Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. A bit nonsense that the BSI standard is so expensive, but funnily enough it's available on the Warrington district's site for free: https://www.warrington.gov.uk/sites/default/files/2020-08/cf54_bs_4142_2014_a1_2019.pdf All that mumbo jumbo (somebody has really gone to town) means essentially measure the background noise level and then with the heat pump running. Obviously the heat pump can't add too much, otherwise it's 'officially annoying'. Essentially you're just measuring how much the sound level increases when you turn your heat pump on. Not sure you really need some consultants for that - it would be good if you can just use a cheap sound meter or even a phone app. Maybe if you can provide a graph like in the BSI doc then you'll be good.
  2. If you google the code you gave above you might (after a couple of jumps) find the same number as me for that product: that is 7.35 kW. Max for a UK plug is about 3kW, and actually 3kW often doesn't work too well if either the plug or socket isn't high very quality - you can get arcing and heat. In principle you could do it and expect the 13A fuse in the plug to blow if you used more than one ring/zone. But I wouldn't. I'm sure a qualified electrician will be along in a jiffy, but the 'right way' of doing it would be a dedicated circuit to the consumer unit on say 20A or 32A wiring / breaker and out to a proper cooker-rated switched spur with the hob directly wired in. Or just buy yourself a single/double zone hob less than 3kW.
  3. Well this is all very curious given that, in my experience, the BH forums are generally very helpful and people here spend a great deal of time and energy making their knowledge available in a very generous way. The question, as stated, is obviously winding a few people up for reasons I can't quite figure out. Maybe the subject of planning itself just puts everyone in a bad mood... I won't inflame further, but will post any info I find on the subject (if I find any) for other people to find later. That could be me when I've totally forgotten about it . Thanks for everyone's responses though.
  4. I can't see anything wrong with your calcs. I did something similar to this calc a few months ago for an existing property i.e. I have some reasonable energy usage stats. I came to these tentative conclusions (some or all of which might be nonsense) : + until Ofgem make the feed-in a proper % of the standard rate, selling the surplus is not worth the bother. + a HW diverter is a fairly simple way of using a lot of the extra generation. + you can always add the battery later if the cost/benefit is good. + even if you have good projected usage and generation stats, the sizing calcs are a bit iffy - there are just too many assumptions. The key assumption, of course, is electricity prices going forward - hopefully things will normalise a bit once the Ukraine war is concluded. But that implies the payback will be longer + ideally you could add single panels at a time to your model - until the incremental payback of the extra panel was longer than you could be bothered with. In my case (12 panels/6.5kWp is the max that will fit on this roof) I came up with these calcs: + but overall I decided that the panels themselves are fairly cheap and you might just as well fill the roof while you're about it (even if you don't use/install an inverter/battery to cope with max. panel output). That is, the fixed cost of installation is high enough that you only want to do it (that is, the bit on the roof) once (except that you might start with a smaller inverter / battery etc. if funds are tight). That might mean asking for something a bit more custom than the usual packages that get sold. You can probably change the electrics inside without much bother/cost later if needed. At least I can - since there's an easy / substantial / flexible attic space to use and easy to access. As I said - these conclusions might be nonsense , and they might be too specific to my particular situation for anyone else to draw any conclusions from.
  5. >>> So you haven’t even submitted your application yet? The thread is about ‘how do I find out what my local planning situation is like’ rather than a particular application - a subject presumably of interest to BH members. @DevilDamo - Am I right in thinking you’re an ex-LA planner and/or planning consultant? If so, can you give us some pointers on how we figure the local environment as clearly not all LAs are the same?
  6. >>> Day night shift of 1-2 kWh hotel loads is the most that should ever be cost effective Possible to explain a bit more?
