seconds by a junior lawyer without ever visiting the plot / looking at Google Earth / booking in a surveyor ~ and Google isn’t accurate anyway and subject to.optical distortion.
  18. I have half a memory that the EA has an escalation procedure. You might call them and see whether they’ll do something promptly for you. Alternatively, if you can get an ‘expert’ to write something acceptable the BCO might accept that. Is there someone else using the same route? - I have a few neighbours who are, so it would hardly make sense to allow them but deny me. Once I got hold of a normal human at the EA, they were quite helpful and found the details of the drainage route they needed - I supplied the gist 400 metres or so and they figured it out to the final tidal destination.
  19. We needed one as we were draining to an intermittent watercourse (if I remember rightly) - took a while as they ‘lost’ our first application. About 6 months - I’ve posted the exact time ere somewhere.
  20. Don’t know how true it is, but I was told recently that power float skills are less and less common. Some people will try it on though if they have too much business / don’t fancy the job / think you’re a bit gullible.
  21. We were working on this today. A properly anal approach, but I wanted to be able to get it out easily if there was a future problem. Very doable DIY - although it would be easier .... the next time 😁. Main issues were falls (courtesy of some earlier careless groundworkers) and, believe it or not, making the straps work sensibly. My digger skills are improving, although the original dig out was done by an experienced guy in one day. There was properly hard dried out clay that far down. The dry mix was done by hand on a piece of ply - we didn't even bother to get the cement mixer out. The perforated twinwall in the last picture is for checking on GW level.
  22. Well I'm sorry to hear that and it's a good thing that someone is taking this nonsense on. >>> after submitting a minor amendment to our already-exempt planning permission, we didn’t realise we had to send in a second CIL commencement notice I've never heard of that particular excuse before - is it possible to say a bit more. What kind of amendment and 'non-material' or 'minor material amendment' and/or a 'Section 73 amendment'? I'm interested what part of the CIL law details that gotcha? Did the LPA explain with reference to the law or did they just assert their position? I know some LPAs do make stuff up / 'have their own special interpretation' where the law is a bit vague. Was the LPA's assertion challenged by a solicitor?
  23. How big is the plot? Would it ‘make much difference’ if the dwelling was moved over a bit?
  24. The thing to watch out for is the FX rates/spread - a lot of bank cards these days use the Visa or Mastercard rates which are not crazy bad (but not crazy good) at 2% of the transaction. As usual, financial services usually takes the micky on anything that isn't written in plain English in front of you. See e.g. Currency Converter – Exchange Rate Calculator | Visa Whenever you see 'zero or no commission' that means they're trying to fool you into thinking there is no transaction charge. Some people call that 'lying'.
