Everything posted by JohnMo
We bought a power shed a couple of years ago, no issues so far. https://www.powersheds.com/
Review the low star reviews also, some recent reviews are pretty rubbish.
No, as they are parallel loops, you just calculate the single longest (master loop).
To comply with building regs you really need the pipe in conduit. It is supposed to be replaceable. We did cold under the insulation - this works well and keeps cold water cold. Hot we didn't do in the floor, but between the insulation for that should be ok.
Buying at full price, I would go Panasonic monobloc and just go to City Plumbing or Cylinder2Go (you get a discount )for the cylinder. Then you just need an UFH manifold. Next job - do your pressure drop calculation assume a 100m long UFH loop and then use your pipe length to sort out primary feed pipe sizes. You want to be getting around 1.4m³/h flow rate (assuming 6kW), to keep UFH and cylinder happy.
I found with boiler it's super efficient at heating via UFH. I run at a fixed temperature, chosen so the boiler runs without stopping when ever it's on (when it's been below 5 degs for more than 6 hrs - hybrid install). And running against a heat pump cylinder generally runs about 4 degs hotter than the cylinder ends up. So about 56 degs max temperature.
Forgot to mention - one thing goes wrong generally the whole thing is toast. Monobloc and 3rd party cylinder every day.
So why the bulk of the all in one then? It basically moves most the stuff of a monobloc inside? Big box small cylinder and from the looks a £1k plus cost premium. Easy plumbing for a premium price. Until you realise most the time in points are exactly where you want them, they have zone valves not needed, basically plumped for S plan or similar, which you don't want. My 210L came with 3 port diverter, expansion vessel, combi valve, and elbows, for under £1k, pre plumbed was nearer £2k, piping in wrong place for easy tie-ins, loads of stuff not needed.
Why do you need a pump? Why 2 port valves, you just a 3 port diverter! You definitely need an expansion vessel X2 one for DHW cylinder and the other for the heating system. All in one cylinder (assume you mean pre-plumbed) full of sh*te you shouldn't need. Would be my opinion. Reality is you need a 3 port valve and some isolation valves. If you do need an additional pump due to pipe length (distance from ASHP) you will just add a fixed speed pump on the return line after cylinder and UFH tee together.
Humidity - too low?
JohnMo replied to richo106's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It's on the low side, but still ok. Ours fluctuates between low/mid 30s to mid 50% depending on the weather. Have found we almost never need boost either. If it sitting consistently at 36% and below I would considered dialing down the MVHR flow rate a little. It's doing what it needs to. Also look at the way you boost, you may not need it? -
The stuff I linked to wouldn't need the liner and is £25 a sheet.
I think the insulation material is this https://www.thepackagingdepot.co.uk/s-1241/1200mm-x-2000mm-x-25mm-white-foam-sheets/?srsltid=AfmBOormE9cYSfOuxypkmQFxMf25Te6Zgn3pYwoIJnoQGgXQ6KlRuT00z-g
MVHR ? Who needs it? I don't.
JohnMo replied to ToughButterCup's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Wish it wasn't the heating season for us, we nearly got to the point of thinking about cooling and temperature took a dive. Average temp here the last week has been between 6 and 8 degs. -
You could used XPS - Extruded polystyrene. It's pretty tough. But why do you need insulation? If you do make it inside out, hard stuff inside, EPS outside.
When we first had the MVHR running we were getting similar, so tweaked up flow rate in bedroom and lowered elsewhere, it never goes above 1000ppm (window closed and door closed). Now with window open most nights it's closer to 600ppm. -
Would doubt it's EPS, been working with it for a few weeks, and it would soon fall apart in a a rotating composter. Looks more like @Iceverge says.
Mdpe is fine, just look in most farmers field, mdpe pipe been there for decades. Underground plastic drain pipe will turn white and may go brittle. Armour cables generally UV stable.
Hot Water Cylinder Usage and Losses Estimator
JohnMo replied to SteamyTea's topic in Boffin's Corner
Not able to open a .ods file? -
You don't Shop around and buy what you want - simple. I couldn't be bothered guessing, or messing about with odds and ends, so I shopped around, bought exactly what I needed.
Not a good start
MEV mechanical extract ventilation - so just extraction, but ONLY when needed. A simpler system with dMEV could be done with no ducts -
Yes. A ducted single fan unit like MVHR but without the supply.