  7. I’m surprised that your architect is making a fuss about this - especially for a clad house, which makes the solution v. easy as you’ve shown. Just make the main door more prominent and the dog door more blended in. For the dog door one or more of: clad it / match window profile / diminished door furniture etc. Highlight the main door with one or two of: lights either side / pots either side / doorbell / knocker / more prominent features or finishes / external door mat / highlight the paving and/or planting. Essentially you’re just trying, for visitors, to make one look more likely to be the main door than the other. You can call this ‘affordance’ or ‘design cue’ and then you can (a) charge yourself twice as much and (b) encourage your architect to get a grip. If you want to be cute, you can even impose an outline of a dog or something else doggy somewhere on/near the dog door. I would also find some more suitable I.e. paw and claw resistant surface materials for the dog room so it doesn’t deteriorate so fast. Plastic / metal sheathing / coir maybe. I don’t have a dog, so dog resistant materials are not something I’ve thought much about. Alan
  8. >>> Isn’t east Suffolk one of the better ones? Surely the higher the % within 8 weeks the better? As I said - I was just showing the bottom 10% of the table - there are 294 local authorities out of 329 that do better than East Suffolk. Follow the link above and you can see the whole shooting match. >>> It looks like they determine 74% within 8 weeks. Yeah it might look like that, and you might hope that the other 26% were getting dealt with in, say, 6 weeks. But that's not the case. Does anybody know if there are some more granular stats around? For instance, I see https://www.planningportal.co.uk/ is something 'run by TerraQuest Solutions Limited and Department for Levelling Up'. Presumably they should have some numbers? Alan
  9. Just to add extra annoyance ... E.On Next (such a stupid name) email or text me once a week with the 'smart meter come-on': We know you’re busy, but we haven’t heard from you yet about fitting a smart meter for you. When I fall for it, they ask me 8 questions, think for 10 seconds and say 'nope'. As a systems guy I hate the bugs in all these systems, so f.....g careless. I have have found bugs as in 'system not functional enough to be able to get it to do something simple' in HMRC tax, Taxcalc, this, and Royal Mail on-line postage purchase over the last couple of days. And I'm pretty good at working around stupid bugs in on-line systems. There's not even an easy way to submit bug reports for any of them. Alan
  10. >>> But a house is much slower time constants, hours not milliseconds, so to do the same with the heating system in a house would take days. More akin to tuning the heating system on a furnace to get to desired temperature as quick as possible without overshooting. OK I'll give it a go at some time and see whether I can figure any results. I have Heatmiser to measure the temperatures / Bright to measure the total energy input / and maybe I can pick up some solar and wind data from somewhere. Alan
  11. OK I'm leaning towards the 'drop down from service void above' (I guess that could also work 'from below' if you have a basement) and 'duct/flexible conduit' solutions. Of course, cable trays are used everywhere in offices for this purpose. Maybe there's a way to build them into the walls at socket height. Alan
  12. >>> @Mr Punter - East Suffolk seem to be taking about 3-4 months. Probably typical. Can you actually see the planning delay stats somewhere or is that a single data point? >>> @DevilDamo - What’s the reason for you not having Appealed as a result of non-determination? Well I'm looking at existing application delays with a view to 'planning my planning application'. I was just looking at my neighbour's application. In my investigations I came across these (not very readable) stats: https://www.gov.uk/government/statistical-data-sets/live-tables-on-planning-application-statistics Table P153 'district planning authorities performance - speed of non-major decisions' seems to be the most relevant: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/1125509/Table_P153.ods I can see East Suffolk is 295th out of 329 i.e. in the bottom 10%. The others at the bottom are as below. I also found out that planning departments can be in 'special measures' although I can't see a current list of those anywhere. I did find this 2020 list though: https://www.planningresource.co.uk/article/1690460/authorities-danger-special-measures-designation-poor-appeal-records Alan
  13. >>> It’s got nothing to do with building control I was meaning BCO love plasterboard for fire reasons. >>> What have you against plasterboard? It's crumbly cut-once stuff. If a 'professional' had done the wire pulling job I just did - for time reasons they would have made a swiss cheese of the plasterboard and roughly patched up the holes. That's fine - until the next time. >>> I would do it like on the continent with a large duct that I can pull new cables through. Like a square plastic ventilation duct? Or a cable tray kind of thing? Alan
  14. Mine (East Suffolk) is taking a year to do simple non-contentious single dwelling stuff atm. From their org chart, they seem to be fully staffed and I can't imagine a huge increased in demand for their services as there's so little building land available. They seem to be getting back responses from the various consultation bodies reasonably quickly and then just sitting on the applications. So much for ... the statutory determination period for validated planning applications, which local planning authorities should not exceed, is 8 weeks. https://www.designingbuildings.co.uk/wiki/Planning_permission_-_how_long_does_it_take Did I miss something? How are other local planning departments doing these days? Alan
  15. Hi, In our 'old build' I have been running some new cables over the last few days in a crazy awkward place behind a consumer unit (as it happens) and through some metal studs and voids containing properly itchy fiberglass. Super time consuming (unless you want to hack the wall to pieces) and annoying. Also some of the plasterboard had already been hacked about a bit and some had gone a bit soft in places (or was that just me). So the finish leaves a lot to be desired. Well it reminded me that in our 'new build', I would really, really, really like (a) to have a proper service void that I can pull new services through easily when needed, and (b) walls clad preferably with something other than plasterboard. I know that's ... unconventional, BCO will hate it etc. But somebody somewhere must have figured out (a) a better approach to service voids; (b) not expecting all services to be 100% designed up front and stay like that for the life of the building; (c) an alternative to plasterboard. Alan
