Everything posted by JohnMo
Running electric UFH sounds super expensive. Why not a good old storage heater, that least you charge up on cheap rate. A simple direct UVC can be charged to about 70 degrees and should last all day between heating. Run it on a smart tariff or good E7.
We did OSB and then laminate floor over It was pretty rubbish - screed over sounds much more sensible, full contact with pipes and aluminium, should perform much better.
Just a matter of working through the insulation values of the floor above the pipes and see how that affects your flow temperature. If the flow temperature stays sensible that's your answer.
But isn't bucket loads of tonnes of concrete or screed a big enough buffer already? Thermal conductivity for concrete ranges from 0.8 to 2.5 W/(mK), thermal conductivity of water is 0.598 W/m·K at 20 °C. So the floor should suck heat away as quick as you can give it, as long as you have delta T between floor and the water. So why would you need or want a buffer? Aren't you just adding inefficiency by doing that? An additional pump, possibly distortion on each side of the separation? Leading to increased flow temperature, for little or no advantage.
Sounds a big heat pump. But ok for batch charging. Simple table for working out flow temp based on room heat loss. Just draw a line between centres and W/m² to get mean flow temp. One you get low W/m² flow rate doesn't change dramatically with pipe centres changes. You may have to extend the W/m² line downwards. Remember a heat pump flows a min 25 degs in heating mode. Most the time the average heating temp is closer to 7 degs than design temp, so half the heat input is needed. MWT is mean water temp, so mid point between flow and return temp.
Cylinder Choice, Heat Pump, Gas and Oil Boiler
JohnMo replied to JohnMo's topic in Boilers & Hot Water Tanks
We (2 off us) have 210L, 50% of the time it's heated once the other 50% twice a day. But currently, although heated this morning its been further heated to 68 degs via immersion (excess solar). -
She busy peddling away. -
Very true, ours is set a little high. Driven by wife's expectations of very hot water in the kitchen sink -
Thought I would drop some information in to a stand-alone topic, about unvented cylinder (UVC) choice, be it for a heat pump or fossil fuel boiler. The normal advice from a plumber is to use gas/oil boiler specific UVC, when installing a fossil fuel boiler and a heat pump specific one for a heat pump. The primary difference is coil surface area, used to heat cylinder. However I would advise anyone to install only a heat pump specific cylinder, with any heat source. You generally get a huge 3m2 heating coil, which allows the cylinder to be hot without excessive boiler flow temperatures. This was mine this morning - running in hybrid mode (gas boiler and ASHP) Cylinder temp at 53 Deg, but more importantly the boiler flow temp was only 56 degs. This ensure good condensation while boiler is running for improved efficiency. Also if you are using S or Y plan heating schemes it allow a good reduction in flow for both central heating and you can have a hot cylinder.
Just looked back at some of your posts @umiq88. Looks like your house is the same size as ours around 200m². Your issue with so many loops could be flow rate from heat pump. You may need more flow than a small heat pump can deliver (around 1m³/h). By way of comparison we have 7 loops in total. One thermostat. Below is what our plan looked like and how it was actually laid out. Even at -9 we only need to flow at about 35 to batch charge the floor. Average room height excluding lounge is 3m, lounge is 6m.
Why dedicated loops in halls, they have clumped together pipes at side of halls, then added dedicated loops to halls. Just spread the pipes leading through halls to room at 200mm centres. 100mm centres in kitchen seems excessive? Do you really need all those thermostats? I would do bathrooms at 150mm centres and the rest at 200mm. I did all ours at 300mm centres - zero issues.
MVHR ? Who needs it? I don't.
JohnMo replied to ToughButterCup's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We open ours quite often, living room and bedroom windows been open all day, bedroom been open for the last few weeks. But heating is off (or what heating we have on is powered by PV) so not saving or loosing anything. -
Huge MVHR quote
JohnMo replied to Garald's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Really what's the point, you will be several life times saving the money. Is your building even that airtight to warrant going MVHR. It's got PIV now, so would doubt it. If it isn't pretty airtight, it's just additional ventilation, possibly where the 30% efficiency claim comes from. Unlike @Mike I think it's a colossal waste of your money. Just looked at some of your other ventilation topics, you really need to get on with what you have. You have just completed a full renovation, so why do you really want the whole house pulled apart again? -
Do the same in the hallway
Makes perfect sense, you are generating heat in that room with the equipment, floor is heated via the pipes that traverse under it etc. Same should be true for hallway etc. divert pipes through utility also, that room doesn't need dedicated heat either. Our plant room is the roof (fully insulated room) never cold in there.
Still listening. Interesting the base material is lime for cement. The production of lime produces bucket loads of CO2 just because the chemical reaction causes it. Plus the heat input. So not that sure the environmentalists are correct saying I'm using lime because it's better for the environment.
Start by looking at fire engine access and turning space required - or alternative.
But why is it a planning issue? But not a listed building consent issue as well? It either both or neither. If it's a boundary to a listed building it needs both. But also needs the listed building owner involved as well.
Why? Not a fan of heating or ventilation that requires third party control especially if internet is involved. Background ventilation that already automatically boosts only when needed - zero to do, zero for home assistant to mess up if an IP address changes blah blah. The ones I mentioned are 0 to 100% speed control. CV2 - Cheaper than the one linked, full speed control for setup (set flow rate for normal and boost), auto boost - no additional wires needed, no AVMs needed, no back draft needed, no additional room grille needed. Fit and forget never hear you fan again.
As I said the fan linked to is silent, no air noise - nothing. I have to take the cover off to see if it's actually running. Plus costs about 50p a year to run at low speed.
I would say you now take that drawing to your structural engineer, he then determines the foundation structure based on your ground makeup and imposed loads.
Not sure I would ever use a fan like that again, for any reason. Not knocking the make or model, just the noise of intermittent fans - Dreadful. Just install a Greenwood CV2 or CV3. Background silent ventilation at a very low rate and automatic (rising humidity) boost, again near silent.
Ideal brand Heat Pump - any insights?
JohnMo replied to Walshie's topic in Air Source Heat Pumps (ASHP)
That depends on size of heat pump. If you need 4kW max heat and you install a 4kW that storage mode works at more moderate temperatures. However if heat load is 2kW a 4kW ASHP will charge the floor in 12 hrs on worst day and most others in a cheap rate period. Yes, variable flow temp for WC. Heat pumps will modulate based on compressor work input and sometimes variable pump speed, some do it by variable dT also - just to confuse things. -
what outside vent?
JohnMo replied to CalvinHobbes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Just choose one to suit your needs. My choice will not be yours.
