craig
    5
Everything posted by craig
  1. We ask for 50% upfront, simply because we refuse to take a credit arrangement with our supplier, they require full payment before releasing to the logistics team for transport. So we ask for 47.5% 3 weeks before arrival to site. It’s a lot of money but we offer guarantee of supply from ourselves, insurance and confirmation money has been transferred via our currency supplier. It’s not a lot but depending on order size it can be anywhere from a couple of quid to a few thousand into the tens/hundreds of thousands as a 2.5% retention. We are just changing our installation to 100% on the day installation commences. Then the 2.5% upon sign off. We’ll attend back for any window related or install related issues without question. Any visits after the first year (i.e adjustments), will now incur a call out fee.
  2. Be careful, if your looking at using them, your building control officer is unlikely to sign them off. First, check you’ll get approval from building control officer, 2nd your insurance company and 3rd they’ll work with the windows.
  3. You’ll need to make an enquiry, sorry. Here is not the right place. Apologies, hope you understand.
  4. Electric, one cable coming out requiring a 3 gang switch.
  5. This is external venetians (roller shutter exactly the same) on a project we did, completely hidden box and in a conservation area. Planning was rejected on several occasions. Options exist for them from a few suppliers.
  6. I’m sure we can find a solution ?
  7. They aren't certified, they are PH suitable. Not a bad thing, as long as the values can be proved. Others also supply PH suitable bi folding doors but Lacuna are not certified.
  8. It's easier to have them planned in from the offset. The boxes generally come in two options that the motor and the venetian blinds/shutters sit in and varying heights dependant on the window height. If retro fitting, you only really have one option, which is front facing of the box. This is simply due to the fact you cannot conceal the box. If planned in from the offset, you can detail the box to be completely hidden. With some models you can retro fit them but you need to have the relevant depth from the window to the external wall to house it. Your likely going to lose 150mm/200mm + at the top of the window/glazing, due to the box.
  9. Who is the window company? What is the model of the bi fold door? Is there section details available on their website or the manufacturers website?
  10. Seconded, a nicer neater finish.
  11. I appreciate that and acknowledged that in my initial response.
  12. Not wrong, I order of drawings pretty much every day. It’s rare for any opening size to be wrong, as long as all parties communicate before the timber kit/window order is raised nothing “should” go wrong. As others here would testify too. There is a few occassions when site measurements would be required but in general not required at all.
  13. Any aluminium supplier, your best fitting the windows then taken the flashing measurements (just for safety/costs). You’ll get them in any ral, let them know whether gloss or matt finish.
  14. It isn’t always necessary to come and measure and can delay build progress, that’s just wrong advice to give and probably based on your experiences for which I’m sorry you have endured.
  15. Ignore the fact that the drawing shows a supplied corner post, the priciple is the same. I’ve assumed Auraplus? It doesn’t have grooves on the cladding and this detail shows a return on the cladding creating a shadow gap. The principle would be the same for using your own post. If your not comfortable with the depth, rather than returning back onto the post and fixing, you could return it behind the cladding of the fixed jamb. You could also have it sit slightly prouder and then fix it ontop of the fixed frame cladding.
  16. Does the aluminium cladding on the windows have a groove running vertically for a 2mm thick aluminium flashing to fit? If not, not a biggy you can detail the flashing in, whats the dimension of the timber post? Where at the windows sitting within the opening and can you insulate behind the flashing? Do you have a detail in PDF/DWG? Would be happy to draw up a detail for you. What window system are you using? More importantly, are they fixed/T&T/casement/sliding etc?
  17. Generally speaking a site measure is not needed as the sizes are confirmed with client/architect/timber kit supplier. All detailing should be done this way as well. If angled windows or wrap around window/rooflight etc. are required then we suggest a site measure. The issue with a site measure is that it adds time onto a build and delays the build getting water tight.
  18. It depends, I lost a job recently because of this reason. We have a degree of flexibility but only a little. The job was £32K, rationel came in at £29k. Bit of value engineering and negotiating we came in at £29k Rationel dropped price for supply only from £25k to £18k at the drop of a hat. Sometimes you just have to walk away and question how much they are marking up in the first place.
  19. Nothing ventured nothing gained, go for it. You’ll have a blast. If it doesn’t work, all it has cost you is time and maybe some pride. A little bit of unused ply/osb to step on, unused carpet and you’ll have the making of a permanent staircase ? If it works (I’m sure it will), then you have gained a staircase and others have gained easy access to the second floor. Good luck, look forward to seeing them.
  20. Sorry just seen this and may have already been dealt with, we use two companies for aluminium paint repairs / recovering. Spray Clad & Magicman, both give 10 year gaurantees on the finish and will colour match.
  21. CT1
  22. A recent survey we did External measurements Width: 2550mm Height: 2110mm Internal measurements Width: 2520mm Height: 2065mm Order Size: Width: 2530mm Height: 2100mm This was achieved by measuring external size in 3 places and using the smallest, repeated inside and then deducting 10mm from the external measurements. Always measure from underneath the external sill.
  23. http://www.securedbydesign.com/wp-content/uploads/2014/02/SBD_THSG_1627_March_2013-2.pdf Page 65 of 72
  24. Have you tried Grauthoff? I know the Grauthoff doors, something we looked into a few years back. google grauthoff doors uk?
