Everything posted by Onoff
Bugger - big chip in glass induction hob
Onoff replied to jack's topic in Kitchen & Household Appliances
@jack http://hobcoversdirect.co.uk/hinge.html Got my lad a very basic hob cover (not from above, some place in Hove). To protect his hob at uni and give him much needed space. Really well made. -
Not hopeful of getting a spare glass top if I drop something on my Electra Elecheib induction hob. I guess that's the problem with these well known makes! -
Stainless trim to hide it? -
Chemical Anchors: choosing one isn't easy.
Onoff replied to ToughButterCup's topic in Tools & Equipment
We're they tested or just failed when you tried to nut them up? We use a rig like this:- 22 replies
- chemical anchor
- resin
(and 3 more)
Safety harness points, abseil points, safety wire systems.....- 22 replies
- chemical anchor
- resin
(and 3 more)
We use this at work for man riding applications, Fischer FIS V 360 S: The piggy back cartridge is imo superior to the standard mastic gun type.- 22 replies
- chemical anchor
- resin
(and 3 more)
Tbh out of all I've used I used to find the Rawlplug catalogue easiest to navigate. Helpline was good too. Nowadays I use Fischer but that's only on the back of work and I can score the odd slightly out of date tube as we daren't use it for our man riding applications. I helped somebody a while bavk and they were using DeWalt stuff. Nowhere near as good as Fischer imo.- 22 replies
- chemical anchor
- resin
(and 3 more)
I found digging /lifting with a fine tool between the fins and vacuuming around the heatsink worked best. I did take the back off the old 42" tv the other week and got the compressor and a brush on that. Amazing how much "sticks" and has to be helped with the brush.
- 84 replies
Worth cleaning the accumulated dust from between the heatsink fins above the CPU if getting into an old pc. Often it's so fine and compact it's easily missed. Toothpick etc is pretty good for digging it out. Things can start getting hot and shutting down for no apparent reason.
- 84 replies
What plant to hoick around concrete floor beams.
Onoff replied to epsilonGreedy's topic in Foundations
Two wheel barrow wheels etc & diy one. -
Council tax
Onoff replied to nod's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Raise a "Stage 1 Complaint" (based on incompetence) against the council for quoting the wrong information etc and the stress it's caused you etc. Their internal mechanism kicks in by default and fur flies. Successfully done it myself with advice from my barrister brother. -
We used to happily shift 6m long 178x102x19kgm I beams around roofs between two of us. Around 254x146x37 and we would just design around 3m lengths Probably explains my disc problems now! Why I only carry one 25kg test weight at a time now. If 4 of you lifting it can pay to use 2 strops with one of you either side each end. Sometimes we would use a beam trolley: http://www.bakerfabrication.co.uk/beam-dolly/4567731201 -
Might have been my place as the smells still there when something dies under my floor! -
Many years ago it was nicknamed Bidonville (shanty town). That only applies to my plot now! -
Try it of a weekend, packs of the morons clogging the road up and not wanting to pull over. -
Erm.....no, not really. Still got to cast the wet room corner, do the mitred corner boxing in and the pockets, fit the shower...... I was joking to the missus (as we drove past St Michael's prep school) that most round here probably pay £600 per square metre for their bathroom tiles! -
I can't believe nobody spotted the deliberate mistake when I posted up this photo of the model previous! Anyway...Union Jack cuts in 330x330x8mm ceramic floor tiles. On a loser? Possible? I can probably get some water jet cutting done.
£600 on tiles last night. Walls, floor & mosaics. -
Every time I have a good idea someone nicks it!
Descent as in lowering the tone, bringing people down to his level...
No that's downstairs, building paper on concrete. I think she's safe.
Software to Model fall of Sunlight / Shadow
Onoff replied to Ferdinand's topic in General Self Build & DIY Discussion
This? https://www.findmyshadow.com/
