Alexphd1
Everything posted by Alexphd1
Porcelonsa is one of those brand with a high rrp but always big discount to be had/negotiated. I was disappointed with the Edinburgh showroom. Where are you located?
Our raft is a wee bit different with eps insulation under the concrete. I wouldn't sit the doors direct on the insulation we have eps300 (cant comment on the tougher stuff mentioned above). On the second house we will be using angle steel beam cast into the concrete raft sitting over the eps raft upstand to the sit the doors farther out in the insulation compared to build 1.
DIY ICF Construction - Bracing
Alexphd1 replied to Conor's topic in Insulated Concrete Formwork (ICF)
I have no trade connection or own a icf company, I am a fisherman. I wanted a system I could build myself and as it is a large build, icf was the best solution for me integrated with a diy insulated raft. Timber frame costs where ridicules for us by the time you added in the steel work. Single block with ewi would have been a good option but decided against it in the end. A heavy insulated air tight house without relying on taping plastic sheets was also a attraction which is easily achieved with icf on the principle fabric first approach learned on here. Future proof is a tricky one, I have came to the conclusion there is no such thing it's just snake oil used by salesman pushing expensive systems but we have build everything with ease in mind for future. Large eaves upstairs we can drop new cables down 2 inch gap on icf wall (2 inch batten between icf and plaster) steel conduit in block build garage that goes direct into the large eaves. Large easy to work areas for mvhr, ST station etc. We even looped every individual PV panel into to the loft space so if one panel fails we can loop it out pretty easy. As for the need to add a extension we have tried to design that out at the initial design stage. Agree with Gus on the over brace option but blow outs on icf is not uncommon although thankfully bracing falling over is. A blow out is not the end of the world and can be fixed during the build (we didnt have any blow outs with nudara icf) I strongly recommend anybody considering a icf diy self build, visit as much sites during concrete pour day as possible and learn some good practices ie small constant pour lifts is better than just holding the nozzle in one bit and filling to to the top. -
Hi Galvtheouch, I dont see any mention of basement in your post above so will ignore that. The external coating ie render, cladding etc is your waterproof layer in a above ground icf build. Icf basements is a total different ball game and there is many existing threads on this. I am building (build 2) in Scotish countryside and a diy icf selfbuild basement not only adds up financially but utilize the site to the best layout for me. No problem in doing what you suggesting a guy on this forums predecessor ebuild done exactly that on the outer hebrides. He bought a self loading 1cu mixer and self mixed all the icf build himself. Dont underestimate the workload though he questioned in the end if it was worth it think he would have done single block on side with EWI if starting again. Not sure on the practicalities of ordering a load of premix then using a digger with concrete pouring ladle set up, you need good control for firing the concrete into the 150mm gap plus the time to use use the full load you could end up in one big mess. To hire a concrete pump for a day 700-800 pounds and premix will be mixed to consistent standard. You could cut weeks of hard work from your build. Is it worth the hassle? -
Irregular window/door spacing in ICF
Alexphd1 replied to gavztheouch's topic in Insulated Concrete Formwork (ICF)
No problem with icf for your drawings. Build number 1 almost finished with icf and will be starting build 2 v shortly with ICF. -
Does anybody know how much of a price increase on September 4th there will be?
We bought a second hand spit p370 from fleebay. Been faultless and should resale for what we payed for it. 3 cartrdges for firing into different materiel red being the strongest. Also note this can be a very dangerous too in the wrong hands! Never had a issue with spit cartridges bought online.
Carrerhill, yes 25mm is ordered for live and neutral (you could argue 16mm would be enough) but I will be running in 16mm for earth as that's what's already in (meter tails) plus its £14 cheaper (on earth cable alone) which is a few extra pints for me when I finally go to the pub. You must have a better supplier than me, hes £1 per meter more expensive between 16 &25mm.
If they are single i would go double, if double i would go treble panel. If going going single to double (double internal fins) it doubles the surface area so double the heat output.
I am looking for some framless internal glass doors, does anybody have any good recommendations for suppliers.
I will be 100% honest and say I dont know exact answers, although I am a ex heating engineer it was more a case of stick in a gas/oil boiler bigger than needed and the jobs a good one back then.... there is better guys on here to answer that questions. Only reason we went for a TS is it's near impossible (legally) to mix a UVC with a solid fuel system. A 500l UVC heated to 60 degrees will del 500l of water @ 60 degrees then a temp drop pretty quick when hot water is empty while a 500l TS heated to 60 degrees will (roughly) deliver water at low 50 degrees then start slowly dropping instantly until the tank is fully empty. But remember a shower is usually approx 37 degrees so you have a fair bit of HW before water no hot water left.
We have a mixed system consisting of 2x 500l stainless TS, 22kw log gasification, 8kw ashp, 8m2 solar thermal, 6kw PV. We haven't commissioned it yet. It's a very complicated and would be expensive install (my father and myself are ex heating engineers) and the material was sourced on the cheap ie ebay and buying the log boiler in eastern Europe (kotly.com). Its designed to keep as much load of the heat pump as possible but the weak point is the TS needing a higher temp than a UVC. I would personally forget OSO and look at Telford tanks. Remember you can put a heat pump coil into a UVC and not use it and add the heat pump in later.
@Carrerahill I agree with you 100% if in doubt go up a size with cable but the cost difference between 16mm and 25mm earth is £14 (13 meter). Its not going to brake the bank but I am not throwing money away unnecessarily plus its easier to work with.
Nick. If your speaking about 3 core 25mm SWA then I think it would be a PIA to install esp around bends.
I haven't seen 3 core 25mm, that would make life v easy.
Guess what... sparkie never showed. I am away to order 25mm cable but do I need 25mm for the earth or is 16mm enough. Here's some photos of garage solar & normal CU. The 2nd CU in the house is empty at the moment, I didnt bother with photos of that.
ASHP/Plumbing Quote Help Please
Alexphd1 replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
That's a fair bit of plumbing alone, material he is providing wont add to much but time will add up. Also keep eye on small details as thickness of insulation esp if outside heated envelope of house. What about a tap in the garage? Try and cut out expensive 'extras' just now. -
I agree with prodave but all depends on finding decent tradesmen. How much bathrooms and is there a utility sink? 170m2 is maybe ufh 800m of pipe (very rough est and loops depends on zones). Emmeti is a decent brand I am 99% sure they used (8 years ago) rebranded uponor mlcp pipe (it was my favorite ugh pipe) -
Sorry for the smart ass comment but I always brick myself when I see quotes like that. Have you vetted this plumber ie spoke to previous customers. I am a bit weary of paying up front for material, remember he will be buying material on a trade account 30 days credit. What square m2 is the ufh area, this may give us a better idea if a realistic cost. As long as it's a new build there shouldn't be vat mentioned. I understand it's going to end up costing you £8k but you will have less cashflow during the build being £18k out of pocket very early on. Only you will know if this is an issue We have the option of changing to a RHI system at the end from a DIY install, getting a approved buisness to fit only the ashp unit for the rhi. -
Was he wearing a mask ? -
I have read the riot act to the sparkie, he will make a appearance today.... he was planning to run in 25mm as it's a big house. Fingers crossed he shows up.
@prodave I have a empty flat for digs if that sweetings the deal?
I was hoping not to use swa cable as it's in metal trunking all the way.
The 12 way CU in the house already half installed.
