Russdl
Everything posted by Russdl
That idea, or at least similar, was diss’ed a bit further up this thread so, due to an abundance of ignorance of these things, I’ll give that a miss. So it seems, however copper sulphate solution was promoted further up this thread so now I’m confused, but as copper was diss’ed I can get my head around copper sulphate solution being a no-no. Yep, shame on me. As they are promoted as self cleaning I thought I wouldn’t have to get involved. I’ve not cleaned them since installation which has got to be pushing 5 years now. It’s not easy to see them and it’s only in certain light you can see what is probably lichen and it was only late last year I spotted it. Window cleaner is going to cost around £80-£100 to clean them but I wonder if s/he will actually clean the lichen off or just make it wet. Hence the original question. I assume copper kills lichen (who’d have know!) Also, from what’s posted earlier in this thread I assume copper kills aluminium? It would also seem from previous posts in this thread that copper sulphate solution would kill lichen but not aluminium? Does copper sulphate solution kill zinc? Anyone know?
Bumping this thread again. We have what looks to be lichen growing on our solar panels. They are a long way up so not easy to reach. Does anyone know if that copper sulphate solution suggested by @Jeremy Harris would eat our zinc roof alive? If the copper sulphate solution is an option then I’d only be able to apply that solution via a sponge or something similar on the end of a long pole and wouldn’t be able to exert any scrubbing pressure. Would the copper sulphate solution work in that scenario?
Well that was uneventful, tiny dribble of water, gauge is off and still firmly stuck at a little over 2 bar, which makes that previous high pressure I saw a little less terrifying. I an’t see any way to adjust/calibrate it so I’ll guess I’ll get a new one and fit a pressure relief valve at the same time.
I was thinking of trying that Let’s see what happens…
I’ve had another read through @Jeremy Harris’s thread and he noted that the latest Sunamp models are limited to 5 bar instead of the 10 bar of the previous variants, mine being one of those. After getting the expansion vessels to play ball I’ve got around 5.7 bar, which is around 2 bar above my known water pressure from when we started the build and, knowing what has happened to previous Sunamps, higher than what I wanted to see. I was curious so turned off the cold feed to the Sunamp. Pressure remained the same (trapped in the hot circuit). Ran a hot tap until it stopped which was only a few seconds - pressure dropped to 2.5 bar (I was expecting zero??) Deflated the expansion vessels - pressure dropped to 2 bar (was definitely expecting zero now!) I ran every hot outlet in the house, non of them ran apart from one shower (it was running cold so I guess that’s just cold water getting past the thermostatic mixer when full hot is selected?) Still 2 bar of pressure. I’m assuming my pressure gauge is knackered and miss reading by +2bar. Is that likely? If not, where is the 2 bar hiding and why can’t I get it out of my hot circuit? So, to recap I’m sat here with cold supply off, hot taps open, expansion vessels without air and showing 2 bar on the pressure gauge. Any clues??
@Dillsue good advice. At least one of my expansion vessels had effectively failed as there was no air in it. And I’m guessing there was nothing in the working expansion vessels as well hence the over pressure I saw. Now they are both charged up again everything looks fine - too my eyes at least.
No, there's no pressure relief valve in or around the Sunamp, and no mention in the MI's. I think I recall Jeremy's replacement Sunamp having some pressure relief facility that his previous set up didn't. I'll have to re-read that thread. It looks like getting the second expansion vessel working again has fixed my problem. There has been negligible change in the pressure after charging the Sunamp for a little over two hours. I guess my lesson learnt is that those little expansion vessels that are pretty much out of sight, shouldn't be out of mind. I'll add them to my list of things to check every 6 months to make sure they're holding they're charge. I don't think I've checked them once since we moved in.
I seem to have got the dodgy expansion vessel working again, they're both now charged to 3.5 bar and the Sunamp is on and charging in the daylight so I can keep an eye on the pressure.
@Dillsue I probably didn't make it clear but that is my view as well that the expanding water as the Sunamp heats up is causing the pressure rise. There is a non return valve on the cold mains supply, and on closer inspection it seems like only one of the expansion vessels is working properly. I can get air in/out of one of them, but not the other the other one. I guess those things break down? Would going from two 500ml expansion vessels to just one be enough to cause this big water pressure rise? I don't know. I don't think so. Can you throw any light on what that would look like and where I'd find it?
A bit of a long story: It transpires a joint in our DHW manifold has been dripping unnoticed for what would seem to be yonks. It drips onto a pipe directly below, that drip then tracks along the pipe to a water circulation pump and then drips off the back of that pump on to a pipe below it before finally hitting the wall leaving very obvious evidence, unfortunately that evidence is nicely hidden behind the Sunamp, hence it's gone unnoticed. After reading @Jeremy Harris recent woes I took a good look around mine and discovered the evidence of this leak. The trouble is, this leak only materialises when the Sunamp is charging, all other times the pipes are bone dry, initially it seemed to be the rear plastic moulding of the pump that was leaking as that was the only place where water was evident, it had long evaporated from the copper pipe work. I blagged a replacement pump off a friend and felt certain my problems were over, except that replacement pump seemingly started leaking in exactly the same place so I widened the search and eventually found the source. Throughout the days usage the joint remains bone dry, it's overnight when the Sunamp is charging that it starts to drip which lead to an unpleasant discovery. There is a pressure gauge on the cold supply to the Sunamp and early one morning I saw it indicating 13bar! Maximum operating pressure for the Sunamp is 10 bar. The pressure instantly reduces to around 5 bar when a hot tap is opened. If I isolate the cold supply and open a hot tap it reduces further to around 3 bar, but no lower. So every night (for years potentially) when the Sunamp charges the pressure builds to 13 bar and forces water to leak from an otherwise water tight joint in the DHW manifold (maybe this small leak has prevented anything worse happening?) What can I do about this? There are two 500ml expansion vessels fitted. Do I need another, larger expansion vessel? Is there something much bigger going on here? Any help gratefully received.
