Big Jimbo
Everything posted by Big Jimbo
Flashing / ending coping stone .
Big Jimbo replied to Pocster's topic in General Construction Issues
Can you get a grinder in and make the drip channel, wider, and deeper ? -
Stick your hand in a bag of flour. Shake off, then stick your finger in the hole. The flour will pick up any moisture and show easily.
I know that there are companies out there who use some sort of water jet machine, to cut a slot alongside a tree line. i think they go 2.4 m deep. They then put ridgid plastic in the seam to stop the encroachment of roots. It must be some serious pressure they use, as it cuts through tree roots etc. There was also a granite company i used to use, that cut granite using a water jet. I very much doubt you could do something similar on a DIY basis. I used to know the owner of the Biggest basement company in London. `They used to dig a meter wide hole in the front garden. Take out a portion of the footing. send in a micro digger, and would underpin in 1 meter sections as they excavated. Always had a conveyor, and a couple of guys with picks and shovels for the bits that the digger could not reach. It was mind blowing expensive, but all around Kensington and Chelsea and the square m price around there was £20k at the time.
Just a thought. has anybody seen the spray on rubber ? I believe that it has been used in basements in the USA. It is quite stretchy so, does not crack with movement.
Fire protection of steels
Big Jimbo replied to Post and beam's topic in General Self Build & DIY Discussion
Re @nod and @ETC . The last time I fitted a steel, I painted it with a load of gloopy bollom fire paint. The building inspector when he saw it said "no need to bother with that anymore" ?? -
Razor wire and other serious deterrents
Big Jimbo replied to Adsibob's topic in Networks, AV, Security & Automation
@Russell griffiths they are the proper job. Love em. -
The (not so) secret diary of two self builders, one aged 62 and a half…
Big Jimbo commented on G and J's blog entry in Da Bungalow
Well I just want to say.Well done. You will be fit as a fiddle by the time you get finished. -
DPM and block and beam floor
Big Jimbo replied to Glee's topic in General Self Build & DIY Discussion
Tony. What a mess. That whole thing is so wrong. That whole thing needs to come up, and be started again. You have no cavity ! I have got to go out now, but I will be back tonight and try and give you some answers later. Your builder is not a builder. I'm shocked. -
Should I go for flush flooring or standard 150mm step
Big Jimbo replied to mads's topic in Damp & DPCs
The 150mm from DPC to ground level wasn't made up for fun. You are asking for some nice damp. Have one level access point for the old duffers. Our rainfall is getting much heavier in GB. You get One chance to prevent water getting into your structure. When you have to have all your patio lowered you will be spending loads of cash, and making a right mess. -
Sit the beams on a continuous strip of DPM. It's cheap FFS, and don't forget to seal the ends of the beams which is now a Building regs requirement -
I'm not a fan of level thresholds. As a minimum, I would want a linear drain where any outside fixture is brought up to the height of the DPC. -
Primary vs Recycled - MOT type 3 - subbase for PERMEABLE driveway
Big Jimbo replied to bmj1's topic in Building Materials
My Mrs says you can't walk in high heels on that. -
Thats so true.I have got LP's and cassettes I can't play. Reel to reel tapes of my own music, (that I paid thousands of pounds to record ) that I can't play. Photos on phones and old computers that i can't access. Mini, and Dat, and video tapes, that I can't play. Compact discs, etc, etc. Even cars are over complicated. One small wire broken only son in laws car, made it drive like crap. Drop its fuel consumption considerably, Soot up internally, and fail its mot on emissions. All without even giving him a dash light warning. Technology is over rated without question IMO
You may have twisted the frame when fitting it ? That would cause the problem that you have. You may be able to adjust it by using the hinges in and out adjustment . The pin in the hinge is often like a cam. Be careful though. you may find that the seal no longer touches the frame on the hinge side if you adjust it too much. That will then cause a draft internally.
I told the council to demonstrate that they owned, and maintained the grass verge. They could do neither. I then pointed out that regardless of ownership, the residents would ,by adverse rights, having maintained the land forever, now have a right to claim it as there own, if they so chose to. Find out, who, if anybody, pays the tractor man.
If you and your neighbours left the grass to grow, he might be being paid to cut that at the same time as the hedge? Where I am the council maintains nothing.So I was able to tell them to F-off. Worth your while finding out
He might do it on behalf of the council for a fee, rather than because he likes playing on the tractor. That might put a spanner in the works for you.
Then ring the council and tell them to remove the stupid wording / condition . Plenty of info out there about putting a crossover from your land to an unclassified road.
If the road is unclassified, and you either own the land up to the tarmac , or the council own the Green verge, but don't maintain it, you can put a crossover anywhere from your land to the road without permission.
So the road is unclassified. Do the council maintain the Greenstrip next to the tarmac ? If they don't maintain it, you can tell them to f-off
Try looking it up on the internet . I can't remember the site. Just type in is, blah, blah, and full postcode a classified road
If you can answer No, to both of the above, you can tell them to F-off
Do the council maintain the green verge ?
