Everything posted by JohnMo
UFH - zone not heating up. No flow...
JohnMo replied to Newbuildnewbie's topic in Underfloor Heating
Was the system ever commissioned by the plumber - or did he just install and walk away? First set all the thermostats so they are calling for heat. Check all actuators are open. Then reduce thermostat temp (one at a time) and which actuators close (after about 5 to 10 mins) mark the room on the actuator (s). Once you have rooms for each actuator, check if they match where you think they should be. Your pump from the heat pump/boiler may be just too small to cope with the flow to all your loops. Go through each loop and record the flow being recorded on the flow meter. Does your paperwork contain a pump curve? It will be a graph m3/h or litres/min on the bottom and pressure or m head on the vertical axis. You have a short run of pipe to the manifolds, but a lot of loops in the floor. The issue could be the amount of flow required? -
Your thoughts on this design?
JohnMo replied to Alan Ambrose's topic in New House & Self Build Design
Look like posts to hold up the middle of the upstairs floor, also coincides with similar squares around the outside walls. -
Big windows on the north just loose heat, so consider reducing the size. Overheating from lots of South side windows likely most of the year. Not sure of the mixed size of windows in roof and solar panels looks messy, try to standardize the sizes. As @ProDave says stairs are wrong. Void is just a waste of space, having your kitchen connected to also seems like a bad thing, fire, smells etc -
So it looks like the post is inline with the outer skin of the building. So outside the thermal envelope. So not a cold bridge. Just looks a bit odd. So you need to infill, could you not just form a short return with brick block and cavity insulation, use a cavity closures on both sides insert window/door.
How does the steel post align with the other wall/cavity. Can the post be outside the thermal envelope? Or is it in it? Your photo is not there?
As I said a ove you are over thinking it. PV does not add would not integrated in to the ASAP. If you have PV or battery power available the ASHP will naturally use that power instead of the grid. Mixergy why not just a normal cylinder with a heat pump coil? I believe the low temp heat pump suitable sunamp is no longer available. Keep things simple, no need for integrating nothing really needs to talk a or ask questions of the other equipment. Cylinder, on/off thermostat, call for heat from heat pump, 3 way valve opens heat ramps up temp, cyl thermostat closed, 3 way valve to and heat pump to heating duty. All simple bog standard stuff. PV charges batteries or powers home when sun out. If ASHP is running it will use that power.
Why automate the MVHR then...
Welcome, lots of information on here, very friendly bunch. No question to daft
- 1 reply
If you are getting this type of alert you should be getting out of the house ASAP. Then figuring why you are getting high CO. Your MVHR will not save you
Not a lot of money really
Basics are, there seems to be no real target values. Improve airtightness to what? Just a bit better or 1m3 per m2 at 50 Pa or better? Target U values, better than you find it is too vague. You need a clear statement of what you want to achieve, otherwise it's rubbish in rubbish out. As I mentioned in another thread linking an ASHP to PV and battery is daft. Let the PV and battery feed the house, if power is available the heat pump will use it.
Completion certificate came through this afternoon. Had an inspection a month ago, the only things picked up were. 1. Boiler not positioned as per plan, variation required, easy enough to update, took a couple of weeks to be approved. 2. Hadn't finished the balustrade due to weather. Had to get that completed. 3. Wanted a commissioning cert for log stove. Next jobs Install ASHP, mostly complete. Build summer house, being delivered next week. So from digger arriving on site, 3 years almost to the day. Could of been finished 6 months earlier, but I went back to work. All in took me a year longer than expected, but big site everything bigger and takes longer than expected. Overall costs including doing lots myself, and including all groundworks £2400 per m2
Think you are trying too hard. Break it down into bite size chunks. Do you have G99 approval for 6+kW of PV? Any electrical driven equipment will take up excess PV electric, so you don't need anything fancy or complicated. Basically during the heating season PV generates next to nothing. A DHW cylinder with a 3m coil is all you need, half the cost or less than heat a bank, simple control, simple PV diverter. Concentrate your efforts getting the heating system to run as low a temperature you can, that way you get best CoP.
