MortarThePoint
Everything posted by MortarThePoint
Chimney DPCs and damp handling
MortarThePoint replied to MortarThePoint's topic in Stoves, Fires & Fireplaces
For the chimney on the side wall we had a low level aluminium tray below wall plate and then a Code 4 lead tray higher up to coincide with the back gutter. The chimney is continuing upwards another ~2.5m tomorrow and will hopefully get finished. This takes my focus to the topmost DPC at which I appear to have some options (extract from technical manual below). Fabricating a lead tray is probably not possible now if it needs an upstand as time is too short. The mortar being used for the flaunching will be very stiff (cement 1:3 sharp sand). This chimney has a cavity wall (diagram below). I'd happily incorporate two courses of solid blue engineering bricks just below the corbels, but I don't see how that would help stop damp going down the cavity. What about slate incorporated into the flaunching? -
I'd recommend Cambridge Crane hire as I used them. A day was around the £500 mark I think. Your heaviest truss (~1165kg) would be a nightmare with a telehandler. I arranged the crane to arrive before the trusses (two lorries in my case) and we got them all on. Would have been a miserable day doing it by telehandler and was a fun day with the right tool for the job. You have to weigh up the saving vs the risk and cost of fixing a disaster. I hired a 17m telehandler to fit some steels (400kg each) and chickened out at the last minute swapping to a crane. The plant guys were cool about it and swapped to a smaller machine that I needed to move blocks and the crane driver had a very early start to his weekend. There have been few times I have been so relieved to spend ~£500. It's a weight off when you make the decision like that. Have a hard think about whether there is anything else you could use the crane for. We lifted up lintels and sheets of plywood which saved a lot of effort. With more planning, I could have done more too (flooring chipboard, plasterboard...). I went with Pasquill. They said the only treatment offered is for longhorn beetle which is an issue near Surrey I believe. I wanted some form of damp treatment, but the companies I spoke to didn't offer it.
That looks like a surround that has then been filled in
Years back I bought a Makita DHP481 which is a very good combi drill, but I find myself preferring to use assorted cheap tools. I was recently drilling a load of holes through wall plate and was using a countersunk wood bit, 210mm 6mm SDS bit and a T30 Torx bit. Each one was in a separate supermarket tool each of which cost 1/8 of the combi drill and each in their own way did a better job. I don't think they would survive the abuse or workload of a pro, but I've been impressed by their performance. They are also much lighter which is a huge benefit on a long day. The lighter weight batteries don't last as long, but then each tool is doing less. Hoping this doesn't prompt it to die, but I think my favourite is the Parkside PDSSA 20-LI A1 impact driver. I stripped a 300m2 cold store with it (not including the major steels) as well as putting it to good use on woodscrews. It's not brushless so lots of sparking inside but it's served me well to date.
I have mixed feelings about Banggood. They have some good stuff at cheap prices but goodness me they have some woeful stuff too. I spend too long looking at their emails as well.
I suspect it's called a One Hand Saw because that's how many you have left after using it
Convinced I would end up swapping too if I didn't have shoes What about Gully surrounds
I know opinions vary, but I am keen to use shoes at the bottom of the downpipes because I actually like the look as well as the functional benefits they offer (interesting link). I therefore expect we'll be using inline bottle gullies with a grating under each downpipe shoe. Below is a diagram of the setup. That leaves me with some questions: I presume the rectangular ones are for when you also have a tap above the gully, or an outlet from a kitchen sink for example? Concrete gully surrounds seem like a problem waiting to happen as if the gully blocks the surround will fill up and expose the wall to standing water. They can add to the look and would stop leaves etc being blown onto the gully's grate. What am I missing here? Can you get 4 sided gully surrounds?
Trusses against brick wall
MortarThePoint replied to MortarThePoint's topic in Roofing, Tiling & Slating
I spoke to Simpson StrongTie and they said the masonry application is still possible, but they found it raised more questions than it was worth and they preferred it to involve an Engineer. For example worries that people may bolt them into a bed rather than mid block/brick. -
Interestingly, the SAE hangers are not listed on the "Timber to Masonry Hangers" page of the Simpson StrongTie website. The SAE page and datasheet and don't mention masonry except for one picture. The datasheet was updated on 10 March 2021! -
Yes I saw that type when looking just now and that doesn't have any tabs that tuck in. I like the sound of the hybrid approach you described as that seems like the best of both worlds. The SWL (probably 2.2kN aka 220kg) isn't particularly good which is a shame [datasheet]. The tuck in type have about 3x the SWL [their datasheet]. -
That sounds good. Do you know of any brands that make that type to help me find them? They sound like they are designed to avoid the need for mortar or resin with the tab that tucks into the brickwork. -
Drilling holes and using Rawlbolts feels like an easier process. -
Yes, I'd have to cut out some bed and then mortar the hanger in which doesn't sound much fun -
That's prior to loading, they can be built in during construction. The wall extends a storey higher. -
We have a lower level roof (half flat half pitched) that the designer has used JHI masonry hangers to attach to the wall at one end (circled below). The wall is already built and I was wondering if people thought cutting a masonry joist hanger in to an existing wall is harder than using a ledger board and timber joist hangers?
I do like this product. What spacing did you use for the downpipe clips? With an offset bend did your downpipe become: 112 bend pipe 112 bend clip pipe + clip half way down socket pipe + clip half way down shoe
Hot water: Part L requires insulation. If the water is 38C warmer than ambient then a 22mm pipe losses heat at 53W/m [link]. The heat capacity of water is 4.2KJ/KgC. The volume is 0.38l/m giving 0.38kg/m. That will therefore cool at a rate of 53J/sm / (4200 J/KgC * 0.38kg/m) = 0.033C/s or 2C/min. The temperature difference half life will be something like LN(2) / (0.033/38) = 800s about 13minutes. Table 5 of https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/697525/DBSCG_secure.pdf Table 6.1.1 of http://www.timsa.org.uk/TIMSAHVACGuidance.pdf Insulated to achieve the 9W/m figure would slow the heat loss to about 0.33C/min. The temperature difference half life will be 13*53/9 = 77minutes of 1.25hours. I wonder if that's worth it for the family bathroom where chances are all activity happens in a flurry and then nothing for many hours. Probably makes sense for a downstairs loo where the usage is more constant with the tap going about once an hour or more (depends who's cooking). Cold water: Is this a building regulations requirement or guided by good practice?
Am I imagining it or did I read somewhere that hot and cold water pipes should be insulated even within the building's insulated envelope? I hope I did ?
Cool. I follow now, 7kW peak charge current but many kWh capacity. Still now worries charging overnight.
Nice quick charge then. What's your EV then, at Twizy?
I know I'll have to talk them out of it though ?
I got 30 panels for £11 each for just the panels. You can easily find clips for around a pound and I knew someone with an old pallet of feet that I paid £50 for. They charged £100 for delivery as it was a fair way. Tip on collecting as I have done it as well. I hired a luton van and they shifted in transit causing the door to jam. That was fun sort in the dark at 10pm.
Just wondering what sort of charge time is that going to make for?
