thinner alternative to flowing liquid screed - views?
Russell griffiths replied to mikeysoft's topic in Underfloor Heating
I thought about the amount of bags needed and thought he would need 4 blokes to do this, two mixing and two laying. seems like a lot of hard work when you could just pump it in. -
The upvc arch formers look a bit naff in my opinion. I would also worry about getting them sealed to the windows well. im also not liking the window placement and would want to see it set further back into the warm part of the construction. all depends on what sort of house you are trying to build, one that just passes building regs or something better.
I looked at them then dismissed them, don’t remember why it was a couple of years ago.
German kitchen brands - Nobilia, Bauformat or Leicht?
Russell griffiths replied to Indy's topic in Kitchen Units & Worktops
We had a quote from wren, and Schmidt the hand built one was 2-3 grand dearer than wren and the same price as Schmidt my computer won’t let me upload a pic at the moment our hand built one still has mdf doors, to go oak would have been a good few thousand more. -
Depending on what look you want, we wanted handle less but didn’t like the look of the metal trims used for the area your fingers go in, we ended up going with a local company who handmade it all in a small unit a couple of miles from us. the trim to put your fingers in is in solid timber, we went with oak, but the do walnut if you want a darker look. -
What is going on the inner wall, insulated plasterboard, or just dot n dab boards. if you are having a lot of wall units you might want to fit something to the wall to fix the units to. whatever you do I’m sure you can pad the surface out enough to fly over the face of the steel to hide it. or talk to the engineer and see what you can do to change the size of the post.
- 6 replies
- steel frame
- concrete pad
- (and 6 more)
Do you not have a foundation plan I wouldn’t expect the post to go down to the foundation , but instead sit on some concrete blockwork that brings it up to around dpc level or floor level. this lifts it out of the wet damp zone. concrete wise I would just widen your strip footing in the area of the post.
- 6 replies
- steel frame
- concrete pad
- (and 6 more)
A block wall will give next to no sound insulation you will end up building 3 walls, block in the centre and two skins of some sort for sound and insulation properties.
Are these to sell both, or will you be living in one. i would want something far more robust if I was living in one of them, a stud wall with the correct boarding will meet the regs, but i would want something better. as mentioned above sound transfer will be very relevant as well.
Concealed shower valves too recessed?
Russell griffiths replied to tokyotecubate's topic in General Plumbing
Some makes do have extensions however I don’t think they are available for that valve you have, do some searching. I think you will end up tearing that wall apart. having two different teams fit first and second fix can be a recipe for disaster I’m afraid. -
Reading the Land Registry runes?
Russell griffiths replied to Alan Ambrose's topic in Party Wall & Property Legal Issues
I need to update a boundary, I’ve been told it can take up to a year 😂🤦🏻♂️ -
Bonding cementuious UFH boards to cement board
Russell griffiths replied to GTM_88's topic in Floor Tiles & Tiling
Flexible tile adhesive the single part bagged stuff, not the ready-mixed stuff out of a tub. -
barn conversion. SIPs or stick build ?
Russell griffiths replied to mattp22's topic in Structural Insulated Panels (SIPs)
Do you need a 10 year warranty for a conversion?? @scottishjohn sounds like your build. -
If your planning on putting it underground eventually, then why can you not put it underground now, just have the mdpe running above ground until you build the extension. what am I missing.
You actually want a tank full of poo sitting on top of your garden. what are you going to do with the outlet pipe, just clip it to the fence and grow some ivy up it. Nope, put the proper underground one in and you will be left with a neat inspection chamber lid, nothing else to see.
Lean to abutment cladding detail?
Russell griffiths replied to junglejim's topic in Roofing, Tiling & Slating
Mines not timberframe, no membrane on the walls. -
You need to determine if it’s rain or condensation go in the loft when it’s raining with a torch and sit there for half an hour and play detective. take some pics. water should not be getting under the tiles and onto the membrane in the first place. the tiles are your number 1 rain defence, the membrane is a secondary line of defence. I would do a bit of research first.
A little tip is to liberally apply wd40 over everything cills frames etc when finished a bucket of soapy hot water brings them back up. all the mortar and splashes will not stick to the wd40 covered frames.
Do affordable(to buy) work towers exist?
Russell griffiths replied to YodhrinForge's topic in Tools & Equipment
I would buy some second hand bandstands and new scaffolding boards, 3m isn’t very high so with you stood on top it only needs to be 1m high, cover the entire room so you have a full walkable surface without getting down. this will be far nicer than spending all day up n down, up n down. you will sell the bandstands for exactly what you paid for them, and probably loose 20% on the boards. -
His drawings lack details that I’ve seen shown from others. also I’ve never seen type 1 stone used. im only going by what I’ve seen mentioned on here, and it’s normally a different stone makeup. that could be because of your ground conditions. needs some input from people on here who have done this previously.
I have 3 sewage systems I have to look after, two are old septic tanks, the third is the new treatment plant I installed. they are like chalk n cheese, the treatment plant just sits there bubbling away, I can’t see it needing emptying in the next few years, there is zero sludge in it, it is not in heavy use at the moment as I’m the only one here at the moment. But as long as it has a power supply there very little to go wrong with it, I’ve had numerous problems with other things on site, but not that.
No photos. you need to stop water getting behind or under the roof flashing, the membrane is only there as a second defence. whatever flashing you are using needs to go really high and lap into the window area.
