Russdl
Everything posted by Russdl
Sorry, I don't understand that bit?
- 131 replies
- triple glazing
- condensation
(and 3 more)
Also, there are three different types (standard windows, frameless and sliders) all of which have had condensation on them.
- 131 replies
- triple glazing
- condensation
(and 3 more)
@IanR they're timber frame, ally clad, Internorm windows. In theory the thermal breaks should be up there with the best.
- 131 replies
- triple glazing
- condensation
(and 3 more)
@IanR Thanks for those figures, interesting. I'll see if my IR thermometer can give me an answer on the pane temperature. On the windows/sliders with condensation it's all along the bottom where the pane meets the frame.
- 131 replies
- triple glazing
- condensation
(and 3 more)
@joe90 I've ramped up the MVHR as well, but maybe not for long enough. It wasn't part of my master plan to have condensation on the inside and aside from ramping up the MVHR I'm out of ideas.
- 131 replies
- triple glazing
- condensation
(and 3 more)
I thought I was going to hear that ? The house is currently around 20° and the humidity is around 63% (a degree/percent or two different in different rooms)
- 131 replies
- triple glazing
- condensation
(and 3 more)
On the last two mornings where its been pretty cold outside I've found a small amount of condensation on the insides of some of our triple glazed windows, I promised the good lady this would never happen!! The house is built to passive standard, has good airtightness and MVHR. Should I be getting condensation on the insides of the windows, and if not, what is going wrong?
- 131 replies
- triple glazing
- condensation
(and 3 more)
I’m pleased to report that is not mould, just crud (flies, seeds, dust etc).
- 100 replies
- mvhr vents
- filter
I guess that may have helped but the condensation is on the outside the box. Mainly on the top and down the back of the box. My aim now is to make the problem go away by insulating the inside of the box. @PeterW’s suggestion of a cut up yoga mat sounds like a good idea because I don’t want to restrict the flow and that should be thin enough to achieve that. I wonder if it’ll be too thin to be effective? I guess I could always do two layers.
- 100 replies
- mvhr vents
- filter
I can answer my own question here. My ‘pre-filter’ MDF boxes are in a warm loft and work a treat at pre-filtering however I am getting plenty of condensation on the outside of my ‘supply side’ pre-filter box, the ‘exhaust’ side is fine. I’m thinking the easiest fix will be to insulate the inside of it. any suggestions as to what would be best to use?
- 100 replies
- mvhr vents
- filter
Didn’t realise you were MCS certified Nick, is that a new thing for you?
@hendriQ I can’t offer too much insight to the Combimate performance, save to say it’s been in a year now and: There are no unusual noises coming from the Quooker (I’ve not opened it up yet to look inside, so it may just be well silenced). There is no limescale on the Quooker and we are in a very hard water area. Drinking water has no discernible taste to it. Finally, I haven’t changed the balls yet because it doesn’t seem like they need changing (based on no limescale anywhere). It only provides drinking water to the Quooker so it’s only a ‘half charge’ anyway. All the rest of our water goes through the water softener before it gets to any outlet.
Kalispera and welcome. Has the PHPP been done? You’re not going to need a wood burning stove I’ll wager.
We're all electric with a Sunamp, and it's the all electric Sunamp as well (we have no ASHP). We charge the Sunamp with PV or cheap overnight electricity, (both of which seem to have disappeared). Generally speaking it works very well and up to about a month ago we had paid nothing to charge the Sunamp as our solar export more than covered the cost of any electricity we had to import. I suspect October will be a different kettle of fish but we are in credit with our provider so I'm kinda hoping the credit balance will see us most of the way through the winter months until we start producing more than we use again next spring. Regarding reliability of the Sunamp, we had a thermistor string fail early on which was very quickly replaced by Sunamp and it's been fine since, it just sits there and silently does its thing. One of the early issues reported by Sunamp users on here was that it wouldn't charge until it was fairly well depleted. That is not the case now, our's will take a charge anytime we let it.
