Gone West
    20
  1. I used Mul-T-Lock at our new build.
  2. It was screwed around the the timber frame and I attached packing pieces, a few mm thick, to the metal bracket to ensure the Hardiebacker was flat and couldn't move when the pan was attached. There was no support for the Hardiebacker in the area marked in red and there was no movement.
  3. They were just sleeping it off.
  4. Are you going to use wire mesh under the floor to protect the insulation from the rodents.
  5. You don't need nitrogen as beans are legumes. I tend to just use Tomorite.
  6. They are excellent. Bought one a few months ago and am very pleased.
  7. Is it impossible to unbolt it from the ground anchors and jack up one end to be able to slide a board under and screw down through the frame flange.
  8. If possible I would board the outside of the whole frame including under the floor and fill with Frametherm. I would put a thin layer of Celotex over the whole of the inside of the frame and board over.
  9. I installed wall hung toilet (not Grohe) and basin frames and clad using 12mm Hardiebacker board. I pre dilled the Hardiebacker to ensure the board pulled in tight to the frame and didn't have any movement. I had the board Venetian plastered and the plasterer would not have been happy about the board flexing. I would check that the board is tight to the timber.
  10. We have found slow worms under paving slabs and large rocks here so I guess you could put a couple of old paving slabs in a sunny spot in there.
  11. I like that, very smart, well done.
  12. You would have to ask him but purely as a guess I would have thought he would have calculated it based on average winter ground temperature under the house, target indoor temperature and overall U factor for the floor. It's easier for a PH where the idea is to have the floor slab only slightly above indoor air temperature. If I were to ever build another PH, I would use the same method as before and use air to air ASHP heating.
  13. Well the more insulation that is used the better, but no insulation is perfect so IIRC even with 300mm EPS Jeremy calculated an 8% heat loss to the ground. The area under the insulation won't be chilled by winds and should reach a steady state which would just be a higher temperature than without UFH.
  14. In my view UFH should be banned in building regs until standards reach PH. All the effort that is put into insulating walls and ceilings and then you are allowed to waste heat by putting it into the ground. Even if all houses were truly built to current regs and building inspectors checked rigorously the standards are not yet high enough to have the slab at a low enough temperature to minimise heat loss to the ground. When building standards are better than PH then wet heating isn't needed.
  15. I had an old garden retaining wall which was damp and I painted it with Durbocem and it has worked extremely well. I do have drainage holes at the bottom though, but I guess you could drill some drainage holes in yours. https://andrewscoatings.co.uk/shop/interior-exterior-walls/damp-mould/durbocem/
  16. I drilled 25mm holes around 100mm deep and filled with SBK. None of the sycamores or beech showed any life but the ash trees have tried throwing some shoots which I just rub off with my boots.
  17. Just looked at a website that reckons the copper strip should be at least 40mm wide and suggests using electric guitar shielding tape. https://www.growlikegrandad.co.uk/in-the-garden/pests-diseases-in-the-garden/copper-tape-stop-slugs-snails-heres-video-evidence.html
  18. Snails and slugs just don't like copper so it isn't necessary to connect to a battery. Some of the 'copper' tapes sold as anti snail are poor quality and I hadn't thought of using stripped copper wire which is a good idea.
  19. A long time ago now, but I was told to ring a few days before decision date so I could withdraw the application and resubmit.
  20. It was a local timber yard that supplied it, but it was several years ago now. At the time I got quotes from all the internet suppliers and the local place was competitive and would supply all 4.8m lengths rather than a mixture of lengths.
  21. It's Canadian Western Red Cedar graded number two clear and better.
  22. On the TF house I built I had a plinth clad in brick slips on cement board. Around the porch there wasn't a plinth but I clad the foundations EPS upstand with two rows of brick slips just glued to the EPS using Titebond PU gel glue. We didn't have a problem for the five years before we moved. https://www.axminstertools.com/titebond-solvent-free-construction-adhesive-311ml-10-5oz-409001
  23. We had a portal frame so no ridge beam. Everything had dried out well before plasterboarding so no cracking.
  24. Not this year, too busy, but possibly next year. Haven't even got the weather station data logger working yet.
  25. We moved into our house a year ago which has a 1.4kW ST panel and 4kW PV system. The ST system seems to work well. The immersion didn't work and the PV system was only being used as background supply so this year I installed a Solar iBoost which now supplies the immersion but a lot of the PV energy still goes to the grid. The ST currently heats the DHW to 60C and the immersion heats it to 75C so the heating oil isn't being used to heat DHW. I will sort out the DHW system this year but I would have thought the ST and PV would provide hot water for eight or nine months of the year.
