Everything posted by Onoff
I'm pretty sure you could build a pallet shed then fill the wall (& roof) with expanding foam... Where would the vcl go? And what U value would a 4" slab of foam with 20mm timber either side have?
"Frominside" is that a wood treatment?
Welcome. Can't beat a pallet shed!
So 4 second year lads renting a house in Brighton for their second year of uni. 3 have known each other since they were tots, the 4th met the other 3 during his first year. Can't say they don't know each other. So that's NOT an HMO? I don't understand, I just pay the bills!
I wonder if there's a hybrid method feasible...EPS/XPS down low, over and below the DPC then Rockwool above.
Not if they do it themselves! Now...where's my trowel & hawk...
I've no probs wiring it up just this thread made me question whether Honeywell is wired/ported different to the Tower one in at the mo. I tell you what you can tell the quality of Honeywell compared to Tower. Streets ahead right down to the tinning on the wires and documentation. I'm a convert!
This is the one I have: Straight out of the box, not wired up and set to Auto it ports to B. Set to Man and it ports to A & B.
He says Honeywell above. I'm only asking as I've one (a Honeywell) to fit. I'm going to run it on the bench so I make bloody sure I know how it ports.
Is that a 3 way diverter valve as opposed to a mid position one? What model btw?
Same with tiling, less visible areas first...whoops!
Talking ballpark here but my external walls are an odd mixture. There's brick & block with a nom uninsulated 60mm cavity, often a mix of brick and block in the same leaf judging by what I found doing the bathroom. I think then I have a 9" block section and also a 9" brick section too. Whatever the wall construction it's all externally rendered. Not sure what's the worst but imagine one of the 9" solid walls. What nominal thickness of Rockwool should I aim for on a retro fit and what U value should I aim for? Any tables about with what U values for what wall make up? Monkey see monkey do here! Cheers
This quip from @jack deserves to be crowned champignon I think.
I simply shan't or else I'll have no fun!
Disqualified, @Big Neil had that one!
Taking serious threads like this off piste should be a criminol offence.....
So can you safely bridge the DPC with Rockwool? As in if taking any retro fit EWI down past it (the DPC) to help with cold bridging at floor level.
Spray PU Insulation
Onoff replied to Blob the Builder's topic in General Self Build & DIY Discussion
Some figures here:- 18 replies
- spray
- insulation
(and 2 more)
Quorny jokes galore on here tonight!
Help with kitchen renovation/ 1st house.
Onoff replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
Didn't we suggest Leyland Super Leytex? Or even the No Nonsense one. -
Perhaps take the truffle to read the earlier posts next time?
I can imagine a fierce fire cracking any render.
@Brickie already had that!
