Everything posted by joe90
Modern housing estate living
joe90 replied to flanagaj's topic in General Self Build & DIY Discussion
And I think the rednecks will revolt (another civil war.) -
Ooh I would not do that, it will stink in a short period of time, much better to build bird boxes outside in their natural environment.
The wall is cold because it has no/little insulation plus you don’t have enough ventilation to remove the condensation. The bathroom and kitchen are the dampest rooms in a house. Is the wood soggy? If so you will need to dig it out and fill with another piece of wood, if sound just sand and paint.
Does the roof sag at all that side ? If not I can see no reason for it. Also additional timbers added to other bits don’t IMO serve any purpose. Have they added solar panels above the sistering, which might be why additional strength was added.
It’s because of silly prices and a housing shortage. My son has recently bought a house on an estate because he could not afford anything “better” and the only reason he had the deposit was because of some money he inherited from his grandfather ! Yes I would not buy one but because of nearly 50 years of doing up houses I have climbed the ladder somewhat and when I peg it he can pay his mortgage off. 🤷♂️ -
I Can Smell My Neighbors Cooking In One Of My Rooms
joe90 replied to Rehan Saeed's topic in Ventilation
Ah no, I used to live there, Shrewsbury is the town, salop is the county of Shropshire. -
Removing outhouse wall, do I need a support beam?
joe90 replied to spleenharvester's topic in Demolition
From those pics I would guess the roof is concrete, so heavy, and depends if there is a join in them over the wall. Is there a span which does not have a wall (apart from the two ends?) -
Air movement is key and the fan is removing it but you need air going in to replace it. You say the mould problem is cured so I would leave it 🤷♂️
https://www.screwfix.com/p/zinsser-bulls-eye-1-2-3-primer-sealer-white-1ltr/10135
Planing/routing proud door frame - tools/techniques?
joe90 replied to DeanAlan's topic in Doors & Door Frames
No such thing, yes photo please. -
Ah, I meant car mirrors (I have a junction near me where I use a door mirror to see if the road is clear)
And @Pocster should know 👀
Hi 👋🏼 new and exploring additional rooms options
joe90 replied to jellybe4n's topic in Introduce Yourself
As long as it’s removable (even by crane) it’s classed as a caravan, it’s only when it’s deemed self contained accommodation I.e. completely separate from the house that planning is required. https://caravantastic.com/2020/09/25/planning-permission-for-static-caravans-on-private-land-do-i-need-it/?gad_source=1&gclid=CjwKCAjw88yxBhBWEiwA7cm6pah5LYPzGfEsqfLz2768MrtIMM63jlzfWZLJdody2cYY_wYWi_SyPBoCpFoQAvD_BwE -
Which heating and hot water solution(s) in 2024?
joe90 replied to Jane W's topic in Other Heating Systems
I was told by my plumber who signed off my tank not, it must be visible to be “venting”, was he wrong? -
Well it’s not a public road so I guess it would be treated as a “drive” that someone else has access too. Still might be worth contacting highways for guidance I guess, but could you say it was “existing”?
Ah, only @Drellingore can answer that one but I assumed private drive 🤷♂️
But that is for road junctions not drive access! I had to fight to get highways out to see my proposed 90’ drive access with full visibility splays and when they did they would not recommend it to planning, they would only “not object” beggars belief (but I won in the end 👍). Might be worth contacting highways in your area fir guidance.
Quick garden.co.uk. Is where I got my log garage and they do bespoke builds, design what you want and let them give you a quote.
I would have thought the insulating properties of 38mm or 44mm thick logs would have been sufficient for the short periods of use. As steamy says log cabins for outside use. (And they look good).
What about a static caravan, if it’s not self contained ( son will need to use the house for cooking or sleeping etc) then it’s allowed. Or a touring caravan again which is allowed. Or a garden office, timber frame or log type. (Kids tend to leave home, Eventually). -
How much will it be used ?, if very often/long hours then maybe worth insulating but if not then heating it for short periods will be fine IMO. Yes that slab looks OTT to me.
