Onoff
    206
Everything posted by Onoff
  1. I believe foxes take more rats than cats, at least if there aren't any leftover kebabs which are their natural foodstuff.
  2. Travis Perkins, Selco etc are nationwide builders merchants as opposed to say B&Q, Homebase that are diy stores. You'll likely have an independent merchant near you.
  3. I'm working on printing an adapter...don't wait up: Buy one if you want it quick: https://www.ebay.co.uk/itm/285050150261?
  4. So how far are your pallets i.e the timber going to be off of the ground?
  5. Dunno, I'd search "heavy duty UV stabilised weed fabric / membrane" or similar.
  6. Mate just bought a house and got a big chunk of money off if he arranged to clear it. Old sheds piled high with stuff. A couple of the neighbours swung by:
  7. SWMBO's just said the cheap ones go brittle in sunlight. You pays yer money etc!
  8. Foxes, rats, bellbind, Japanese knotweed, wasps, social bees etc.
  9. As and when I'll just add to the existing thread.
  10. Reassuringly expensive: https://www.tlc-direct.co.uk/Products/WKONEGEL.html
  11. No offence but this simplified picture may be better. An imbalance, caused by leakage to earth, gets picked up by the search coil: Pushing the test button brings the resistor in and creates an imbalance. It is critical that the in/out wiring is correct. (Same as with current transformers).
  12. Called hanger bolts, wood to metal dowels etc. Then you'll want a penny washer and wing nut of the appropriate size
  13. I wonder how long it takes to cura concrete house...
  14. I could print a scale model here...
  15. Beware the caravan brigade!
  16. You can get non slip epoxy paint too.
  17. I've 15mm PB pipe run in 25mm electrical conduit for protection. I often get my lad to 3D print spheres, cones etc to go on the end of cables. Makes it easier to push through corrugated duct. A cut down silicone tube nozzle, slipped over the cable is something else I use.
  18. Out of interest, how many hours of printing there? Apologies if you've said elsewhere.
  19. I'm sure SWMBO will appreciate it.
  20. I know a chap put one of together for about £370. Everything from Amazon or AliExpress but much of it printed using 3 rolls of PLA: https://docs.v1e.com/lowrider/ 1m X 2.4m working area. Costs: Controller 100 stepper motors 30 belts and pulleys 20 3D printed parts 60 (3 rolls of PLA) 25mm pipe 30 (less if you use galv conduit) wiring 20 router 50 nuts bolts and bits 30? wood bits 30
  21. You'll get the gist of it having a read here, though based on the 16th, it is in fact superceded by the 18th! The basics generally remain the same. https://www.tlc-direct.co.uk/Book/4.3.6.htm Don't forget the option of singles in trunking.
  22. Mental... SWMBO's idea is on the lines of.....get rid of the existing old blue, 1980s, 800mm tray. Then get a new 1200mm tray, this "as they're only about £40". Keep the existing white tiles. Move the stud wall to the right about 400mm. Add tiles to the extended shower area and below the existing to meet the new, lower tray. This means we can utilise the 1200mm sliding shower door we bought years back for the downstairs bathroom and never used. All this whilst there's still a rain leak coming in through the ceiling. My plan, do the roof, gut the bathroom and redo in wall panels. Told her I'm not interested doing it half arsed. As mad as her ****ING mother was!
  23. Cheap as chips in fact...
