Everything posted by Pocster
Yeah I thought about that . But if they get damaged and need to come up …. I could just drill a hole through tread and steel then nut and bolt . But it’s a pita trying to tighten the nut when you can’t reach the bolt . No friends syndrome again ??
Cracking on with these external stairs . The steps etc are all steel . The tread is this stuff . They supply self drilling screws to attach it from underneath. But they don’t bite as well as I’d like . What I really want to do is fix down through the composite tread into the steel - just at the edges of each tread . So a shallow bolt head would be fine . What should I use though ??
Thanks for the mention
What's buried in your build?
Pocster replied to Conor's topic in General Self Build & DIY Discussion
Bodies . Lots and lots of bodies -
After movies I decided time to build a house .
Does not . Always to the right and up . Up a lot . Like really up . Maybe even almost vertical
I did think that tbh . But some like it a bit bent yeah ?
My site will never be tidy .
Yeah it was ‘bent’ before I put the treads in. Might try and knock a piece of timber in there to push it out
Got those already . Just need to fix
Bottom leg of stringer well bent . I won’t be able to hammer it out . Best way to straighten this ?? surprised how ‘bent’ the steel is - not through my efforts though !! Got to fix a balustrade arm there . Could pack it out with washers …. ?
I don’t know .
Coooor this steels a bitch to drill . Bought a brand new Makita steel bit and I reckon it’s blunt and I’m not even through it f ecking rubbish ! . My BM doesn’t stock Dewalt because they are twats .
Because it looks tidy that way
Might just be AO worrying needlessly. I’ll finish the stairs ; jump / slide / stamp on them . If all good will order the biggest American fridge freezer I can find ?
Yeah I asked AO about this . They seemed to be concerned about the 90cm . Perhaps an American FF can’t be lead on it’s side ???
Yeah I reckon so . Width a bit tight . Fridge freezer is 91cm . Stairs 90cm . But once I get the handrail on ( it bolts on the side ) is about 93cm . So plenty of room ?
Well smarty bolloxs . Never intended to render the walls. Will simp[ly paint then have a 'pocket sheet' thing attached to the wall for a vertical garden. SO THERE! ?
Yeah. Pissed down aswell. Still - now I have to wonder if AO.com are happy to get a 140kg fridge freezer down there ?
What a (expletive deleted) of a job ! Had to have the crane repositioned 3 times . Slinger was a new guy . Crane driver in a piss . Started at 8am , now 2pm - it was a nightmare ! Stringers in . As expected it wobbles like (expletive deleted) as no bolts to the wall along the middle run . So I’ll drill a few holes into the steel and add some . The guys mellowed up towards the end so I bought them coffee , sausage roll and doughnuts . Also lobbed them some cash each . They could of stopped as it was so problematic. One said “ I’m not a staircase installer “ - he was told just 2 lifts to the garden . I appreciated their efforts . So @joe90 could I have done with your extra set of hands ? YES ?