  16. >>> One other point, my property deeds state that I have now right of easement. Can it be assumed therefore the Neighbours would say the same please? You don't say over what? Probably not safe to assume unless the buildings are similar and built and sold at the same time. >>> They said I have to take their rainwater by virtue of easement, and since the arrangement has been in place unchallenged for >20 years it has to remain. So ask them to produce the easement as proof together with the original plans. It would also be useful to ask the BCO why they think the neighbour's gutters should be capped. Get the answer in writing (an email will do). Ask the BCO nicely 'as you're getting some pushback, if they wouldn't mind informing the neighbour in writing of their decision'. >>> The builder even commented on the black soil whilst excavating for the foundations. Your builder? Ask them to send you an email with their opinion too. There are two basic directions - either design to take your neighbour's rainwater (probably not a big deal) and forget about it. Or, call the bully neighbour out: write them a letter saying that you have proof their drainage wasn't built to spec. and is causing a nuisance. And you will be fitting your caps as instructed by the BCO. They should take the matter up with the BCO if they disagree. Alan
  17. While cellulose has low embedded energy, I think I would go with Rockwool for its fire and damp behaviour. It'll be boxed in, so the ongoing irritant factor will be negligible. Alan
  18. >>> I don’t think any insulation manufacturer would market a product that was inherently dangerous to health either in its install or use. Ha ha ha, ha ha ha, ha. Grenfell maybe? Asbestos was only completely banned as a building material in ... 1999. The building I'm in right now has 50mm of (very flammable) expanded polystyrene in the walls and it was built in the '90s. The manufacturer is still selling this as a building material. Maybe you were being sarcastic. Alan
  19. Ah, interesting discussion as always on BH, Thanks for the pointer to 'co-heating test', I see e.g.: https://www.designingbuildings.co.uk/wiki/Co-heating_test https://www.nhbcfoundation.org/wp-content/uploads/2016/05/NF54-Review-of-co-heating-test-methodologies.pdf I guess I was thinking similar to ProDave - to verify that the actual build was close to the design calcs. Also, to measure the actual numbers for buildings where you don't have the original design calcs (or buildings old enough that there were no/minimal calcs). I have a couple of those and I would be interested to see what the numbers look like. The results could be used as an input to 'non-AI' heat controllers (a 'building model') for better temperature / energy optimisation. Good points about air movement, solar gain, thermal mass etc. I'm thinking that you could actually measure wind and solar inputs and distill down the answers by regression and/or simple AI (actually I see that's what the NHBC researchers did in their analysis). Also a good point about taking out the thermal mass effect by aiming for steady-state. The SAP and Passivehaus calcs are static ones and. in time (maybe) you could build up a dynamic model. Curiously the NHBC paper suggests that in some circumstances they were able to get within 4% of the SAP calcs. I've never thought of SAP as particularly accurate, so that surprised me. Alan
  20. Hi, Am I right in thinking it should be pretty easy to figure out whole house U values and even some room level U values by blipping the heating with known heat inputs (e.g. on full power for a few hours) noting the outside temperatures and observing the inside temperature response curves? Alan
  21. Interesting. I see that working on metal seam and maybe slate. Wonder where the connections are? Alan
  22. There's some downlighter insulation thingies that might be useful. Not seen any that install from below, but it's not impossible. If working from above: this kind of thing: https://www.wickes.co.uk/Loftleg-Loft-Lid-Downlight-Protector-Hood/p/148851 ... and then patch the insulation and membrane? Alan
  23. From the PMD 7 manual: Manual Calibration If the signal LED 2 illuminates red or yellow, even when no metal is in the vicinity of the measuring tool, the tool must be recalibrated. – To do this, switch the measuring device on using the On/Off switch 3. – Remove a battery from the switched on measuring device. – While the battery is removed, switch the measuring device off using the On/Off switch 3. – Reinsert the batteries into the measuring device (pay attention to the polarity!) – Now remove all objects in the vicinity of the measuring device (including wrist watches or rings of metal) and hold the measuring tool up in the air. – Switch the measuring device on using the On/Off switch 3 and off again within 3 seconds. The signal LED 2 of the measuring device will flash red in slow succession during the 3 seconds to indicate that it is ready to calibrate. – Switch the measuring device back on within 0.5 seconds. The calibration is initiated and takes about 6 seconds. The signal LED 2 will flash green for 6 seconds in quick succession, the calibration is being performed. Now the device is once more ready for operation and the signal LED 2 illuminates solid green. Note: If the sequence of switching off then on again is not followed, no calibration is performed. The signal LED 2 remains either yellow or red, even though no metal is located within the vicinity. In this case, repeat the calibration.
  24. Ahhh, I just chucked a Bosch PMD 7 - it never worked reliably. Occasionally I could find a metal stud or a cable, but more often than not it just went various shades of loopy. Read the manual a few times (such as it is), was careful to give it an 'earth' etc. >>> Yes I nicked the cable A Wago joining kit or two and you're good. I would love to find a reliable cable/metal finder. Maybe a borescope would be more useful? Alan
