Pocster
    29
Everything posted by Pocster
  1. Build underground! It’s a dream !! ??
  2. Best to have it all prepared before the pour ! . No adding afterwards !!!!!
  3. Looking at the drawing ( unless I’m missing something) why not some mesh in the trench ? . Stronger and something for the L bars to tie too. This is what I had
  4. Hmmmmm from memory I had to do some thing similar. My L bars were tied to the frame so poked up through the slab . Then my stepoc ( like icf ) went over it . I then tied all the steel up through each layer . 1 pour with pump on long arm and it was done .
  5. Thanks but my vents have been ordered with the mvhr and kit.
  6. Right ! Have decided mvhr vents will be through the roof - much simpler as i’ll Get someone else to do it ? Still can’t work out how to board this and have good access to mvhr unit and header tank . Assume placing the tank specifically over the wall stud as it gets more support . Guess I just go for it and see what happens .
  7. I always think ( tricky if you are isolated ) that if your home looks secure I.e modern glazing and doors , sturdy fence that must be a deterrent. If I were a burglar I would choose the ‘weakest’ house .... But I’m not a burglar . I’d rather catch them and administer justice - because that is ‘fair’
  8. Dumb question. Why 2 supply/extract pipes per vent with the exception of the WC.???
  9. I did mean the house build..... ??
  10. Yes I'm back!. Landed at 6am in Gatwick; now back in Bristol ON THE JOB! ? Here are the supplied plans for the MVHR. Anyone see anything wrong or not perhaps the best layout? Cheers HRVMH240619Q_Mark Hula REV01-A3_GF.pdf HRVMH240619Q_Mark Hula REV01-A3_FF.pdf
  11. Or use 940nm lighting ir leds No visible red glow but range less . Depends if you want to deter or catch !
  12. Not sure i’d Worry about 4K . Your problem will be viewing remotely at 1fps ? i prefer ‘medium’ res 1024 x 800 or similar at 4 FPS
  13. The SE has no opinion on how to fix these !!! . I’d be going ape with him - it’s his job to detail that !!!
  14. You have got to be the eagle !!
  15. SE’s over spec by about 350% !!! . Mine told me this - then I got him to drop the spec ( probably still 200% of what’s needed )
  16. Yeah they do look excellent; might go for one of those !
  17. £399 here https://www.paintsprayer.co.uk/wagner-hea-250r
  18. Pocster
    Gate Pillars
    No chance !
  19. I do genuinely feel your pain . I got ripped off i.e poor job on my critical flat roof .Had to get it re done . Hang on in there - it is worth it !
  20. Guys - just live underground, nice and cool ???
  21. Yeah I guess if access is tricky then a z wave window is good . I recommend indigo on a Mac to control everything.
  22. Know the feeling ! For the structural steel I insisted the company come out and measure . Most weren’t interested in the trip even if relatively local . So I offered one £100 for a site visit . They came out , measured and supplied the steel . Best £100 i’ve spent... Especially if your build doesn’t match the drawings to the mm ...
  23. I’m going to pretty much automate everything and I could see very little reason to do this with window opening and closing .
  24. Yep I do have a warm roof so I am hoping length of in/out pipes is less critical. Oops - I’ve accidentally attached something! ? 8CAD9864-BECD-47F9-9CC9-A2D521BF347A.MOV
