Alan Ambrose
Everything posted by Alan Ambrose
Ah, welcome back @GaryChaplin how's your build going? On the subject of new people, I'm seeing a small number of local applications approved for self-build, maybe half-a-dozen in East Suffolk in 2025 - should I contact them?
@G and J - walked past your place after a sunny breakfast today. You must be pleased at the speed it’s coming along. Yeah understand the pressure to keep moving. OK straw poll peeps - who can make next Thursday?
Where are all the Blown Cellulose Installers?
Alan Ambrose replied to SBMS's topic in Heat Insulation
>>> is it membrane or board It's board. Has nobody used wood fibre recently? -
Anyone have any recent experience with blown-in materials? Quality, price, suppliers etc? Also is there much to choose between cellulose / wood fibre / mineral wool? Anything to look out for like ensuring full fill? We have a roughly 50 m^3 new posi-joist 30-degree roof to fill. -
Probably not too hard, but you’ll need a Hetas-qualified person to move it. Some flue work, refix the seal into the stove, ensure there is a hearth of the right dimensions and correct distance from anything that can burn. You have a CO alarm? It’s just possible that they need to ‘re-install’ to modern regs, which might make it tricky. Easy enough to get a Hetas guy to give you a quote?
Ah, maybe we should chat about the next meeting for the last 5 mins of the previous one. Does next Thurs work @G and J?
@Gary Martin - can I ask - was there are residue or other weirdness after the Aero Barrier guys left? What stage did you call them in? After painting maybe?
Next Thurs maybe?
@Mike - I was meaning here (below) and yes, the MVHR calcs say a 180mm diameter vent (i.e. 25,000 mm^2) gives 2.3 m/s on boost and the UB19 is 22,000 mm^2 - so 'close enough for government work'. @Kelvin - that's clever, but we don't have any waste running from the garage, and it's also some distance away.
To avoid collision with my PV panels and Velux windows, is there any reason why I shouldn't put my MVHR external vents under the gable soffits using terminals like these? Ventilation Tile UB19 Slates 500mm x 250mm (NJ) Anthracite | Ubbink Also, can I use these, this time on the top of the roof, for SVP vents rather than 110mm pipe? For various reasons, mainly aesthetics, but again I want to avoiding shading my PV panels.
24v lighting circuit - good or bad idea?
Alan Ambrose replied to SBMS's topic in Networks, AV, Security & Automation
The subtle thing about higher voltages and LEDs in series is that one failure with bring the whole string / light down - so you’re looking at a shorter lifetime. -
That’s quick - what kind of appeal, and was that 7 months from file-to-result or from ‘start date’ to result. My gap from file to ‘start-date’ was 4 or 5 months from memory.
Ah yes, I ordered a set in - the mid-clamp is indeed 24mm. I'm not that impressed - the clamps don't slide along the rail easily. I guess they will using a rubber hammer or some such. Seems a pity as the aluminium rail itself is good. Anyone have suggestions re better fixing PV systems for trapezoidal roofs?
I’m using PHPP to calc Uw so I just needed the glazing number. Point taken though - the glazing may make inconsequential difference to whole house numbers.
Ubbink - what are they like?
Alan Ambrose replied to lizzieuk1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@JohnMo - this kind of thing for multi room? https://www.abilityprojects.com/fan-coil-units?gad_source=1&gad_campaignid=22492647782&gbraid=0AAAAA_dPIDvt0GTJyd8qM3Coah64cNGF4&gclid=EAIaIQobChMIuYasioPPkAMVepNQBh1NuhvrEAAYAiAAEgJza_D_BwE How does the ducting compare to MVHR? Much bigger? -
Next Thursday maybe? I think IP14-ish is vaguely the middle of our little group? The Bull at Bacton or Debenham Lion?
Be careful re planning amendments and CIL. But congrats on getting the permission - and there’s wealth of info here on just about any self build subject. A picture of the current building maybe?
LEDs are current-driven devices (they’re diodes, of course, so ohm’s law doesn’t apply) - so as long as you have enough voltage greater than the forward voltage of the LED (string?), the voltage drop should be irrelevant. -
Planning and appeals
Alan Ambrose replied to Gary Martin's topic in Lofts, Dormers & Loft Conversions
Similar, but I would maybe put in the NMA anyway to avoid the hassle of arguing with enforcement. The LPA know what’s going to happen if they refuse it. And congrats for standing your ground with them and winning.
