Onoff
    206
Everything posted by Onoff
  1. I've got to dig a 24m trench at the moment. Mulling buying a Chinese digger.
  2. What about... https://www.maxam.co.uk/maintain-your-property/seek-n-seal/
  3. I've fingers in a couple of pies:
  4. UV from sunlight degrades the sheath is the main thing. You could run a line of conduit and put it in that.
  5. I've fingers in a couple of pies:
  6. There was some b@llocks from memory with the NICEIC wanting to "de-neutralise" the earth.
  7. Doesn't matter a carrot as long as you sleeve both ends as far as I'm aware.
  8. A Bladerunner is what you want: https://www.tlc-direct.co.uk/Products/KTWSBR28.html
  9. I've got similar. I left brown as L, sleeved the black with blue for neutral and sleeved the grey with green/yellow for earth.
  10. It's 3 phase cable / colours.
  11. Storm glands another option: https://www.tlc-direct.co.uk/Products/TLST20.html
  12. Use an earth nut to suit, 20/25/32: https://www.tlc-direct.co.uk/Products/PRPEN20.html Check out the Technical & Description bits.
  13. Is the sink an IKEA one per chance?
  14. Does he?
  15. Not in my house. I like my ale real and ambient.
  16. As of today I'm roughly this far through mine with a 107mm core cutter. This is proper kit from a demo contractor mate. En route I've had to have the drill apart and tighten the clutch where it was slipping. Drilling the first 16" was not easy but I got there. Then on the next section it's very easy to go very slightly off true. The angled interfaces then make it stick a bit. Tbh I think the clutch was actually OK and it's slipping a protective thing. Now, using it, it's one slip up from A&E: In case anyone was wondering:
  17. Good luck. Even with the right kit diamond core drilling can be hard work. Trying to go through my garage foundations and this bad boy packed up: Still got a way to go 🙁
  18. Thanks. Any pointers as to what that coverage criteria is? Cheers.
  19. Any thoughts on service layout in a 9" wide trench: 20 or 25mm mains water 63mm cable duct 110mm waste I'd have said water at 750mm, electric at 600mm but where to put the 110 waste? All in pea shingle with cable tape etc.
  20. Here's an off the wall idea, vacuum excavation. Spendy I bet but if you don't ask etc. You could be their poster girl for domestic work and get a discount! 😀 https://vacukltd.co.uk/news/everything-you-wanted-to-know-about-vacuum-excavation-but-were-afraid-to-ask/
  21. Here's an off the wall idea, vacuum excavation. Spendy I bet but if you don't ask... https://vacukltd.co.uk/news/everything-you-wanted-to-know-about-vacuum-excavation-but-were-afraid-to-ask/
  22. Careful you don't lower or raise your garden to the point of it causing issues on the boundary. We've had walls leaning and gardens slipping on here and it gets very acrimonious.
  23. Why no side access? Does the property go the full width? No possiblity of taking down a bit of the conservatory by that wall and going through there. It's doable narrowing through the house just slow. Cheaper than the gym mind.
  24. Well passive submissive...