I got mine from an online seller. Best to go through a lot of them as prices vary daily, one day they are cheapest next not. But also challenge your preferred local merchants. That amount should be free delivery. Would also consider doing it in two layers instead of one with staggered joints. 100mm was bad enough, 160mm would be a pain to install.
Mesh direct, by the roll. Scissors are fantastic also Category:Stainless Steel Soffit Mesh | Product Ordered: 10cm wide x 30m roll x4 Item No 304-SFLY100 Category: | Product Ordered: Heavy-duty Scissors for cutting fine mesh Item No FIN-225--PROMO
Rye oil - Cedar Cladding Oil / Decking Oil. https://www.ryeoil.co.uk/shop/deckingoil/ Have done all my cladding with the above, one heavy coat, 12 months on as good as it went on. Very easy to apply, with a wide brush, soaks in over the next couple of days. Not expensive and goes a long way. I will be doing our log building with it, in a couple of weeks.
Heat and hot water cylinder vs Vaillant Arastor
JohnMo replied to anonymous's topic in Energy Storage
So an unvented thermal store. Hidden behind a lot of flowery talk. And a time of use tariff. To have any useful energy for CH you would need a big cylinder. -
2700sq ft, 3 Zones, Weather Comp & OpenTherm
JohnMo replied to Ambergold's topic in Boilers & Hot Water Tanks
If you have Viessmann boiler use their controller. If your plumber is not comfortable with doing how Viessmann design their system, get another plumber who is. On weather compensation you should be getting on average over 100% efficiency out of the boiler, your none condensing one was possibly 60 to 70%. Keep the flow temps as low as possible. Make sure your plumber doesn't plumb as a normal Y or S plan, you need it set to priority hot water or X plan, this allows the boiler to heat the cylinder at a high temp and heating system on a low temp or weather compensation. -
Not sure why you think you will get short cycling when operating as a single zone. A HP that turns down to say 3kW and has a 0.5kW heat demand, requires a system volume of 60L to give a run time of 10 minutes. Off time should be around 50 minutes.
If your on a single zone at 200mm centres and 265m2, don't see why you need a buffer. Unless your running a massively oversized heat pump. Mine (6kW) will be installed with a single zone, but with 300mm centres on 192m2, with a second area of 16m2 on 115mm centres (summer house) - no need for a buffer. All will be run on WC.
You can't if the buffer is controlled by a thermostat. If your running WC can you do away with the buffer by using a 1 or 2 zone system, just make sure the engaged volume is bigger than minimum volume required by HP.
Planning through Celebration beers or more expense
JohnMo replied to Canski's topic in Planning Permission
4. 1 says it all, talk to your architect -
ASHP - LG Therma V Water flow issues - Plumber vs Installer
JohnMo replied to Woze's topic in Other Heating Systems
Well you must have had a magically boiler, my last house and current house, the water flows cold, then warms up over a few seconds then becomes hot. -
Trouble is boilers can only modulate down so far. Your UFH looks to quite small on only 3 loops. So will not have the demand to keep the boiler happy. Are running the 3 ufh loops on their own thermostats, if so your engaged water circuit could be extremely small. I would suggest you try running the UFH only with all three UFH loops open, to see if that allows the boiler to function correctly.
Two ways to control 1 attach a thermostat to buffer, run it hotter than you run ch use the thermostat to call for heat from ASHP. Disadvantages, lower CoP from heat pump, cannot run WC. 2 allow buffer to float on ASHP flow temp. Can use WC keep flow temp low. Use room thermostat to call for heat. If you haven't plumbed it in yet, consider piping into the return line only, not across the flow and return this ensures no mixing of supply and return flows to minimise flow temp. It's also heated to the lowest temperature so least standing losses.
