Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. >>> Of course this places greater demands on the environment being clear of obstacles. I see that PVGIS has a feature to handle that if you're a proper nerd - which I guess I am. >>> Also worth noting that if you plan to export at current rates (£0.15) it tends to dwarf any other small optimisations to just maximise total generation. Just go with South/40 degrees and you're done? You bring up an interesting point though which is that given export is worth anywhere between 2x and 6x less than reduced import, then we should focus not on summer peak but maximising the other seasons? Below are graphs from PVGIS of generation by month and generation by season for various roof slopes (all for a south facing roof). The concussions are: + for max total generation roof slope of 30-50 degrees is good. + for max non-summer generation, slope of 40-60 degrees is good. + if you weight the value of the winter electricity (to account for better value of those units), 40-50 degrees is good. Maybe I didn't discover anything new - except maybe a slope of 50 is a bit better overall than a slope of 40. Alan
  2. >>> vertical mounted panels Ah, interesting ... PVGIS gives this for south facing vertical. Although 27% less than the optimum 40 degrees pitch roof, it has wider 'shoulders'. Alan
  3. Depending on your DNO it may be very hard or slightly less hard to get them to move the pole at their expense. The bad news might be expensive. It does look pretty end-of-life though and the stay isn't doing anything - you could ask how old it is and when it'll be coming up for replacement. Or what would happen if you report it as unsafe. Which DNO? Alan
  4. Ah, it occurred to me that there are two other practical difficulties with 3-phase: + it's hard to get a 3-phase smets2 meter installed - see e.g. Octopus 'no can do'. + 3-phase also makes PV install and battery much more expensive and probably less efficient. That's because (a) you'll probably need 3-batteries and 3-inverters etc, and (b) you'll have to balance all the house loads (which are nearly all on single phase circuits except maybe GSHP and high-power instantaneous water-heaters) against the PV / inverter / battery set-up on those individual phases. Alan
  5. >>> if you split SE/SW you might see some extra benefit See below - the same thing with SE+SW. So apparently not much benefit in deliberately splitting the roof orientation away from South. But ... less harm of course in doing SE+SW so as you only lose 1% / 8% / 16% of best case Southerly output in Summer / Shoulder / Winter respectively. Numbers for straight E+W are 6% / 25% / 49%. >>> If you're looking to size a battery Yeah, for battery I need to model daily consumption data plus some indication of the variation in generation. Alan
  6. Hi, I've been fiddling around with PVGIS daily data vs. roof orientation - actually the objective was to get an idea of battery sizing. This is for East Suffolk, 30 degree roof pitch. I think I've figured out that ... if you have the option ... that south facing panels really are better than split East/West panels. Maybe that's not a surprise, but I was assuming/hoping that splitting East/West would be very handy in order to flatten and widen the output curve - which would provide more useful power. Well it looks like it does a little bit in summer, but in spring and autumn and winter it seems to not help at all. See below: Alan
  7. >>> I can piss faster than the hot water comes out of that btw. There will be some members on here, including me, that can't Interesting thought, not crazy expensive ... and has the advantage of being fairly straightforward tech. Alan
  8. Ah, that's interesting - I hadn't seen that product. A stretch to get the ducting to the outside but may be possible. I see max 20m of 160mm insulated straight ducting or less if it has bends. Claims 33 dBA. Has a separate immersion for backup. Funnily enough, my downstairs neighbour contacted me to see if we 'had low water pressure' yesterday - I think he probably meant flow rate. But that leans towards keeping the pumps. Maybe there's some fancy cold water accumulator / pump which would guarantee pressure for the unvented Dimplex product. I can't imagine who specified this set-up originally - this was the early 90s - 400L of cold plus 300L of hot plus 3-phase power ... in a 3-bed flat. Alan
  9. OK thanks interesting. Heat pump isn't possible as although there's a small patio, it's nowhere near the cylinder and linking it up would involve ripping the flat apart. I think I'll see if I can get a pressure data logger and then proceed down the well-insulated 'vented without pumps' or 'unvented cylinder with pumps' as required. Alan
  10. >>> my equal parts loved yet maligned PoE powered toothbrush charger) Love it - somebody has to Thanks for taking the time both to describe your set-up and your thoughts on (not much) improving it. That's where this forum is so great. Alan
  11. Apologies for yet another tank question. My objective is to get a more energy efficient set-up. In my 5th floor flat there is a 30-year old vented set-up. It has two big custom made cube-like tanks (almost 1m cubed each) tight in a cupboard and two Stuart-Turner 3 bar twin pumps (hot and cold) for pressure - one for each bathroom. (Some time, way back, I had a second one installed so we could shower even when one pump failed.) The upper vented cold tank is about 1m off the floor and there's a hot tank underneath, with thin-ish insulation and heated by two immersion heaters. (This was from a time when designers were scared of gas in flats and the flat has electricity only.) The incoming pressure is about 1.5 bar and I'm not sure whether or how often the mains pressure dips under that, but my upstairs neighbour has been having some trouble with mains pressure. I've applied a bit of extra insulation to the hot tank but it's not possible to get all around it and the temperature still falls off quite rapidly. (I've a Heatmiser system and can see the temperature fall-off quite easily and accurately.) I know the fall off is much faster than another more modern unvented set-up I have data on. There are some fancy taps and shower fittings here which need a minimum of 1.4 bar. So the question is, how can I get a better insulated system without risking dodgy water pressure? The options seem to be: (1) Replace with a more modern vented set-up with immersion heaters and keep the pumps. (2) Replace with a more modern unvented set-up with immersion heaters, lose the pumps and take the risk on low water pressure. (3) Go a bit off-piste and use something like a 12KW Heatrae Sadia electric boiler, lose the pumps and ditch all the tanks. Take the risk on low water pressure. I think a downstairs neighbour has something like that set-up. Any thoughts? Alan
