Pocster
    29
Everything posted by Pocster
  1. Is 5 o'clock too early for wine?
  2. Thanks I did find the first one TBH. No electrician seems to understand. The council require it for HMO license. So it's really a case of whomever installed it can sign it off with these. But of course they probably aren't BS5839 qualified ( or done the course ) . So then it gets tricky.....
  3. Do you know, If it wasn't for me you lot would be bored. Same old questions about a UVC , or some 'brexit' rubbish or perhaps watching endless photo's of @Onoff re grouting the same tiles for the hundredth time. I add an air of creativity to projects even Kevin McCloud would shun . My posts keep you lot alive!!! FRIDAY WINE LATER!!!
  4. Ooooo - only just noticed I'm an "advanced member" does that mean I know lots of things or just that my penis is massive?
  5. Why make life easy when you can build underground!!!! ???? ( you can tell it's Friday! )
  6. No, no no. This is a simple problem. Ripping up your own work to get it done again and still 'potentially' have leaks in a 'roof' - now that will drive you mad. This is known territory . Rough floorpan to show distance issues attached!
  7. Hey all, Apparently my local council require these. But any electrician I have spoken to seems 'confused'. Even the one that installed the fire alarm and emergency lights. I *assumed* there was a standard form for these - but can't find anything generic online. Council unhelpful as you can imagine. Any help appreciated. thanks Mark
  8. SWMBO will execute me ! ?
  9. Now I understand a pump station- it’s not possible . No where to place it ! Onwards and upwards !
  10. Actually i’ve Just thought of a trick ! i can ( I think ) reduce the Maserati pump distance ...
  11. Problem is wc is some distance from sink . So WC has to pump to near sink and exit .
  12. What’s the difference? A pump station just on the wc ? I.e it can pump that distance ?
  13. Right ! i can feel @Nickfromwales breath on my back already ! In the below ground domain we are having a wc . Its quite possible it’s location downstairs has to be moved . It will be under the parking area and on the opposite side to all the drainage ( typically ). As it stands the macerator would have to pump up 2 metres - then ‘around ‘ the stairwell , then horizontal for maybe 8 metres , then possibly vertical again ( less than 1 metre ) !!! Directly below this ‘exit’ point is the below ground kitchen sink ( which of course has a macerator) . I’m assuming the run for the wc is too long and convoluted ( diagram might help ) . So ! Could the wc macerator feed into the kitchen one to ‘eject’ waste ? ???
  14. Skills !
  15. Gave in and ordered it . relatively small groves in each board . Surprised not T&G ! Anyway spent the cash
  16. Hey @Onoff fit one of these ! Dead nice I think !
  17. It will fall off one day for sure !
  18. Not oiled yet
  19. Well ! The lead flashing looks spot on !
  20. What is lot20 ? Electricians thinks maybe pcb duff
  21. Why so bloody expensive!? Got one in a rented property that’s bust ; electrician’s suggested replacement... https://www.heatershop.co.uk/dimplex-xle-150-storage-heater?gclid=Cj0KCQjwj9LkBRDnARIsAGQ-hUfwN5jr78fTy3xlNl-OeLK-1aR9lWVDkPHngQN5nu-YzuXqCCLVeCgaAg-4EALw_wcB So expensive!!! ?????
  22. Ah yes . Some ‘proper’ reviews ?
  23. Still seems to get mixed reviews . Might be ‘user’ error ...
  24. Which model ?
  25. So what’s the next best tile cutter at a considerably lower cost ? The rubi 200 etc . Seem to get mixed reviews