MVHR commissioning
Russdl replied to CC45's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@dpmiller so you reckon ‘ventilation’ in 5.1b is the same as ‘extract ventilation’ in 5.1a? I guess you’re right, I think most people here who refer to the “0.3 l/s per m2” section have all bumped up their extract rates to hit the target, and many of them are far wiser than me. -
MVHR commissioning
@dpmiller yep, mine are pretty much balanced. My question is in relation to Table 5.1b which specifies ’Ventilation’ rates (not ‘Extract Ventilation’ rates, that is in table 5.1a) Note ‘a’ of table 5.1b requires minimum ‘ventilation’ rate (not ‘extract ventilation’ rate) to be 0.3 l/s per m2 of internal floor area which would be 57.9 l/s for us. So the question is, do I combine my extract rate and supply rate to get to a figure above 57.9 l/s or do I have to ramp up the extract rate so that my extract total is above 57.9 l/s My view is that ‘ventilation’ is air in/air out whereas ‘extract ventilation’ is just air out. -
MVHR commissioning
I have a question regarding MVHR commissioning and Approved Document F. Document F, Table 5.1a is titled ‘Extract Ventilation Rates’. Document F, Table 5.1b is titled ‘Whole Dwelling Ventilation Rates’. To my mind ‘Ventilation’ is extract + supply and not extract only. It seems most on here are hitting the 5.1b ‘ventilation’ requirement by upping the extract rate to hit the 0.3 l/s per m2 of internal floor area. Is that necessary? What am I missing? Thanks in advance. -
And, for what it’s worth, the flush plates are different sizes for the different models so make sure if you do get a Geberit you get the correct flush plate for that model.
@SteamyTea. Yep. I described it as a ‘conditioner’ not a softener. (And I’ll update when I do take the Quooker to pieces)
Have you considered a Combimate? We live in a very hard water area and all our water is softened except for the cold supply to the Quooker. That single cold goes through the Combimate which is a water conditioner not a softener. We are the best part of a year on and there is no sign of scale on the Quooker tap itself, I’ve not opened up the Quooker to look inside yet. The Combimate may prevent your problem recurring once you’ve cleaned that tap up again.
@PeterW the Shelley 1PM is in control of the Sunamp, just need to sort out the IFTTT side to things so that it has full control. Thanks again for the ‘heads up’ on the Shelly stuff, brilliant kit.
- 12 replies
- sunamp
- octopus agile
(and 2 more)
I think these planners could have a lot to answer for. Octopus Agile is definetley untenable in that case (at the present time). I think that's about the most you'll get on a normal export tariff from any of the suppliers, Octopus included. On Octopus Agile Outgoing (I perhaps should have emphasised that it's Octopus Agile Outgoing) you have to take the rough with the smooth but what that does mean is that the export rate is around half of the import rate for each particular 30 min period. I used to be paying an average of 20-25p/kWh for import and would get an average of 10-12p/kWh for any export. The import price shot up an hour or so either side of 08:00ish and 12:00 ish and for around two hours or so either side of 18:00 ish. The export price would follow that price up, remaining at about half of the import price. What surprised me was that the export price didn't stop going up when the import price hit its 35p cap. The below is from a reasonably sunny day where the export rate was pretty high. You can see that during the daylight hours the export rate was mid 20p's/kWh when I started exporting and was mid 30p's/kWh when I stopped. The break in export around midday is where I was charging the Sunamp. On a clear day I charge the Sunamp and export as well. If the overnight tariff goes below the following days export tariff I charge the Sunamp overnight.
@TerryE It’s certainly not going according to my master plan just yet, the standard ‘import’ rate seems pretty much firmly fixed at 35p. Ouch. The ‘export’ rate is a bit of a surprise as its not capped like the ‘import’ rate is. Back in the old days, before energy prices went nuts, the export rate was around half the import rate, what ever that was, and that didn’t seem unreasonable but as you can see from the picture below, whilst the import is capped at 35p the export frequently exceeds half of that (the highest I’ve seen so far is £2.20, all be it when the sun wasn’t shining). Theoretically, if I ‘export’ twice what I ‘import’ then I break even. So far in October I’m exporting almost exactly what I’m ‘importing, so in effect I will be paying for half of what what I ‘import’ - most of it at 35p. Ouch. It’s obviously going to get worse as we move towards 21st Dec but should improve as we move into the new year. We’re all electric and in credit at the moment and I’m keen to see how it all balances out after a full 12 months of occupation. Wish me luck.
That does look like the one for me. I’ve got a lot of learning to do as I’ll want the Sunamp to come on when the electricity price goes below ‘X’ and switch off when it goes above ‘X’ which I think the combination of Octopus Agile/IFTTT and the Shelly 1PM should do for me but I fear it won’t be easy for me to line those ducks up, especially as I don’t do FB. YouTube it is I reckon. And lots of head scratching.
- 12 replies
- sunamp
- octopus agile
(and 2 more)