How to mount an external door when using an insulated slab?
Russdl replied to zzPaulzz's topic in Timber Frame
We used GRP angle attached to/cast into the slab for all our exterior doors. On our sliders I put 7 x 150mm M12 bolts through the GRP, threads extending into were the slab was going so that the bolts would be encapsulated in the slab when it was poured. It seems to have worked fine, no thermal bridge and enough strength to hold a big heavy slider. The slab was kept 25mm lower where the slider was going so that Compac Foam could be used under the sliding door threshold to insulate it from the slab. The front and back doors were much easier with their narrower thresholds. Sliders Front and back doors were simpler.- 11 replies
- 4
- foundation
- passivhaus
Brink Flair 400 Maintenance
Russdl replied to Russdl's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Don't! It'll be sweet, and if not it's really easy to clean. Let me know if you have any dramas when you getaroundtoit, splitting the fan casings and getting to the nitty gritty/mouldy slimy is really easy (when you've got the fan units out) -
Probably right, I won’t be doing that for another three and a half years 😃 -
I took the extract fan housing to pieces, it was a bit grim on closer inspection but I was expecting a lot worse so I’m pretty chuffed and I don’t think I broke anything in the process which is a great result 😃 I’m pretty sure my pre filters have helped, and not turning the MVHR on until all the building work had ceased can’t have hurt things either. I’m wondering if the fact it’s an enthalpy unit helps as well? It was bone dry inside and I’m presuming there will always be some moisture inside a non enthalpy unit? -
Got them out. So to remove the fan's I followed the instructions by giving a sharp tug and rotating the fan housing out (reversed for the fan on the other side). The next step in the instructions wasn't working for me without making me nervous of causing damage so I found that I could lift up the fan housing (orange arrow) by just a small amount which was enough to allow the rest of the steps to be followed without issue. -
The manufacturers instructions for removing the fans make it look incredibly easy, the reality for me is that it isn’t, feels like I’m going to damage the polystyrene internals trying to get the fans out. Does anyone have any ‘top tips’ for the fan removal of a Brink Flair 400 MVHR (or anyone have superior Googling skills - I can’t find anything) ~~~ I’ve left it far too long to finally get around to cleaning my MVHR heat exchanger and fans (3.5 years!) but it looks like I’ve got away with it. Frankly I’m amazed how clean it is in there. The dirtiest component is the fan on the extract side which I guess is to be expected. Intake fan Extract fan
Yes, please do. It’s very interesting but complete Swahili to me. I would like to learn a new trick if you can spare the time (and start with the basics!)
I’ve got one in the garden on my weather station but annoyingly it quit recording the Solar Radiation a while ago. Consequently I’ve substituted Solar Radiation with PV Production so I can continue to bore my wife witless with my statistics. 😃
@JohnMo do you think you have a have problem then? We have had wall to wall sunshine down here for the last few days with hardly a cloud in sight so not at all atypical.
Significant difference down south. 27th Feb - 4th Mar 2024 26th Feb - 4th Mar 2025 The most noticeable result of the increased solar is the decreased heating requirement (the house is around 21 degrees). The heating last turned off at 05:30 on the morning of the 27th Feb and it hasn’t been back on since. It doesn’t look like we’ll need any this week and maybe not next week either despite negative overnight temperatures, down to around -4 to -5 on recent nights. Epic.
Seamed Roof - what to have Zinc/Aluminum/Greencoat
Russdl replied to Caroline's topic in Roofing, Tiling & Slating
That’s a good point. We have zinc, formed on site and 600mm centres. 400mm would have looked better. Pigeon shite eventually doesn’t wash off completely either, so if you can get anti roosting wires/spikes fitted economically consider those as well. -
@Onoff that is a genius suggestion. I’m now trying to find something around here that I need a Quinetic door switch for. @Pocster have you had a look at the videos on the product page in the link.
Willis heater UFH. Heaters in parallel or series?
Russdl replied to Russdl's topic in Underfloor Heating
Thanks for that explanation @John Carroll much appreciated. 👍🏻 -
That's interesting, I've never seen temperatures even close to that after 6 hours of running. I've turned the pumps down as well to slow down the rate of flow, perhaps I need to turn them down further? I do have a 7°C temperature drop between flow and return which I believe is optimum. Out of interest, what size is your UFH system? Mine is 824 meters of pipe (no idea how many litres that equates too). @John Carroll Thanks for those figures. What is the maths, I can't work it out? That and @ProDaves comment certainly indicate that there is no benefit from isolating one of the Willis heaters, but the lived experience is different for whatever reason.