  12. @joth - so you have radial 12V, 24V and 'active' PoE into each room? Goodness 'PoE' seems a mess atm. Did you consider 5V for charging or is that a step too far? Any recommendations gained from your experience of doing all that - or is that just the best solution? Alan
  13. >>> What do you mean by centrally switched LED lighting? Something similar to joth's set-up rather than direct mains light switch -> light bulb wiring Yeah they need to work, but Quinetic switches which sparkys are using to avoid tricky cable runs are part way there. Loxone more so. Alan
  14. Well you always get good answers from this forum and often from a number of perspectives. I'm planning on running CAT cable everywhere which I guess means PoE everywhere, also centrally switched LED lighting, also sensors etc (e.g. Heatmaster) on radial circuits - all back to a plant room. I'm sure there will be PV batteries - maybe in the plant room, maybe not. So, that seems halfway there without trying... Alan
  15. That sounds interesting, is it possible to describe a bit more? - central PSU for 24V? - PoE from one place only? - what kind of wiring / cable / fusing etc for the 24V? - you have your LED strips all wired back to a central smart switch somewhere? TIA, Alan
  16. It seems to me we'll have more and more extra low voltage (5-48V) stuff as time goes on and I'm wondering whether anyone has considered wiring all over for that as well as 220V? There is a bit of thought here: https://www.theengineer.co.uk/content/product/dc-energy-metering-applications and https://www.mdpi.com/1996-1073/11/9/2463 which suggests maybe a 20%-ish saving. Particularly helpful where we already have 48V batteries for PV? Any thoughts? Alan
  17. Yeah I can see the 'more is better' argument for 3-phase - more amps innit. But... + 3-phase is harder to monitor if you're into circuit-level power monitoring. Not impossible, just more expensive and fewer options. + the electricity companies are not really up with 3-phase domestic. Ask me how many meter-replacement men turned up here with single phase meters here (two). Once I got their boss out, he actually suggested I could usefully convert the property to single-phase. Duh. I imagine I'll wait until all the single phase smart meter roll out has happened before anyone asks why the remaining properties haven't got smart meters yet. Hmm, why would that be? + the whole idea is to be using less energy, not more . I have 3-phase where I am now, but I'm planning that single-phase will be fine for my new build - because it'll be 'new overhead line time' if I need 3-phase. Alan
  18. Building control are usually quite happy to answer any questions in advance. Alan
  19. Maybe find something vaguely similar on Etsy (say a light made with similar materials) and see if they'll custom make what you want? This is for your western-themed parties? Alan
  20. Hi, Yeah, for work done in the last 10 or so years (i.e. since the DNO was established) there should be docs. For work beforehand, my understanding is that there may have been no docs (I'm talking LV / 230 or 400V) or that the docs might have been lost in the mists of time. Here, the latter is the case i.e. no docs. Alan
  21. Hi, I have a question re re-routing overflying cables. But it boils down to this: ‘does the DNO have rights to enter a neighbour’s land to inspect the DNO’s poles & cables?’ Could they, for instance add a new stay? I’m pretty sure the DNO can’t find the existing wayleave agreements - even if they once existed. In fact they probably couldn’t find their own … well never mind. TIA, Alan
  22. Thanks Chanmenie, >>> Company called Subteno From their website, they look like proper engineers . >>> but I do completely understand having someone local to oversee things and if there was a local SE that specialised in insulated slabs maybe I'd have given them an opportunity. but, as with a lot of things in the building game, that's not how they've always done it and so I didn't find any. Understand - I've found that once you start looking at more specialised skills, there may only be one or two in your county - and that's if you're lucky. Alan
  23. Call it belt and braces, but I would much rather the SE attended site once or twice at the critical phases to ensure that what is being built is what he or she intended. I'm seeing a few comments like this on buildhub, so I'm not alone: >>> A few hundred pounds spent with a local SE, who knows the ground conditions in your area would be money well spent. >>> ... included two sites visits after trial holes were dug also included drainage design. So, I'm not alone. Alan
  24. @Thorfun - I see a lot of people are happy with TSD. I wonder how any SE signs off on the build though if they don't observe the construction? Also, since it's much harder to sue a foreign company, what would you do if there was a major problem later? Or am I worrying too much? @Chanmenie - Yeah that would be great. Thanks, Alan
  25. He he he, loved the video of the suspended digger Batibouw Trade show in Brussels sounds good. Alan
