Everything posted by Pocster
Looking at
Ok , so a platform attached to the rafters , is that what you mean ? So no load on the chipboard t&g ???
Lol insulation was a mission ! Not 1 truss the same distance apart . Which actually brings me to my next question how do I board with these trusses getting in the way ? - going to be a pig ?
Right ! I’m starting to think about where my mvhr , header tank etc are going to go in my limited loft space . I was going to board with T&G directly onto the joists . So then I’ve got a platform for me and the stuff . Assume this is ok . Was also at this point planning where I should fit the loft ladder . Just thinking about access to mvhr for filter changes and header tank if there are any issues .
Yeah I looked at their website . Was interested in what everyone else used and naming convention; I was thinking ... e.g -1/Bedf/light1 so -1 is floor ( -1 below ground for me ?) , Bedf - bedroom front , then of course light1
Presumably I buy a little blow torch to shrink them ?
Yeah I was just worried about rubbing off , label being torn or ( most probably ) being unable to read my own writing!! Might punt on one from a company with a returns policy . Something tells me i’ll Be labelling a lot of things . I reckon i’ll have at least 60 cat6 cables - that’s ignoring all the things I haven’t thought of yet !
Well here’s the reply ..... doesn’t seem to address dryness of air hope this information explains things A Mechanical Ventilation Heat Recovery (MVHR) system is an energy recovery ventilation system that uses an air-to-air heat exchanger that recovers heat that is usually wasted. It works by supply and extracting airflows in and out of homes and buildings to ensure a better indoor air quality. Heat recovery units can recover up to 90% of normally lost heat depending on the unit and the application. A MVHR system works independently from a heating system and due to the heat recovery feature, it can have great savings on your energy bills. A MVHR system works to eliminate condensation and mould within a building by constantly ventilating a property. By eliminating condensation, it also eliminates the risk of damage to the structure of a building and stops the build up of mould and damp. MVHR systems are suitable for small residential products to large commercial projects.
Or ..... https://www.tlc-direct.co.uk/Products/BRPTE550WVP.html?source=adwords&ad_position=&source=adwords&ad_id=315107931576&placement=&kw=&network=u&matchtype=&ad_type=&product_id=BRPTE550WVP&product_partition_id=297813383188&version=finalurl_v3&gclid=EAIaIQobChMI3Kyn6tiR4wIVx-FRCh2PtgvsEAQYAyABEgISxfD_BwE
I said no stickies but ..... https://www.cablecraft.co.uk/cable-identification/brady-labelling-systems-kits/bmp21-label-printer-consumables/bmp21-plus-brady-hand-held-printer-only?gclid=EAIaIQobChMIxJXPrtWR4wIV6b3tCh0p0ABwEAQYBCABEgI1nfD_BwE
My next question would be what numbering/lettering systems do people use to avoid f’ups later on ! ??
Need to start thinking how I’m going to label my trillions of cat 6 cables . Need a reliable way - not stickers . Been looking at https://www.fs.com/uk/products/23298.html or https://cpc.farnell.com/hellermanntyton/w3-270-cc/cable-marker-cc-snap-on-500-box/dp/CB18314?mckv=sgFjgsKVa_dm|pcrid|224645119674|kword||match||plid||slid||product|CB18314|pgrid|52698577371|ptaid|pla-583456645642|&CMP=KNC-GUK-CPC-SHOPPING&gclid=EAIaIQobChMIjtKZ2M-R4wIVRxDTCh2-ugV1EAQYASABEgJCa_D_BwE This the right way to go ? . Expensive for plastic numbers ! But hey ho !
Surely the incoming ( outside air ) is ok as in not dry ?
? i’ll Send them an email and find out !
Ok , why don’t the mvhr companies push this ??? . Just wondering as they don’t seem to mention it ....
Now I’m confused ! I thought mvhr took the stale air and moisture out - used the heat for incoming . Why cycle the moisture back into the house ?
I’m still not sure even what this is and the benefits....
Ok , guess it depends on house layout and usage . I’ll leave the boost switches out but was going to put motion/humidity sensors in anyway ( fibaro one’s do the lot ) . Good to know though
Lining a wall with plywood: how thick should the ply be?
Pocster replied to ToughButterCup's topic in General Joinery
I’ve been “told” to use osb as it’s cheaper and more environmentally friendly..... -
Think i’ll Just link the boost function per zone to my own home automation humidity and movement sensors . Surely the manufacturer doesn’t expect someone to push a boost button just because they’ve had a shower ????!!!
Been looking through the spec in more detail . They recommend 4 ‘boost’ buttons . When would I use these ? . I assume in a wet room it would ‘boost’ automatically with humidity. Is there no humidity sensor at the end of each duct ? ( does it not work like that ? ) . Personally sounds better to link boost to a movement sensor in bathrooms / wetrooms . I was expecting a system where you set and forget .... Any advice welcome
Thanks . I plan to make sure access is good and will mount it suitably just for that reason .
BPC have replied and suggest Vent Axia Kinetic FH Duct pipe cost more than the unit! ?
Adhesive thickness for 600x300x9mm tiles please
Pocster replied to 8ball's topic in Floor Tiles & Tiling
Dumb question and just a thought . Could you not comb the floor with adhesive. Then comb the back of the tile offset ? I.e so tile adhesive interlocks the gaps in floor adhesive... Or is that plain dumb ? ? -
It’ll be worth every penny !
